Torque Measurement Around A Rivet
Proud Liberal
I've got a requirement to check a max torque for an application where two stampings are riveted together. The range of motion for the joint is less than 90?.
I've proposed using a fixed weight (attached at a know distance from the pivot) as a GO/NOGO gage.
Are there any issues with this approach?
rclanzillotto
How does this translate to motion wear and tear? Depending on the criticality here, might consider endurance (lifetime test). Regards
Proud Liberal
Wear and tear are being evaluated through DV testing. This would be an in-process check of the "tightness" of the rivet (which must rotate freely w/ < 1.3 Nm torque).
C Control Plans - Evaluation Measurement Technique Column - Torque Control FMEA and Control Plans 2
R Gage R&R for Torque Device (Non - Replicable Measurement Systems) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Mechanical Torque Wrench MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L Spring measurement device - Measuring the torque of the spings at diferent angles General Measurement Device and Calibration Topics 1
P MSA (Measurement Systems Analysis) for pneumatic torque gun Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Torque wrenches and drivers - How to perform MSA (measurement system analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Jerry Eldred MSA (Measurement System Analysis) on Torque Wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B M85049 backshell strain relief screw torque Manufacturing and Related Processes 1
H Can a calibration lab still use ISO 6789:2003 as guide for torque calibrations Other ISO and International Standards and European Regulations 1
D Torque fractional unit of measure; cN-m or N-cm? General Measurement Device and Calibration Topics 2
L Special Processes - Technical reason concerning torque - Anaerobic compounds Manufacturing and Related Processes 10
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Torque Value for Different types of Fasteners (Socket Head, Button Head, CSK) Manufacturing and Related Processes 2
D How about another torque discussion? Assembly processes General Measurement Device and Calibration Topics 9
D Yet another torque question... Assembly processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Chrysler is requesting a "Torque Strategy" for all Fastener Joints FMEA and Control Plans 7
T Adding an adapter to a Torque Meter to change the Range Capability, Accuracy and Stability - Processes, Machines, etc. 6
J Pneumatic & Electrical Torque Tool - Calibration/Verification of 'Power Tools' General Measurement Device and Calibration Topics 2
B How to do an MSA on an Automated Torque / Angle System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D Standard torque values for threaded fasteners AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
sonflowerinwales Torque of nuts and bolts, which one should you use? Manufacturing and Related Processes 8
J Calibration Merry Go Round - Torque Wrenches and Testers Calibration Frequency (Interval) 13
I Torque-Tension Testing on Automotive Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Torque Wrench Calibration Interval Extension with Non-Use? General Measurement Device and Calibration Topics 1
W Torque Wrench Calibration question Service Industry Specific Topics 9
K MSA for Torque Dynamometer in Stepping Motor Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Preventing Torque Wrench Deterioration Calibration Frequency (Interval) 5
B Digital Torque Meter Gage R&R General Measurement Device and Calibration Topics 4
S Which Torque Meter do I choose based on CpK studies ? Capability, Accuracy and Stability - Processes, Machines, etc. 2
A Torque Wrench Calibration/Verification General Measurement Device and Calibration Topics 24
Q Need help on MSA study on a torque analyzer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J How to measure Loosening and Tightening Torque (VDA 5 - MSA) Quality Tools, Improvement and Analysis 5
R Torque Tester Calibration Traceability and Certificate question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I Should we immediately have recalibrated our Digital Torque Gauge? IATF 16949 - Automotive Quality Systems Standard 5
L Pneumatic Torque Wrench Calibration Procedure Calibration and Metrology Software and Hardware 1
W Measuring the Dial Torque of Plastic Insulin Pen devices Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Computing Failure Torque for Helicoil Threads in 6061-T6 Aluminum Design and Development of Products and Processes 5
D How to conduct a Gage R&R on DC Tools to Torque Bolts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Motor Stall Torque Failure after Changing Supply of Cyclindrical Gears Manufacturing and Related Processes 1
M How to perform a Gage R&R on Torque Wrenches Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C How to Calibrate and Verify Torque Multiplier Gages General Measurement Device and Calibration Topics 6
hogheavenfarm Is there a relatively inexpensive method of Calibrating our Torque Wrenches? General Measurement Device and Calibration Topics 7
S ISO 9001 Section 7.6 - Customer has supplied torque specifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Q Defining Torque Requirement for Screwing Power Module onto Heatsink Manufacturing and Related Processes 2
T why CPK <1.0 regarding two pieces of control charts of torque wrench? Statistical Analysis Tools, Techniques and SPC 2
Q Torque Wrench Issue - Incorrect method to collect the "as found data" Problem Solving, Root Cause Fault and Failure Analysis 7
