Traceability and the initiation of GMP Activities
sbrowning
Hello everyone,
I think this is a basic question, but my QMS knowledge is still growing so I am not confident I have it correct. I work for a small medical device manufacturer that is establishing their QMS in preparation for their first medical device (small and simple to start). We are working with QSR consultants for establishing the system, but I'm doing much of the legwork writing of procedures, etc.
Some time ago, my employer purchased custom cut Tyvek seals for our thermoformed trays that are ~1 inch to big, which they would like to trim to fit our custom trays (edit to add, with a paper trimmer, not scissors). I've worked in GLP labs before, and I can write procedures, inspection tests, and validation for this (along with associated records for the equipments, maintenance, etc). However, I am not sure this is sufficient--I don't have any experience in a GMP environment. It seems that the thermoformed trays are made to a specification, and we will receive them with a DoC to that spec, but are not GMP. Can we trim the Tyvek seals ourselves?
Thank you for all the advice.
yodon
Re: When does GMP start (traceable material vs prep manufacturing)?
There are few things going on here.
First, traceability is required only to the extent necessitated by risk. If that material gets out in the field, is there any risk that it would cause harm or fail and need to be recalled?
Second, GMP starting is really when you start any manufacturing activities (arguably when you accept a contract but that's probably cutting too fine for this discussion).
Finally, what's the risk of trimming the seals yourselves? Will that elevate the potential or likelihood of hazards / hazardous situations? (Guessing not). Yes, you should have procedures and all that as you indicated to properly support GMP. I'm guessing the output of this operation can be 100% verified so I doubt validation would be required.
Does that help?
Ronen E
Problem Solver
Moderator
Are these sterile devices? What's the role of the trays and lids?
sbrowning
Re: Question on Traceability and the initiation of GMP Activities?
Yodon and Ronen, thank you for your replies. Yes, the trays will be EtO sterilized with a single-use disposable medical device inside, although the medical device has not yet been manufactured.
The seals have a 0.5" lip on the tray for heat-sealing, and one identifiable risk is that an improperly sized Tyvek will not seal sufficiently to maintain sterility. The trimmed Tyvek will undergo 100% inspection. The device in tray still has to undergo the EtO sterilization validation, and the trays will undergo burst pressure testing, distribution testing, and aging, and other tests as expected. So although I believe the risk of trimming the seals ourselves is extremely low, the sealed trays will be tested afterwards as well.
"GMP starting is really when you start any manufacturing activities." Isn't trimming the Tyvek ourselves a manufacturing activity? We are not a CMO; we are the manufacturer that will be named on our 510(k) submission. However, we will be using a CMO assembler for the assembly of the device and building the tray, which then will be shipped to the EtO sterilizer.
Ronen E
Problem Solver
Moderator
You should be validating the design and process you will be using in the long run. There is no point validating a provisional process because you will have to revalidate when you later (soon?) introduce another.
GMP (actually, QSR) applies to all manufacturing steps that lead to finished devices that you'll be placing on the US market.
I wonder what your "QSR consultants" have to say about those issues.
sbrowning
Thanks, Ronen, I appreciate it. The consultants gave us copies of their procedures/forms/templates and it is up to us (me) to get it as much operational before manufacturing as possible. My employer will bring them back in to evaluate/audit the system before we seek regulatory approval.
Ronen E
Problem Solver
Moderator
Maybe getting a little :topic:, but FWIW:
That's a strange approach if you ask me, especially where the responsibility for the actual QMS development is handed to someone not well-versed in medical devices QM practices.
I don't consider handing out canned procedures and forms as "consultation". To add value the consultant would have to help you tailor them to your org and also stick around to support you during break-in and fine-tuning. I think I won't be taking a huge risk speculating that your bosses are trying to save money (consultants time), however you should be aware that this kind of arrangement is not good value for your $. As I already noted, the real value of canned procedures and forms is little and they usually require a lot of shaping before they fit a specific org, plus you could probably get some for free without losing much (or any) of the value; it's just a raw material. Second, I expect that when the consultants come back to audit they will find a lot of NCs and you'll lose much time (and maybe more money) trying to fix them. Perhaps you'll even need a second (hopefully not a third) audit before being ready for official regulatory clearance.
