Definition TPM (Total Productive Maintenance) - What is TPM?
RoxaneB
#21
Equipment Improvement Program (EIP)
We are well on our way to implementing an Equipment Improvement Program (EIP) at our location. Slowly, we are developing "points of inspection" for each piece of equipment and machines. These are areas for the operators to routinely clean and inspect and grease, as necessary.
The Key Equipment Improvement Program (KEIP) then leaves the bigger maintenance jobs available for our maintenance people to do (rather than contract out).
The EIP was implemented concurrently with our 5S program as they complement each other.
In our South American locations, the EIP is called Autonomous Maintenace. We have be trained on the seven steps of a successful EIP - probably a level 3 for us right now, almost ready to go to level 4.
The EIP will be part of how we achieve Integrated Maintenance. This is an improvement process whereby Education/Training, Planned Maintenance, Autonomous Maintenance and Data Management/Analysis are combined to improve the overall state of equipment/process and employee morale.
RoxaneB
#23
Marc said:
Sounds like TPM by another name.
I kinda figured that, but the folks down in South America want it to be their system, so we call it by their name...then, because of the union environment we're in, changed it so that no one got overly upset.....a rose by any other name, I guess.
Swanee
#24
Marc,
I was recently in a TPM facility and was completely blown away. It was the Nissan Dechard Engine Plant. The Tool Crib/Rework Manager gave me a tour of the facility. They are getting something rediculus like 96% OEE, with scheduled downtime! They did a lot of things to notice worn out machine parts like you've mentioned above and the associates were mostly responsible for their own machines. I say mostly because when they had a problem machine everyone goes out to look at it. EVERYONE! Then they decide how to quickly repair the problem. Once it can be quickly brought back to working order they try different ideas to eliminate the problem. After taking the tour with my mouth wide open the manager really threw me for a loop. With a smile he said, "You know...you didn't see a machine today that is newer than twenty years."
Proper TPM is truely a sight to behold.
The company that I work for doesn't have "turn key" machines that look that clean or run that well out of the box. I would be suprised if we achive 60% OEE on what we consider a good running machine.
We have a so called TPM program, but it is basically an excuse to let machines run longer before the "scheduled maintenance".
#25
Another example
At a nameless auto manufacturer:
Every 15-20 minutes, associates spent 5 minutes climbing into the automated welding lines (2 lines/128 robots each line) and filing the welding tips back to 8mm with a hand file. (Cycle time produced ~1 car per minute).
This was followed by 3-5 minutes of chaos every 3rd or 4th stop. Current density is defined by the amount of current passed through the area of the weld tip. Too high, the weld "blows out". Or rough cut the tip and it sticks to the part, pulling the tip, spraying water everywhere, machine shutdown, new tip, etc. (this will be important in a minute).
Said mfg. spent over $2 million US on the following:
Automatic tip "dresser" (installed) for all 256 robots.
Additional robot movement program to find the dresser.
New weld timer with step-up (programmable) current for 256 robots.
New programming for 32 different Programmable Logic Controllers for the robots (count the cycles, step up the current every 5 cycles to adjust for tips flattening out as they wear, every 15 cycles make the robots clean their tips, reset the weld current back to the beginning).
Testing each system as it was installed for safety/performance/interference/etc.
Savings (conservatively based on an estimated downtime cost of $10K per minute)
15 minutes per hour x 8 hours per shift x 2 shifts per day x 250 days per year x that $10K per minute = $40 million (and that's only one line).
Results varied, but, worst case was an additional 80 welded bodies per shift per line per day. That's another 320 bodies a day! Without adding personnel, work time, or plant space.
Alan moss
#26
Re: What Is TPM (Total Productive Maintenance)?
hi my name is alan moss . i am just starting up atpm programe at my firm i woul be very greatful if any one can send me some templets of tpm schudles and counter measure shhet so i can get some ideas pleaes
many thanks in advance
alan moss
L
LumaraC
#27
I was curious when reading this topic and got more excited when everyone in this thread start sharing their working experience involving TPM.
It is fun and good to read it as I'm a beginner in the maintenance world.
I do involve with TPM but from my point of view; the TPM we carry out was just to fulfill audit requirement.
And I was surprised about how the Motorola handle their TPM very detail and involve everybody.
I do sometimes ask my self, do we need to be very detail about TPM until we reach for every small parts
(because our TPM only touch the big part/the visible part that can be see from outside)
Hopefully this thread will be going on by people sharing their experience in their working field.
