TQPC (Total Quality Process Control) for Injection Molding
Hi All,
Just quick question - have you ever read or reviewed 'Total quality process control for injection molding' book written by M. Joseph Gordon Jr? Is it a good point for make a checklist if our quality approach is well ordered and to find holes which is 'what we can not forget about'?
:read:
Have a good day for all!!
Stijloor
Re: TQCP (Total Quality Process Control) for injection molding
Hi All,
:read:
Any injection molding experts want to comment?
Thank you!!
Stijloor.
Hello again,
I suppose there will be no many people interested in this book. But in this one I have found many issues concerning not only molding process but especially quality management issues.
Is there anyone who can help me to understanding one quotation:
'Quality managers will audit the configuration management system (CMS) section for each department to ensure their employees are following procedures, and the documents and records of the operations are completed and filed in the system.'
What does CMS means for YOU? What is this? Can I compare CMS to SAP or different intagrated systems? This is the same rule but called different?
Thank You in advance,
Abak
JaxQC
No I have not read that particular book but in a previous life used Layered Audits to answer the following procedures etc part. Supervisors audit their area per shift, Quality once a day, Mgrs random area once a week, Top Mgt random area once a month. The items on the list varied and overlapped to a degree between levels. You still had metrics that covered all areas (FTQ-First Time Quality, Customer complaints (formal/informal), scrap type, downtime). The findings and repeat issues were reviewed once a week. The list had it’s core check items but also changed as events required. Specifics checks added after change implementation, complaint, finding etc which was later dropped as proven effective.
Within a 6 month period we dropped issues down to almost nil (0.24 ppm) and internal items (scrap, FTQ, and repeat findings) were the best ever. It was a lot of work at first doing look across and finding the dirt but once they were wiped out, maintaining it after that point was a breeze and even allowed time for pro-active items.
Start at the Process Flow and look at the scrap points (which should be identified). You should have controls in place to address where you expect to have scrap. When you have scrap at a point not expected it should be more worrisome since you are not planning for it there and most likely do not have controls in place at that spot (molded in flash, at asmy, undercure at molding, short shots without a missing insert somewhere in the heat).
I can’t remember the last time I saw a Customer return that truly was a “one of a kind” or “never seen before”. It’s was always something that was noticed, not acted properly upon, and eventually one slipped out. Operator: “Yea I’ve seen that a couple times before but we didn’t mention it since we thought we got them all”. Sound familiar?
B Total Productive Maintenance - Company Transport IATF 16949 - Automotive Quality Systems Standard 2
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
J Implementation of Total Quality Management/Starting a Quality Department Reliability Analysis - Predictions, Testing and Standards 9
K IATF16949 8.5.1.5 Total Productive Maintenance IATF 16949 - Automotive Quality Systems Standard 9
B IATF 16949 Section 8.5.1.5 (Total Productive Maintenance) IATF 16949 - Automotive Quality Systems Standard 19
P Total Variation in Data - Overall Importance of the Principal Components Reliability Analysis - Predictions, Testing and Standards 1
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J One third of the total audit days on manufacturing (TS 16949) General Auditing Discussions 2
M Total Productive Maintenance vs. Lean, Six sigma, Business Process Reengineering, etc Quality Tools, Improvement and Analysis 9
F What is the scope for "Total Numbers of Employees on site" per ISO/TS 16949 ? IATF 16949 - Automotive Quality Systems Standard 4
Marc Total Lunar Eclipse Visible in North America - 15 April 2014 Coffee Break and Water Cooler Discussions 4
K Can I use ANSI/AQL for the Total Number of Containers for the entire Lot? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
I Supplier Selection based on Total Cost question Supplier Quality Assurance and other Supplier Issues 4
B Total Resolution of an Measurement Instrument Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Pls hlep me understand the "Total Anaerobic Plate Count" Food Safety - ISO 22000, HACCP (21 CFR 120) 1
G How can Total Quality help a company or business compete in the world market? Preventive Action and Continuous Improvement 2
M How many documents total do you currently have? Document Control Systems, Procedures, Forms and Templates 6
5 Reasonable GRR result for a 0-1" micrometer with a total tolerance of .002" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
C A total newbie to AS 9101 needs general help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
B Total Productive Maintenance Templates to Drive TPM Forward Lean in Manufacturing and Service Industries 1
N Total Productive Maintenance (TPM) Portuguese Definitions and Terms Quality Tools, Improvement and Analysis 4
V Differences between Business Process Reengineering (BPR) and Total Quality Management Quality Manager and Management Related Issues 3
Z KPI Formula Issue - "Change Requests Managed" = Changed/Total ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
optomist1 Circular Runout vs. Total Runout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S Ppk & Cpk - Within Subgroup Variation is always smaller than Total Variation Capability, Accuracy and Stability - Processes, Machines, etc. 18
optomist1 Circular or Total Runout Gears and Splines? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Q Inspecting Total Runout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
P Uncertainty Measurement for Colour, Odour, Taste, Turbidity, Total Suspended Solids Calibration Frequency (Interval) 2
A %Total Variation & %Tolerance - Differences in Gage R&R Forms and Templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Determining the Total Sample Size using AQL - AQL Lot Quantity question AQL - Acceptable Quality Level 8
D TQM (Total Quality Management) Diagram Software Quality Assurance and Compliance Software Tools and Solutions 4
R Total Quality Management (TQM) in the Aerospace Industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
C ASQ Quality Management Journal Vol. 17 Total Quality Management (TQM) Comments Wanted Book, Video, Blog and Web Site Reviews and Recommendations 8
N ISO 9001 and the HR Function - Developing a Total Quality Management System for HR ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
K Where to obtain General Concepts of Total Organic Carbon (TOC) testing information? US Food and Drug Administration (FDA) 2
R Total Tolerance Method vs. Total Variation Method - Measurement System Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Mojonnier method (determining fat and total solids) validation General Measurement Device and Calibration Topics 1
K Quality Assurance Clinical Research Auditor - Masters in Total Quality Management Career and Occupation Discussions 3
R TPM (Total Productive Maintenance) Reference Books Suggestions Book, Video, Blog and Web Site Reviews and Recommendations 3
M Top Three Reasons why TPM (Total Productive Maintenance) Initiatives Fail Manufacturing and Related Processes 39
N Journey towards total quality and Optimal results Misc. Quality Assurance and Business Systems Related Topics 4
L Total Quality Management System Quality Manager and Management Related Issues 3
M Total Variation Formula - Can someone provide a source for this formula Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
bobdoering Total Variance Equation and process capability Imported Legacy Blogs 4
A How do I set up a PPM with Total pcs shipped vs. Total Scrap for the month Statistical Analysis Tools, Techniques and SPC 10
T Total Organic Carbon (TOC) testing - USP requirements US Food and Drug Administration (FDA) 4
E Variable Data - Total Percent Nonconforming from Different Nonconformances Quality Tools, Improvement and Analysis 4
R Sampling - Total probability of accepting bad lot - Producer's risk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Total Productive Maintenance Database? Document Control Systems, Procedures, Forms and Templates 1
S Total Quality Managememt Video for sharing Book, Video, Blog and Web Site Reviews and Recommendations 0
