Torque Confidence Testing (Non-normal Distribution)
Rob C
greetings all!
I have a torque process that we are qualifying. i have 30 samples that have been tested and the distribution is non-normal.
the test is to establish a 99% confidence that failure would not occur until >5 turns.
we experienced no failure <=5 turns. but the distribution is skewed toward the limit.
can anyone suggest a model or method to determine the confidence level?
thanks,
bobdoering
Stop X-bar/R Madness!!
If you can post the data (in an Excel spreadsheet is especially handy), it would greatly allow us to assist.
Rob C
here's the data
thanks
Rob C
  • torque data.xls
Tim Folkerts
This sounds like a typical application of reliability engineering.
In reliability engineering, the Weibull Distribution is a commonly used instead of the normal distribution precisely because it can fit skewed, non-normal data.
There is lots of information on the web about Weibull analysis. A good website is http://www.weibull.com/basics/lifedata.htm They sell software, but they also have a lot of good information.
And I always recommend the NIST Engineering Statistics Handbook. They have quite a bit of info on reliability at http://www.itl.nist.gov/div898/handbook/apr/apr.htm, including discussion of Weibull analysis.
Tim F
P.S. if you post the data, there is a good chance someone will take a look at it.
bobdoering
I have attached the 'best fit' distribution data from your data. I used my favorite program - Distribution Analyzer from Taylor Enterprises (www.variation.com)
  • data.doc
Tim Folkerts
One more question.... Are the numbers listed the next higher number from when it failed? For example, if the failure is listed at "7", I am guessing that means it survived 6 turns, but failed some time before the 7th turn? As opposed to "7" meaning sometime between 6.5 turns and 7.5 turns.
I ran the numbers thru Minitab and found that the 3-Parameter Weibull, the 3-Parameter Lognormal, and the 3-Parameter Loglogistic all fit quite well.
The results are listed below (in a format that is unfortunately a little hard to read). The bottom line is that 1% of the parts are predicted to fail after 5.07, 5.31, and 5.22 turns for he three different models. Unfortunately, the lower confidences limits for the 1% failure time is 4.95 turns. So you couldn't be 95% confident that 99% would survive 5 turn.
At least, that is how I interpret the results....
Goodness-of-Fit
Anderson-Darling Correlation
Distribution (adj) Coefficient
3-Parameter Weibull 0.665 0.954
3-Parameter Lognormal 0.757 0.979
3-Parameter Loglogistic 0.754 0.986
Table of Percentiles
Standard 95% Normal CI
Distribution Percent Percentile Error Lower Upper
3-Parameter Weibull 1 5.06815 0.313992 4.95 5.72249
3-Parameter Lognormal 1 5.30569 0.620517 4.95 6.67256
3-Parameter Loglogistic 1 5.22087 0.287229 4.95 5.81530
3-Parameter Weibull 5 5.35177 0.250414 4.95 5.86578
3-Parameter Lognormal 5 5.57592 0.424557 4.95 6.47333
3-Parameter Loglogistic 5 5.54601 0.227759 5.11710 6.01087
3-Parameter Weibull 10 5.63980 0.240373 5.18781 6.13116
3-Parameter Lognormal 10 5.79599 0.319429 5.20254 6.45712
3-Parameter Loglogistic 10 5.80170 0.222758 5.38113 6.25515
3-Parameter Weibull 50 7.78835 0.485794 6.89211 8.80114
3-Parameter Lognormal 50 7.39866 0.458349 6.55271 8.35382
3-Parameter Loglogistic 50 7.38317 0.370192 6.69212 8.14559
D GR&R for Torque application Manufacturing and Related Processes 6
S Automatic torque device checking FMEA and Control Plans 2
T Torque tool calibration Oil and Gas Industry Standards and Regulations 5
T Sensitivity Coefficient for Nm Torque Analyzer Measurement Uncertainty (MU) 1
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B M85049 backshell strain relief screw torque Manufacturing and Related Processes 1
H Can a calibration lab still use ISO 6789:2003 as guide for torque calibrations Other ISO and International Standards and European Regulations 1
D Torque fractional unit of measure; cN-m or N-cm? General Measurement Device and Calibration Topics 2
L Special Processes - Technical reason concerning torque - Anaerobic compounds Manufacturing and Related Processes 10
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Torque Value for Different types of Fasteners (Socket Head, Button Head, CSK) Manufacturing and Related Processes 2
D How about another torque discussion? Assembly processes General Measurement Device and Calibration Topics 9
D Yet another torque question... Assembly processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Chrysler is requesting a "Torque Strategy" for all Fastener Joints FMEA and Control Plans 7
T Adding an adapter to a Torque Meter to change the Range Capability, Accuracy and Stability - Processes, Machines, etc. 6
J Pneumatic & Electrical Torque Tool - Calibration/Verification of 'Power Tools' General Measurement Device and Calibration Topics 3
B How to do an MSA on an Automated Torque / Angle System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D Standard torque values for threaded fasteners AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
sonflowerinwales Torque of nuts and bolts, which one should you use? Manufacturing and Related Processes 8
J Calibration Merry Go Round - Torque Wrenches and Testers Calibration Frequency (Interval) 13
I Torque-Tension Testing on Automotive Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Torque Wrench Calibration Interval Extension with Non-Use? General Measurement Device and Calibration Topics 1
W Torque Wrench Calibration question Service Industry Specific Topics 9
K MSA for Torque Dynamometer in Stepping Motor Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Preventing Torque Wrench Deterioration Calibration Frequency (Interval) 5
B Digital Torque Meter Gage R&R General Measurement Device and Calibration Topics 4
S Which Torque Meter do I choose based on CpK studies ? Capability, Accuracy and Stability - Processes, Machines, etc. 2
A Torque Wrench Calibration/Verification General Measurement Device and Calibration Topics 24
Q Need help on MSA study on a torque analyzer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J How to measure Loosening and Tightening Torque (VDA 5 - MSA) Quality Tools, Improvement and Analysis 5
Proud Liberal Torque Measurement Around A Rivet Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Torque Tester Calibration Traceability and Certificate question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I Should we immediately have recalibrated our Digital Torque Gauge? IATF 16949 - Automotive Quality Systems Standard 5
L Pneumatic Torque Wrench Calibration Procedure Calibration and Metrology Software and Hardware 1
W Measuring the Dial Torque of Plastic Insulin Pen devices Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Computing Failure Torque for Helicoil Threads in 6061-T6 Aluminum Design and Development of Products and Processes 5
D How to conduct a Gage R&R on DC Tools to Torque Bolts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Motor Stall Torque Failure after Changing Supply of Cyclindrical Gears Manufacturing and Related Processes 1
M How to perform a Gage R&R on Torque Wrenches Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C How to Calibrate and Verify Torque Multiplier Gages General Measurement Device and Calibration Topics 6
hogheavenfarm Is there a relatively inexpensive method of Calibrating our Torque Wrenches? General Measurement Device and Calibration Topics 7
C Control Plans - Evaluation Measurement Technique Column - Torque Control FMEA and Control Plans 2
S ISO 9001 Section 7.6 - Customer has supplied torque specifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Q Defining Torque Requirement for Screwing Power Module onto Heatsink Manufacturing and Related Processes 2
R Gage R&R for Torque Device (Non - Replicable Measurement Systems) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T why CPK <1.0 regarding two pieces of control charts of torque wrench? Statistical Analysis Tools, Techniques and SPC 2
Q Torque Wrench Issue - Incorrect method to collect the "as found data" Problem Solving, Root Cause Fault and Failure Analysis 7
