Torque specification for setting thread rings vs. "Finger Force" and "Snug"
Charles Harvey
I have a QA tech. who wants to know actual torque specs to define "finger force" and "snug" when setting thread rings. Is anyone familiar with such a specification. I have been setting thread rings for 17 years and have been happily unaware of torque specs for setting thread rings.
Al Dyer
Me also, never heard of any spec. Common sense tells me that "finger force" and "snug" are extremely subjective terms that can't be quantified.
Al...
Marc
Sorry we missed this thread. Thanks for kicking it up, Al.
Any more takers on Torque specification for setting thread rings vs. "Finger Force" and "Snug"?
John Nabors - 2009
Charles-
By any chance is this QA tech really green and really, really eager? Eager like a beagle pup going after his first rabbit?
I've always done it by touch. To my (possibly Stone Age) way of thinking, by the time there would be enough drag between the ring and the set plug to register on a torque meter you've already tightened the ring much too far. I'm attaching a pretty decent procedure for setting rings.
Tell your tech that there still are some things that cannot be conveyed by a degree or a certification, only by experience and hands-on training, and setting thread rings is one of them. If you want pure objectivity, buy a Johnson Gage.
Regards -John
Satellite
I understand the problems. We have 13 different people from 6'3" 285# to 5'3, 110#. Everyone has a different "feel" for what is snug and finger tight. The 3 finger rule doesn't seem to work too well under these conditions since tight is relative to finger strength. :confused:
I suggested a similar idea for torque using in-lbs to my thread supplier and was almost disowned - it doesn't meet the standard. In the mean time I am continually fighting the thread war - goes on this gage, doesn't go on that one. Clear out the inventory and have one person verify/set all of that size.
So, we are starting to look at electronic ID/pitch diameter gages for specific thread sizes as a training tool for setting gages correctly. Set the gage, measure it see how close it is. Repeat until you can hit the size correctly - both pitch diameter and minor diameter. This way we can establish a consistent feel across everyone. Since this is so subjective, the training is something we will have to refresh every couple of months just to ensure continued consistency.
My thread supplier still thinks I'm spitting in the wind,:lmao: but we will see.
Wayne
Gage Crib Worldwide
Sorry all. This is not that critical of an issue. The setting of a thread ring gage is a feel thing. If one person has one feel and another has a different feel, it is OK because the actual difference between the two feels is minimal. By minimal. I mean less that the thread gage tolerance. For a 16-TPI thread, the gage tolerance is 0.0003".
Thread set plugs have a similar tolerance. A thread ring gage set with one thread set plug will not fit a different thread set plug, but both thread ring gages are considered to be properly set. The standard states that a part is considered good if a properly set thread ring gage passes the part. If checked with two properly set thread ring gages, and if either thread ring gage passes the part, the part is considered good, even if the other thread ring gage fails the part.
The standard gives lots of room here, because it is not that critical of an issue. Don't work at it so hard. Just meet the intent of the standard and be happy, regardless if you have Betty Boop or Brutus setting your gages.
John Nabors - 2009
Once again, if your pitch diameter really is that critical, a Johnson Gage will give you objective, variable information.
Wayne
Gage Crib Worldwide
Agreed, a variable type thread comparator will give you some good objective data. There are several good brands of this type of gage: Johnson; Starrett; Southern; MTG; Gagemaker. These are not useful in setting your ring gages. They are only good for checking parts.
G
Grizz1345
It amazes me that in our high tech society we depend on feel to set thread ring gage. It is the same when getting thread ring gages re-calibrated. I have found that sending to the original manufacturer means less reworked gages. It all sounds so archaic. Oh well in 5 months I will retire and not have to be concerned about this subject.
Have a great day.
Wayne
Gage Crib Worldwide
It amazes me that in our high tech society we depend on feel to set thread ring gage...
Some measurements will require more precision than others. In our high tech society we have the ability to measure the width of a piece of wood with a CMM, but it is still usually measured with a tape rule. The same is true when setting thread ring gages. We have the technology to be more precise, but the level of precision required easily falls within the tolerance variation of feel. To put more effort into the process is wasted dollars.
