Toyota PPAP Process - Three Questions
Berger
Hi, I am new to elsmar and found that this is the place where all experience gurus are. I have searching but did not get the information I am looking for.
I am a quality engineer who are now newly a Toyota supplier. I am confuse on how to prepare PPAP for Toyota. I know that SQAM is the best source of the information, but after reviewing SQAM, I still don't know what to start. Can anyone help me please? It will be very very appreciate and this help will safe my life.
I have experience for PPAP but not with Toyota so that I am not sure what is difference. Not sure if Toyota require PPAP packages same like other or not.
1) What are the steps of preparing PPAP submission for Toyota ?
For example : submit I/S --> PFMEA/ MQC-->Boundary sample and Sample part submit to Toyota-->Submit AR form for PA approval ( with all follow documents completed/Approved : MQC, FMEA, I/S, Capability study, Raw material cert, PEP, SDS and QRC)
2) If the Drawing/PFMEA does not have designated control characteristic [Pc] ==> do I still need to submit the capability study?
- if yes,
- then how to determine which dimensions should include on capability study?
- then we are only focusing on Ppk (>1.67) as the PPAP part is only short term with small sample size correct?
3) This part does not have any checking fixture (both variable and attribute) ==> do we still need to submit any GR&R ? The process is using PLC only no checking requires rather than visual check when placing each part into the bin.
4) Do Toyota always require Boundary sample and sample part submission (sample as PPAP parts?) ?
5) Any other information , suggestion would be really and very appreciated.
Thank you in advance,
Berger
optomist1
A Sea of Statistics
Hi Berger,
First welcome, this is one of the best sources for taping experience. I would strongly urge you first contact your Toyota Supplier contact as his or her info and input is what is needed here. Of course unless someone from Toyota is a member of the Cove, even then Toyota tightly controls their info and data. The Covers can give you their input or suggestions but what matters is what your customer has requested and specified.
My two cents...and check out the Cove for similar posts...pretty certain this or similar questions have been asked.
Cheers, Optomist1
Berger
Hi Berger,
Cheers, Optomist1
Thank you. I will eventually contact SQE. I am just starting this job only 5 days. My previous company where I worked with, doesn't work in Toyota. I am now hand off this Toyota project from the previous QA here, and just need as much as information before going to speak with the SQE at least I am doing my home work. I am kind of nervous and probably lack of confident to this newly job. However, I will put my 110% in to it.
Sebastian
Everything is in SQAM.
Just study or ask Toyota for training, when possible.
European suppliers have access to Toyota Portal.
Toyota engineers issue requests for preparation of documents, e.g MQS, SDS, PIS
You need to submit them and get approval.
Special characteristics are managed by PIS. Content may be decided by Toyota or by you, as supplier.
Dimensional results, capability analysis you submit using form Sample Data Sheet.
All PIS items have to be transferred into SDS.
If no checking fixtures listed in MQC (control plan), you don't need to prepare document.
Product, process approval is formalized through documents called Provisional Approval Form and Final Approval Form.
Boundary sample are used for aspect evaluated visually to clarify doubts or get approval for deviations if needed.
It is what I remember from past and don't expect radical changes, but of course current SQAM access and study is needed.