Looking forward to learn more. :)
Marc
#28
B Total Productive Maintenance Templates to Drive TPM Forward Lean in Manufacturing and Service Industries 1
N Total Productive Maintenance (TPM) Portuguese Definitions and Terms Quality Tools, Improvement and Analysis 4
R TPM (Total Productive Maintenance) Reference Books Suggestions Book, Video, Blog and Web Site Reviews and Recommendations 3
M Top Three Reasons why TPM (Total Productive Maintenance) Initiatives Fail Manufacturing and Related Processes 39
C TPM (Total Productive Maintenance) Assessment Checklist wanted Quality Tools, Improvement and Analysis 2
S TPM (Total Productive Maintenance) Implementation Handbook Quality Tools, Improvement and Analysis 10
E Wall TPM (Total Productive Manufacturing) - Where to Start? Preventive Action and Continuous Improvement 1
D Total Productive Maintenance (TPM) - What is a facilities managers role? Preventive Action and Continuous Improvement 7
N What is TPM (Total Productive Manufacturing) all about? Preventive Action and Continuous Improvement 1
M Total Productive Maintenance (TPM) Shortcomings Preventive Action and Continuous Improvement 1
V Definition TPM (Total Productive Maintenance) vs. TQM (Total Quality Management) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 18
L How to start with TPM (Total Preventative Maintenance) Quality Tools, Improvement and Analysis 13
J Methodology to Improve Productivity using SMED & TPM - Experts opinion about it. Manufacturing and Related Processes 4
somashekar Information sharing: Week 22, 2010 (TPM, OEE) The Reading Room 1
M Implementing Lean Office / Office TPM in a technical sales team Lean in Manufacturing and Service Industries 17
H TPM Game/Simulation/Exercise Lean in Manufacturing and Service Industries 3
M TPM Announcement Letter for TPM introduction in a organisation Lean in Manufacturing and Service Industries 3
M TPM Formats & Implementation Methodology Lean in Manufacturing and Service Industries 1
M TPM - Master plan for the Admin Pillar Lean in Manufacturing and Service Industries 1
M TPM Pillar of the Month and Employee of the Month Criteria Manufacturing and Related Processes 12
B TPM Training Game/Simulation? Lean in Manufacturing and Service Industries 1
L 5S, TPM, LEAN, TPR and SLIM - How to implement these concepts in process industry? Lean in Manufacturing and Service Industries 12
A TPM Template Sheets and Counter Measure Sheets - Robot Welding Systems Preventive Action and Continuous Improvement 1
S TPM increasing employee overtime costs - How to reduce costs? Quality Tools, Improvement and Analysis 6
P Is it necessary to undergo the ISO 9001 surveillance audit before going for TPM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
F TPM according JIPM (Japan Institute of Plant Maintenance) concepts - JIPM or JIPM-S Quality Tools, Improvement and Analysis 2
A Integration of Six Sigma & TPM - Please tell me how Six Sigma 5
S Is 5 (Five) S activity a part of TPM? Preventive Action and Continuous Improvement 2
A JIPM offers TPM Awards to plants for exemplary TPM achievements - Criteria? Preventive Action and Continuous Improvement 4
M Approaches to Training in a TPM Company Preventive Action and Continuous Improvement 2
M How can I start initial TPM training? Preventive Action and Continuous Improvement 5
N How hard is it to implement TPM the second time around? Preventive Action and Continuous Improvement 3
K I'm looking for a good TPM Focused Site Preventive Action and Continuous Improvement 1
P Being strongly encouraged to put TPM in my plant by my customer Preventive Action and Continuous Improvement 4
M How is TPM related to Software Engineering vs. People and Machinery? Preventive Action and Continuous Improvement 5
J TPM and FORD's Lean Manufacturing Deployment training course same as Toyota's Lean in Manufacturing and Service Industries 4
B Total Productive Maintenance - Company Transport IATF 16949 - Automotive Quality Systems Standard 2
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
J Implementation of Total Quality Management/Starting a Quality Department Reliability Analysis - Predictions, Testing and Standards 9
K IATF16949 8.5.1.5 Total Productive Maintenance IATF 16949 - Automotive Quality Systems Standard 9
B IATF 16949 Section 8.5.1.5 (Total Productive Maintenance) IATF 16949 - Automotive Quality Systems Standard 19
P Total Variation in Data - Overall Importance of the Principal Components Reliability Analysis - Predictions, Testing and Standards 1
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J One third of the total audit days on manufacturing (TS 16949) General Auditing Discussions 2
M Total Productive Maintenance vs. Lean, Six sigma, Business Process Reengineering, etc Quality Tools, Improvement and Analysis 9
F What is the scope for "Total Numbers of Employees on site" per ISO/TS 16949 ? IATF 16949 - Automotive Quality Systems Standard 4
Marc Total Lunar Eclipse Visible in North America - 15 April 2014 Coffee Break and Water Cooler Discussions 4
K Can I use ANSI/AQL for the Total Number of Containers for the entire Lot? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
I Supplier Selection based on Total Cost question Supplier Quality Assurance and other Supplier Issues 4
B Total Resolution of an Measurement Instrument Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