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B M85049 backshell strain relief screw torque Manufacturing and Related Processes 1
H Can a calibration lab still use ISO 6789:2003 as guide for torque calibrations Other ISO and International Standards and European Regulations 1
D Torque fractional unit of measure; cN-m or N-cm? General Measurement Device and Calibration Topics 2
L Special Processes - Technical reason concerning torque - Anaerobic compounds Manufacturing and Related Processes 10
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Torque Value for Different types of Fasteners (Socket Head, Button Head, CSK) Manufacturing and Related Processes 2
D How about another torque discussion? Assembly processes General Measurement Device and Calibration Topics 9
D Yet another torque question... Assembly processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Chrysler is requesting a "Torque Strategy" for all Fastener Joints FMEA and Control Plans 7
T Adding an adapter to a Torque Meter to change the Range Capability, Accuracy and Stability - Processes, Machines, etc. 6
J Pneumatic & Electrical Torque Tool - Calibration/Verification of 'Power Tools' General Measurement Device and Calibration Topics 2
B How to do an MSA on an Automated Torque / Angle System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D Standard torque values for threaded fasteners AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
sonflowerinwales Torque of nuts and bolts, which one should you use? Manufacturing and Related Processes 8
J Calibration Merry Go Round - Torque Wrenches and Testers Calibration Frequency (Interval) 13
I Torque-Tension Testing on Automotive Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Torque Wrench Calibration Interval Extension with Non-Use? General Measurement Device and Calibration Topics 1
W Torque Wrench Calibration question Service Industry Specific Topics 9
K MSA for Torque Dynamometer in Stepping Motor Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Preventing Torque Wrench Deterioration Calibration Frequency (Interval) 5
B Digital Torque Meter Gage R&R General Measurement Device and Calibration Topics 4
S Which Torque Meter do I choose based on CpK studies ? Capability, Accuracy and Stability - Processes, Machines, etc. 2
A Torque Wrench Calibration/Verification General Measurement Device and Calibration Topics 24
Q Need help on MSA study on a torque analyzer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J How to measure Loosening and Tightening Torque (VDA 5 - MSA) Quality Tools, Improvement and Analysis 5
Proud Liberal Torque Measurement Around A Rivet Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Torque Tester Calibration Traceability and Certificate question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I Should we immediately have recalibrated our Digital Torque Gauge? IATF 16949 - Automotive Quality Systems Standard 5
L Pneumatic Torque Wrench Calibration Procedure Calibration and Metrology Software and Hardware 1
W Measuring the Dial Torque of Plastic Insulin Pen devices Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Computing Failure Torque for Helicoil Threads in 6061-T6 Aluminum Design and Development of Products and Processes 5
D How to conduct a Gage R&R on DC Tools to Torque Bolts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Motor Stall Torque Failure after Changing Supply of Cyclindrical Gears Manufacturing and Related Processes 1
M How to perform a Gage R&R on Torque Wrenches Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C How to Calibrate and Verify Torque Multiplier Gages General Measurement Device and Calibration Topics 6
hogheavenfarm Is there a relatively inexpensive method of Calibrating our Torque Wrenches? General Measurement Device and Calibration Topics 7
C Control Plans - Evaluation Measurement Technique Column - Torque Control FMEA and Control Plans 2
S ISO 9001 Section 7.6 - Customer has supplied torque specifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Q Defining Torque Requirement for Screwing Power Module onto Heatsink Manufacturing and Related Processes 2
R Gage R&R for Torque Device (Non - Replicable Measurement Systems) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T why CPK <1.0 regarding two pieces of control charts of torque wrench? Statistical Analysis Tools, Techniques and SPC 2
Q Torque Wrench Issue - Incorrect method to collect the "as found data" Problem Solving, Root Cause Fault and Failure Analysis 7
MarilynJ6354 Torque Wrench Calibration Frequency (Calibration Interval) Calibration Frequency (Interval) 38
B How to find Uncertainity in a Torque Wrench? Measurement Uncertainty (MU) 5
H Usable Torque Range - Using a torque driver at more than 80% of its range Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
V Calibration procedure for Torque Meter Needed General Measurement Device and Calibration Topics 6
