I am upgrading and automating a measuring process and this has lead me to examine the coding lying behind a computer-based data capture system that has been in place for a while.
ie various parameters of parts are measured at an AQL, the data is manually entered into the PC and passed/failed on the basis of maipulation of the data entered.
I am looking to have the process automated, removing the manual entry of the data, and have discovered a bit of code in the data handling that stipulates that if the average value of parameter X for the sample exceeds the upper and lower tolerances +/- 1 Standard Deviation , the batch is failed.
ie the specification for paramater X is 10-20, but this data criteria widens the criteria to a lower tolerance of 10-1 SD and the upper tolerance to 20+1 SD.
I don't understand why the creator of the code would have widened the tolerances by 1 SD as they did, but I'm uncomfortable removing the code without justification.
Any opinions?
Any opinions?
