Touchscreen Polymer Layer Deformation Measurement
normzone
Hello all. Thanks for all your help in advance. I've got a new inspection challenge.
We are seeing an artifact of manufacture in a touchscreen bonded to an LCD.
The touchscreen consists of a polymer layer attached to a piece of glass.
That assembly gets bonded to an LCD.
What we're seeing is that when the LCD heats up, the polymer layer of the touchsreen expands at a different rate than the glass it's bonded to, and in doing so swells up slightly in a mode we're referring to as "pillowing". It's not visible with text or image, but the customer is not happy.
Discussions are underway to quantify exactly how much of this phenomena is acceptable.
My challenge is how to measure the amount of deformation. It is visible only when the unit is at operating temperature. Contact measurement is going to be touchy at best, and I'm not familiar with any other techniques that would be appropriate.
I do have some budget available to address this issue, so I'm open to all suggestions.
Thank you all, Covers (would that more properly be Elsmarians?)
Norman
Tim Folkerts
Re: Touchscreen layer deformation measurement
Some sort of optical testing seems like it would work. I am envisioning shining a light on the surface and seeing how it reflects. Something like this (where the diagonal lines are the light and the periods, —— is your surface, and the periods are needed just to maintain the spacing)
____—_______
If the the surface to be tested is flat (or even uniformly curved), the reflection from the glass/polymer surface should be uniform. If the surface is "pillowed" then the reflection would get distorted. For instance if the surface being tested was a rectangular sheet, you should see a rectangular spot on the ceiling. If the spot is patchy or the edges are distorted, the surface has imperfections.
You would have to find a way to quantify the quality of the reflection compared to know quality of surfaces. You might be able to do this by eye, or perhaps digitally image the reflection to see how uniform the reflected patch is.
This is just brainstorming -- I don;t know of such a device commercially available.
Norman
This kind of dimensional measurement can get very expensive if you want to buy the equipment to do it. You might want to think about contacting a local metrology lab that has something like this or some other form of laser/white light scanner.
normzone
Expensive indeed. My boss just asked me to see what I could do for $5K - I didn't have the heart to tell him. I said I'd look around.
I figure with a height gage and a surface plate and a unit at operating temperature I can go for contact until deformation of the deformation (DOTD) becomes evident, and then compare that to a non-deformed zone (NDZ) contact point.
But the area of uncertainty includes both the amount of contact required to create visible DOTD and the unseen/unfelt amount of contact in the NDZ.
I think my boss was expecting me to produce a ray gun that would display true values in the production area.
EDIT: Well, I guess this constitutes a happy ending. The people who make the laser equipment that [Jim Wynne] suggested (thanks again Jim) do their manufacturing right around the corner from us. While it's a bit pricey for my budget today they are going to bring their service to us for a fee and get us some numbers. This should be fun.
Thanks all who viewed or posted -
Norman:bigwave:
normzone
Some sort of optical testing seems like it would work. I am envisioning shining a light on the surface and seeing how it reflects. Something like this (where the diagonal lines are the light and the periods, ?? is your surface, and the periods are needed just to maintain the spacing)
____??_______
I've long since left that organization and now play for a competing team, but I came across this thread today and wanted to postscript it.
What one of our engineers came up with was a variant of what [Tim Folkerts] described above. The contraption viewed the deformity developed at an angle and bounced that image expanded up to a grid that allowed us to quantify the expanded amount of deformity, and we took a picture as well.
Splitting hairs with light and mirrors...
H On choosing touchscreen displays and ensuring IEC 60601 compliance IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
B Medical Device LCD Touchscreen Compliance IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Going from push buttons to touchscreen -> Is a new 510(k) needed? Other US Medical Device Regulations 4
T Medical Device Touchscreen Input IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Mobile Touchscreen Devices in a Manufacturing Environment Manufacturing and Related Processes 11
N IMDS Warning Polymer Material Two Substances RoHS, REACH, ELV, IMDS and Restricted Substances 8
B MU for DSC (Differential Scanning Calorimetry) for Polymer Testing Measurement Uncertainty (MU) 1
J Maximal limit of Aluminum in Polymer Medical Device Implants (EU) Other Medical Device and Orthopedic Related Topics 1
R Use of Valve Bags for Medical Grade Polymer Manufacturing and Related Processes 1
T Polymer Lithium Ion Battery and Ventilation Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
D Sample Sizes for 'Bulk' Fluids/ Materials (Polymer Synthesis Process) Design and Development of Products and Processes 1
A I need some quality manuals for quality system - Tire or polymer and rubber industry Quality Management System (QMS) Manuals 1
P Raw materials as bulk materials (polymer, adhesive, etc) for PPAP IATF 16949 - Automotive Quality Systems Standard 1
I Have you ever heard about TOSI (polymer)? IATF 16949 - Automotive Quality Systems Standard 6
V Polymer/Material Specifications - Class 1 Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Risk analysis of syringe made from novel polymer Supplier Quality Assurance and other Supplier Issues 3
K ISO 15223-1 Sterile barrier system - The 3-layer symbol EU Medical Device Regulations 1
N PCB Creepage and Air Clearance on 8 Layer Boards IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Prototype Resin Transfer Moulds - Paste Layer Thickness - Construction Manufacturing and Related Processes 2
C Calculating the Lead (Pb) ppm from the Plating Layer RoHS, REACH, ELV, IMDS and Restricted Substances 6
F MES Systems - Why MES is separated from the ERP layer Manufacturing and Related Processes 1
J I am looking for an example of a Layer 2 audit for Middle Managment Document Control Systems, Procedures, Forms and Templates 1
A Three layer documentation system in a small company Document Control Systems, Procedures, Forms and Templates 4
