Traceability after changing the machine
hopech
I need to know what is the traceability required after changing the machine (a new one) of a process for an automotive part and changing the batch of raw material
in other words when i have to redo SPC , MSA , the PFMEA the control plan etc.
thank you for your clarifiations
John C. Abnet
Teacher, sensei, kennari
Good day @hopech ;
Allow me to ask you some questions...
- What's the risk?
* If it's a new machine, then why wouldn't you want to verify the statistical capabilities of that new machine in regards to product conformance? Wouldn't you want to know if the new machine produces "better", or same, or "worse" product?
* If it's a new machine, and the process steps, controls (and, therefore, risks), are the same, then why would you redo the PFMEA and control plans?
* Assuming it is a production machine we are speaking of, does the new machine verify (i.e. "measure" product?) . If not, then why would your perform an additional MSA ?
* Does your customer have requirements in their contract/supplier handbook, etc..., specific to machine change?
Determine what can be impacted. That will help you determine what is at risk. Then act accordingly.
Hope this helps.
Be well.
hopech
Hello
Thank you So Much for replying
Your analysis is logic but im asking about exhaustive requirements according to iatf 16949 in other words im afraid of forgetting one of these parameters
SPC must be done when changing one of the 5 M ??
MSA must be done when changing measure method operators or part specifications
John C. Abnet
Nope. No such specifics dictated by IATF 16949. IATF promotes risked based thinking (RBT) and fortunately is not "too" prescriptive. I defer back to my original response.
Hope this helps.
Be well.
hopech
Okay
Thank you
But iatf 16949 does mention when to do a reaction plan in the Control plan
So based on your thinking i must do a cm cmk analysis due to machine change and spc analysis due to machine change and raw material batch change
If i Will change the process Flow chart i must change the pfmea and the Control plan to manage additionnal risks
MSA is the same analysis because the same Control devices are used same product and same Control staff
Thank you for your help
John C. Abnet
Okay
Thank you
So based on your thinking i must do a cm cmk analysis and spc analysis due to machine changing
If i Will change thé process Flow chart i must change thé pfmea and the Control plan to manage risks
* If the process flow changes (apparently the "new" machine is more than simply replacing a previous machine?), then I must assume the PFMEA and Control Plan will need addressed.
* Based on what you stated, then no MSA would be needed.
* I/we are unable to tell you/your organization exactly what statistical process performance analysis is needed. But yes, I would certainly imagine you/your organization would indeed wish to know that statistical performance.
You are most welcome. Hope this all helps.
Be well.
Johnnymo62
Haste Makes Waste
Are you submitting a new PPAP to the customer for the machine (process) and material (design) changes? This is usually a requirement for automotive. The PPAP should cover all of your requirements.
J Stock Traceability Methods, where to start? Manufacturing and Related Processes 0
B ASTM, Steel HEat traceability and mixing at distributors/reprocessors Various Other Specifications, Standards, and related Requirements 0
C IVD Metrological traceability without a reference measurement procedure General Measurement Device and Calibration Topics 11
A Traceability unequal lots/batches delivery production IATF 16949 - Automotive Quality Systems Standard 8
A Traceability label ISO 13485:2016 - Medical Device Quality Management Systems 7
T Design Traceability - Labelling / Instructions for Use ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
R DHR question: Traceability of components ISO 13485:2016 - Medical Device Quality Management Systems 2
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Traceability of component parts - Bolts, screws and washers ISO 13485:2016 - Medical Device Quality Management Systems 3
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Non conformance product identification and traceability 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
B Traceability of Thermoelement Batches ISO 17025 related Discussions 7
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
shimonv Design input/output traceability for mechanical parts ISO 13485:2016 - Medical Device Quality Management Systems 31
K Identification and Traceability with an ERP system - Barcode Labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
N FDA Traceability Requirements - Component lots ISO 13485:2016 - Medical Device Quality Management Systems 2
Stefan Mundt ISO 9001:2015 - 8.5.2 Identification and Traceability Manufacturing and Related Processes 14
S How to maintain a design traceability matrix ISO 13485:2016 - Medical Device Quality Management Systems 2
N Requirements for the identification and traceability of demo product for sales force US Food and Drug Administration (FDA) 1
MrTetris Traceability in Medical Sofware Development Process IEC 62304 - Medical Device Software Life Cycle Processes 3
M Medical Device Traceability ISO 13485:2016 - Medical Device Quality Management Systems 9
G Where to list chain of traceability? ISO 17025 related Discussions 6
A AS5553B Counterfeit Prevention - Traceability requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T In house Calibration? Measurement equipment traceability requirements - ISO9001 General Measurement Device and Calibration Topics 12
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Medical Device Traceability Matrix - Examples EU Medical Device Regulations 8
DeeDeeM IATF16949, clause 8.5.2.1 Identification and traceability-supplemental IATF 16949 - Automotive Quality Systems Standard 1
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
D IATF 16949 - 8.5.2.1 Traceability Plan - Does anyone have an example? IATF 16949 - Automotive Quality Systems Standard 4
A UDI - Traceability of Products Other US Medical Device Regulations 1
B AS9100 Rev D - Traceability of Consumables AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Customer Identification and Traceability in Manufacturing Plans Manufacturing and Related Processes 5
S Traceability and the initiation of GMP Activities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
N Calibration Traceability - Fluke 753 dpc with thermocouple Calibrated by Fluke ISO 17025 related Discussions 4
T Policy or Good Guidance for a Traceability Decision Tree (Serial and Batch Numbers) Misc. Quality Assurance and Business Systems Related Topics 4
J How to understand IATF 16949 Clause 8.5.2.1 - Traceability IATF 16949 - Automotive Quality Systems Standard 5
A Aluminum Die Casting Product Traceability Manufacturing and Related Processes 10
G Traceability - Checklist from NIST General Measurement Device and Calibration Topics 4
Raffy ISO 13485 NIST Traceability requirements for calibration of test equipment ISO 13485:2016 - Medical Device Quality Management Systems 3
G Traceability of laser based x-y measuring machine General Measurement Device and Calibration Topics 5
A Power Traceability certificate for values for voltage, current and phase General Measurement Device and Calibration Topics 1
Q Allowed no manuals, technical instructions traceability in products ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Is NIST traceability required if a Refractometer calibration is done in-house? Calibration Frequency (Interval) 6
