Tolerance vs. Part to Part - Is it ndc? When using % of tolerance everything is fine
Corey
Hello, I have been browsing these forums for too long. The more I research, the more I get confused.
Woudl someone please check out the attachment and tell me why when using %tol everythign is fine and dandy? However, part to part is horrid?
Is it due to ndc? I am on the road and do not have any reference material that will help me determine the ndc.
  • Gage R and R spreadsheet - another one111.xls
Re: Tol vs. Part to Part is it ndc?
This spreadsheet evaluates the guage for two very distinct purposes.
The tolerance method is calculating the P/T Ratio. This compares the gage variation to the total tolerance, and assesses the guages suitability for part inspection to tolerance. Your gauge is very suitable for part inspection.
The "Using Part to Part variation" method calculates %GRR. This compares the gauge variation to the part variation, and assesses the guages suitability for process control (e.g., SPC), or for use in statistical studies (e.g., DOE, t-tests, etc.). ndc is a related measure to %GRR. It does not relate to P/T Ratio at all. If the variation of the parts accurately represents the variation of the process, then this guage is not suitable for process control. If you need this guage for process control, you will need to reduce the repeatabilty (within operator) variation.
Most guages are used for inspection or for process control, but not usually for both. Determine what this guage is used for, select the appropriate method (P/T Ratio for inspection; %GRR for process control), then make your decision based on the result of that method. The results of the two methods will not typically match each other, so don't let that worry you.
cuadra - 2010
Hi Corey:
Your P/T ratio looks great.
Your part to part variation is small hence that is why your second acceptance criteria is giving an artificially high number. A low ndc is not the cause, it is the result of having low part to part variation.
This is easy stuff:
1- The Gage R&R give you an estimate of the standard deviation of your measurement system error, lets call it STD.
2- If you multiply the STD by 6, you get the total error that your measurement system.
3- If you divide the standard deviation of your part to part variation over the STD of your measurement system, this ratio will give you a sense of how many times bigger is the part to part variation with respect the measurement system error (STD).
4- If this ratio is for instance one, the system will not be able to tell one part from the other.
5- In your case, this is not bad, it just means that the parts are so close together that the system will put all of them inside the same measurement "bucket". In other words, the system will have only one distinct category.
Note: Your spreadsheet has some conceptual errors.
Cuadra
Corey
Re: Tolerance vs. Part to Part - Is it ndc? When using % of tolerance everything is f
Thanks Guys. It made sense till I read the both responses..lol
I will need the gage to control a KPc of a 2 cavity mold.
So if the gage is not acceptable for process control, how can it also say that the p to p variation is having an impact on the %Part to Part. How does it identify /sense the p to p variation?
Since you need to control a KPC, the Tolerance method or P/T Ratio does not apply. You must use the %GRR or Part Variation method. This is where your guage has a problem.
cuadra's post is partially correct. I agree with items 1 - 4, but item 5 is not accurate. ndc does matter greatly, and this will be a major issue for process control. If you attempt to use this guage for SPC, your control limits will be based on measurement error, not part-to-part variation. Your control limits will be inflated, and your averages will hug the central line.
The first thing that you should do is verify that the variation of your sample parts match the variation of your process. If they do not reflect the actual variation, your %GRR is not valid. If they do reflect the process variation, you probably have a highly capable process, which is good, but an inadequate guage, which is bad.
All of the variation is in Repeatability or Within-Operator variation. Try evaluating the within-part variation (variation in form) of the characteristic that you are measuring.
cuadra - 2010
Thank you for the Clarification on 5:
I did not mean to imply that ndc is not important, in his case, he just probably selected parts that are too close together. The sentence shall read " this is not necessarily bad".
In fact ndc, is conceptually equivalent to the "Signal to Noise" ratio of your measurement system. The equation to compute is ndc = 1.4142 * ( variation of your sample parts / variation of your measurement system).
As Miner already mentioned, the variation of the numerator in this equation needs to reflect the actual variation of your process. In other words, a perfect measurement system could resolve any production part passing thru it, but in real life, the "Noise/Error" will diminish the ability of the measurement system to resolve "who is different/equal from Who" with just a single number, hence the system is bound to discriminate using a "Range/Bucket/Categority"
cuadra
Note: This is beyond the scope of this discussion but under the "right conditions": A measurement system may have a low ndc but still, be able to protect the customer by discriminating a "good" from "bad" part. Of course, it is ideal to have both properties available.
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
C Acceptable NDC for %GR&R part inspection to Tolerance (%Tolerance) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
A Setting air gauging outside of a part tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 2
V Tolerance achievable for Sheet Metal Part with some weld - 0.4mm TP Manufacturing and Related Processes 5
K Profile of a Surface Tolerance - Part with a 195 mm radius on it Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
optomist1 Maximum Shift Tolerance Restrained Part - Calculation of Datum Shifts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C Part Tolerance and TAR (Test Accuracy Ratio) - Non-Fixed Gaging General Measurement Device and Calibration Topics 2
Miner Intro to MSA of Continuous Data - Part 9: %Tolerance for One-sided Specs Imported Legacy Blogs 3
A Best Way to Tolerance a Cylindrical Section on a Part (Customer's Design and Drawing) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D Part Variation, Unilateral Tolerance, Destructive Testing - Gage R&R Experts pls help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
J Clarification of ISO 2768-1 - Inside bend radius tolerance - Metal stamped part Various Other Specifications, Standards, and related Requirements 2
Q Part Tolerance and Equipment Accuracy of thickness gage General Measurement Device and Calibration Topics 1
M Tool capability / part tolerance criteria General Measurement Device and Calibration Topics 7
B Calibration Accuracy vs. Gage/Part Tolerance General Measurement Device and Calibration Topics 4
P Calculating Gage R&R with Part Tolerance instead of Total Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
N Gage R&R - Using Tolerance method, or part to part variation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
U How do part tolerance and gage tolerance interact? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
L Tape Measures & Scales - Part Tolerance - Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 24
H Position Tolerance with MMC and MMB Manufacturing and Related Processes 0
A Nested ANOVA MSA - Excel sheet with bilateral tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
dhuot1990 Out of Tolerance for Weights Manufacturing and Related Processes 3
F Tolerance Acceptance Criteria General Measurement Device and Calibration Topics 3
M Definition of Characteristics Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Quantity Discrepancy Tolerance Standard(s)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Simulate Tolerance Range with Real Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Tolerance and MPEs for Re-calibration Manufacturing and Related Processes 0
S GD&T Bonus Tolerance OOS Capability, Accuracy and Stability - Processes, Machines, etc. 2
WEAVER Can you determine exact date an instrument went out of tolerance? General Measurement Device and Calibration Topics 10
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
I Profile tolerance with a positional tolerance to a hole ? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A % STUDY VARIATION VS. % TOLERANCE Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 31
A +0/-.001 Tolerance question - Feature size is 1.249 +0/-.001 - Actually measures 1.2493 (.0003 OHL Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
L Validation without Tolerance Qualification and Validation (including 21 CFR Part 11) 0
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
Q Acceptable Tolerance - how to derive? Measurement Uncertainty (MU) 16
D Tolerance symbol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
D Calibration tolerance question using Pipettes Medical Device and FDA Regulations and Standards News 3
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Proud Liberal Small radius with tight tolerance on a torus General Measurement Device and Calibration Topics 4
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T How to justify this High %Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
