% Tolerance - Type 1 study on the gages, then a gage R&R (ANOVA)
nvpeter
Hello, I am new to the whole MSA process. My current project is to do a type 1 study on the gages, then a gage R&R (ANOVA) on the process that uses the measurement tool. After this, the customer would like me to come up with a specification on what the gage can be used for. I would have thought this would pertain to the resolution of the gage but the customer would like the %tolerance to be incorporated in this as well. Has anyone have any experience with this?
The customer is just asking you to take the Study Variation and divide by the maximum acceptable %Tolerance to determine the tightest tolerance for which you may use the gage.
nvpeter
Sorry if I am misinterpreting, so lets say if :
tolerance:+/- 0.005"
Study Var: .0111
%Study Var: 19.11%
%Tolerance: 19.99%
the risk of the measurement system is risking making an incorrect decision form the tolerance is 19.99% and so the tightest tolerance for the system should be +/-0.002 more than the usual (.01 * .1999 =~0.002). Or is this entirely wrong.
%Tolerance: 19.99% is interpreted as meaning the measurement variation consumes ~20% of the tolerance. Regarding the tightest tolerance that you can use this gage to measure, it depends on what threshold you set for an acceptable %Tolerance. Are you using 10% as the max acceptable? Is 20% acceptable, or 30%? For the sake of the example, let's say that 15% is the maximum acceptable %Tolerance. Divide the study variation by the max acceptable %Tolerance (15% or 0.15) to get the tightest tolerance the gage can measure.
T How do I calculate Capability or Performance for S-Type Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 4
M Minitab Type 1 Repeatability & GRR% of Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Definition S-type Tolerance - Unilateral tolerance where the desired value is 0 (zero) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
H Position Tolerance with MMC and MMB Manufacturing and Related Processes 0
A Nested ANOVA MSA - Excel sheet with bilateral tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
dhuot1990 Out of Tolerance for Weights Manufacturing and Related Processes 3
F Tolerance Acceptance Criteria General Measurement Device and Calibration Topics 3
M Definition of Characteristics Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Quantity Discrepancy Tolerance Standard(s)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Simulate Tolerance Range with Real Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Tolerance and MPEs for Re-calibration Manufacturing and Related Processes 0
S GD&T Bonus Tolerance OOS Capability, Accuracy and Stability - Processes, Machines, etc. 2
WEAVER Can you determine exact date an instrument went out of tolerance? General Measurement Device and Calibration Topics 10
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
I Profile tolerance with a positional tolerance to a hole ? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A % STUDY VARIATION VS. % TOLERANCE Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 31
A +0/-.001 Tolerance question - Feature size is 1.249 +0/-.001 - Actually measures 1.2493 (.0003 OHL Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
L Validation without Tolerance Qualification and Validation (including 21 CFR Part 11) 0
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
Q Acceptable Tolerance - how to derive? Measurement Uncertainty (MU) 16
D Tolerance symbol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
D Calibration tolerance question using Pipettes Medical Device and FDA Regulations and Standards News 3
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Proud Liberal Small radius with tight tolerance on a torus General Measurement Device and Calibration Topics 4
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T How to justify this High %Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
S Tolerance limits for micro balance General Measurement Device and Calibration Topics 1
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
D Tolerance when verifying an analytical balance General Measurement Device and Calibration Topics 3
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