Toyota has transitioned everything to QIMS (portal) all PPAP tasks are now listed and supplier uploads documents to satisfy these tasks. The most important document is the Inspection Standard. They treat this as a live document and it is to be updated same as PFMEA and MQC. If there are any deltas (Regulation items) on print, then you will need test data and Toyota form to submit results. Have your IT person get you set up on the portal and access to QIMS. THe SQAM is really just an outline but does not explain how to get to Part Approval, and the QE's are inconsistent on which documents they request. Good Luck
Berger
Thank you Felony. This help a lot :)
M APQP & PPAP - Does Toyota follow the APQP and PPAP process? Customer and Company Specific Requirements 5
S Toyota PPAP Information Misc. Quality Assurance and Business Systems Related Topics 3
R Does anyone have the list of Toyota PPAP requirements? APQP and PPAP 6
Q Honda, Toyota, Tesla CSR Matrix IATF 16949 - Automotive Quality Systems Standard 3
E Where can i get latest toyota and honda Supplier Quality Assurance Manual (SQAM) Customer and Company Specific Requirements 3
S Searching for TOYOTA Floor Management Development System (FMDS) board Customer and Company Specific Requirements 3
B Does Toyota utilize IATF 16949? IATF 16949 - Automotive Quality Systems Standard 4
L Toyota doesn’t use Six Sigma Six Sigma 1
C A couple CSR (Customer Specific Requirements) questions... Esp. Ford & Toyota Customer and Company Specific Requirements 5
D TS16949 Annex A versus Toyota MQC's IATF 16949 - Automotive Quality Systems Standard 14
Stijloor Toyota recalls more than 6 million vehicles. World News 5
L Christmas Toyota Accelerator Problem Settlement for the New Year! World News 9
P What is the last revision of Toyota SQAM (Supplier Quality Assurance Manual)? Customer and Company Specific Requirements 3
B Toyota FMDS (Floor Management Developmental System) Manufacturing and Related Processes 7
J New Toyota Supplier Quality Manual is on the Toyota Web Site Customer and Company Specific Requirements 1
L Rise and fall of Toyota - sourcing information for a presentation IATF 16949 - Automotive Quality Systems Standard 7
F Toyota A3 Practical Problem Solving (PPS) Document Needed Nonconformance and Corrective Action 1
Stijloor Toyota to extend development time to ensure quality World News 0
Stijloor Toyota drags down new-vehicle quality average World News 9
Stijloor Toyota Supplier Quality Assurance Manual (SQAM) is revised - April 2010 Customer and Company Specific Requirements 4
Marc Criminal probe launched into Toyota's safety problems World News 25
Marc What are Toyota's idled U.S. workers doing? World News 4
L Toyota Recall - What caused the issue with the accelerator? Quality Tools, Improvement and Analysis 53
Marc Toyota Halts U.S. Sales of 8 Recalled Models World News 16
A Toyota will recall 3.8 million vehicles in the United States World News 0
Stijloor Toyota SQAM Issue 4K, August, 2009 Now Available. Supplier Quality Assurance and other Supplier Issues 2
1 TS16949 vs. TPS (Toyota Production System) - Explaining the differences IATF 16949 - Automotive Quality Systems Standard 12
J Toyota's quality planning and quality management system documents Document Control Systems, Procedures, Forms and Templates 5
bobdoering Survey:Toyota loses luster with suppliers-Ford has made strides in supplier relations World News 7
Stijloor How Toyota fell so spectacularly World News 0
Marc Toyota Cuts Production Goal to 7-Year Low World News 1
bobdoering Toyota forecasts $8.6B loss, says 1 million sales will vanish World News 2
A Toyota may ask for $2 billion in loans World News 0
A Toyota cost-cutting program World News 1
bobdoering Toyota Expects Losses To Triple World News 6
A Toyota to Recall More Than 1.35 Million Cars World News 0
Marc Car Slump Jolts Toyota, Halting 70 Years of Gain World News 3
bobdoering Isuzu, Toyota Put Clean Diesel Engine Project On Hold. World News 1
bobdoering Toyota halts U.S. Prius project World News 0
Stijloor Stung Toyota cuts production deeper in N.A. World News 17
Q Searching for TOYOTA product development system (Toyota Production System) Customer and Company Specific Requirements 9
Sidney Vianna Toyota's winglet - leaner version of the Segway Coffee Break and Water Cooler Discussions 0
B Toyota supplier portal? Customer and Company Specific Requirements 3
D Production Process in Ceramics - Toyota Production System Process Maps, Process Mapping and Turtle Diagrams 3
Stijloor Toyota eyes new batteries, engines. World News 2
Stijloor Toyota ousts Ford as No. 2 US automaker World News 3
M Toyota Supplier "Pulse Rate" Evaluation - Is this document part of the Toyota SQAM? Customer and Company Specific Requirements 4
A Toyota Weld Specification TSH5603G needed Customer and Company Specific Requirements 6
N Why has Toyota won Market Share from General Motors? Misc. Quality Assurance and Business Systems Related Topics 12
Stijloor Toyota is Slipping, Consumer Reports Says Coffee Break and Water Cooler Discussions 12