It's like they gave you a cube of wood and a screwdriver, and will be coming back with a gauge that has a round hole in it to see if it passes through. :(
A Lot number on label vs lot number on device - Traceability ISO 13485:2016 - Medical Device Quality Management Systems 0
M ISO 13485:2016 Identification & Traceability ISO 13485:2016 - Medical Device Quality Management Systems 4
P AS9100 and Raw Material Traceability AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Vicki Mayer GAGEpack and Subcontracted Calibrations Traceability Using GAGEpack Software 2
Y Software to Manage IEC 62304 Traceability Requirement IEC 62304 - Medical Device Software Life Cycle Processes 3
qualprod Traceability with no rules to control labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Stock Traceability Methods, where to start? Manufacturing and Related Processes 0
B ASTM, Steel HEat traceability and mixing at distributors/reprocessors Various Other Specifications, Standards, and related Requirements 0
C IVD Metrological traceability without a reference measurement procedure General Measurement Device and Calibration Topics 11
A Traceability unequal lots/batches delivery production IATF 16949 - Automotive Quality Systems Standard 8
H Traceability after changing the machine IATF 16949 - Automotive Quality Systems Standard 13
A Traceability label ISO 13485:2016 - Medical Device Quality Management Systems 7
T Design Traceability - Labelling / Instructions for Use ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
R DHR question: Traceability of components ISO 13485:2016 - Medical Device Quality Management Systems 2
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Traceability of component parts - Bolts, screws and washers ISO 13485:2016 - Medical Device Quality Management Systems 3
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Non conformance product identification and traceability 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
B Traceability of Thermoelement Batches ISO 17025 related Discussions 7
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
shimonv Design input/output traceability for mechanical parts ISO 13485:2016 - Medical Device Quality Management Systems 31
K Identification and Traceability with an ERP system - Barcode Labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
N FDA Traceability Requirements - Component lots ISO 13485:2016 - Medical Device Quality Management Systems 2
Stefan Mundt ISO 9001:2015 - 8.5.2 Identification and Traceability Manufacturing and Related Processes 14
S How to maintain a design traceability matrix ISO 13485:2016 - Medical Device Quality Management Systems 2
N Requirements for the identification and traceability of demo product for sales force US Food and Drug Administration (FDA) 1
MrTetris Traceability in Medical Sofware Development Process IEC 62304 - Medical Device Software Life Cycle Processes 3
M Medical Device Traceability ISO 13485:2016 - Medical Device Quality Management Systems 9
G Where to list chain of traceability? ISO 17025 related Discussions 6
A AS5553B Counterfeit Prevention - Traceability requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T In house Calibration? Measurement equipment traceability requirements - ISO9001 General Measurement Device and Calibration Topics 12
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Medical Device Traceability Matrix - Examples EU Medical Device Regulations 8
DeeDeeM IATF16949, clause 8.5.2.1 Identification and traceability-supplemental IATF 16949 - Automotive Quality Systems Standard 1
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
D IATF 16949 - 8.5.2.1 Traceability Plan - Does anyone have an example? IATF 16949 - Automotive Quality Systems Standard 4
A UDI - Traceability of Products Other US Medical Device Regulations 1
B AS9100 Rev D - Traceability of Consumables AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Customer Identification and Traceability in Manufacturing Plans Manufacturing and Related Processes 5
N Calibration Traceability - Fluke 753 dpc with thermocouple Calibrated by Fluke ISO 17025 related Discussions 4
T Policy or Good Guidance for a Traceability Decision Tree (Serial and Batch Numbers) Misc. Quality Assurance and Business Systems Related Topics 4
J How to understand IATF 16949 Clause 8.5.2.1 - Traceability IATF 16949 - Automotive Quality Systems Standard 5
A Aluminum Die Casting Product Traceability Manufacturing and Related Processes 10
