Traceability of Raw Materials - Requirements
Michel Saad
I am unable to find a clear requirement for the traceability of raw materials. Depending who I talk to, they have a different definition of what a raw material is. Some define direct raw materials (materials that stay on the part) vs indirect raw materials (sacrificial materials) saying traceability is only required on the direct materials. Others have defined critical raw materials as materials that have a significant effect on the final product whether they are sacrificial or not.
Can anyone tell me what the requirement is?
Martijn TVM
I must honestly say that I never heard of the term direct or indirect raw material. I think that all material influencing your product specifications should be traceable. I don't know what it is you make but I would say all material I could understand that you don't trace 3rd generation recycled material. But since I don't know for sure someone else might be able to help you better.
Tom W
Hello - I was looking in and found your topic. Where do you find the need to have traceability on raw materials in QS9000? Are you sure you haven't "laid a trap for yourself" in your quality documentation? I will try and help if I can understand your situation a little better.
The way I understand it, you set the level of inspection and traceability that you want to achieve. Do you understand this diffrently?
[This message has been edited by Tom W (edited 08 August 2000).]
Michel Saad
This is what the requirement states:
"The supplier shall establish and maintain documented procedures for identifying THE PRODUCT by suitable means from RECEIPT and during all stages of production, delivery and installation"
I guess we could argue about the definition of THE PRODUCT, but to me this includes raw materials.
Then, in the semiconductor supplement, under 4.8,it states:
"The supplier shall be able to trace product (INCOMING, inprocess and shipped materials and test data) forward and backward within 24 hours."
Again, when receipt and incoming are mentioned, I understand raw materials. I am confused?
Thanks for any help.
Michel
Tom W
Raw materials are included, but you set the level of traceability. It needs to be cost effective and practical methods. QS does not require companies to due these inspections a certain way. That is left up to the company. There are many raw materials that fall under the group of having to accept supplier data and insuring there test results meet your requirements. For example - Nitrogen purity for a heat treating company. You specify the purity and have to rely on the certifications with actual test data on it as a means of accepting, due to the nature of the process. Green sand in a steel founder is loaded into the sand system with out being touched by anyone. It is blown in from a truck. You are supplied a grap sample but that is what you have to rely on to check. Once the sand is mixed you can not seperate it. I think that if your company identifies how you want to maintain traceability and inspection verification on raw materials and you do what you saw you should be fine. Qs never stated that you have to do it in any certain way. Now if you have additional customer requirements for traceability based on you industry, then you have diffrent issues. If you are talking about Product ID and traceability of your raw materials then you again need to identify which ones you will maintain this on and establish ways of ding it. There is no set way because every comapny is diffrent.
Michel Saad
Just to make sure we understand each other, I am not talking about incoming inspection. I am talking about being able to trace which raw material lot number is associated with a specific prodcution run/lot number.
My original question is how do you identify the ones to keep traceability. This changes according who I talk to. I am looking for a clear definition, if there is one.
If there isn't and it is up to us, that means that we could trace none of the raw materials that go into making our products (not that we would do that). This seems hard to beleive.
Michel
Tom W
Typically I have seen companies trace raw materials that influence the following - Form / Fit / Function of the product. Defined as A B or C with A having direct impact on the product or process, B having some impact on product or process and C having none. Traceability would be on A and B. Any goods or SERVICES that have direct influence on the product or process would fall into A. B would be goods or SERVICES that indirectly influence or directly but the impact is minimal. C would be all others.
Martijn TVM
H Michel Isn't the most important question whether you can trace material lot numbers in finished goods. Because if you can without to much problems I would but if it is a big problem I would come up with the next best thing. But I do not know what works for you. Just remember that if traceability is a customer requirement you have to. If you work with a decent logistic IT system this functionality is usually allready there.
So just define howfar you want to be able to control traceability. And make sure that it's complying to the QS requirements.
First determine the level of traceability you want.
Remember "suitable means" is the key expression.
Raw material must be identified thru production until the point that it is no longer "raw material,i.e., it has been machined,molded,formed or otherwise made into an item that becomes another part number.
Depending on your type of raw material it is or can be identified by heat number,lot number or batch number in so many inches or feet. Refer to industry standards for identification. Mil std's are a good source for micro-electronics.
Other types of raw material can be tagged or placed in a container with the proper identification.
Accurate record keeping ties it all together.
P AS9100 and Raw Material Traceability AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P Medical Device Raw Material Traceability Requirements Other Medical Device and Orthopedic Related Topics 6
O Identifying Raw Material Part Numbers - Product Identification and Traceability ISO 13485:2016 - Medical Device Quality Management Systems 6
A In Process Traceability - Raw Material to Ship QS-9000 - American Automotive Manufacturers Standard 1
M ISO 13485:2016 Identification & Traceability ISO 13485:2016 - Medical Device Quality Management Systems 4
Vicki Mayer GAGEpack and Subcontracted Calibrations Traceability Using GAGEpack Software 2
Y Software to Manage IEC 62304 Traceability Requirement IEC 62304 - Medical Device Software Life Cycle Processes 3
qualprod Traceability with no rules to control labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Stock Traceability Methods, where to start? Manufacturing and Related Processes 0
B ASTM, Steel HEat traceability and mixing at distributors/reprocessors Various Other Specifications, Standards, and related Requirements 0
C IVD Metrological traceability without a reference measurement procedure General Measurement Device and Calibration Topics 11
A Traceability unequal lots/batches delivery production IATF 16949 - Automotive Quality Systems Standard 8
H Traceability after changing the machine IATF 16949 - Automotive Quality Systems Standard 13
A Traceability label ISO 13485:2016 - Medical Device Quality Management Systems 7
T Design Traceability - Labelling / Instructions for Use ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
R DHR question: Traceability of components ISO 13485:2016 - Medical Device Quality Management Systems 2
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Traceability of component parts - Bolts, screws and washers ISO 13485:2016 - Medical Device Quality Management Systems 3
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Non conformance product identification and traceability 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
B Traceability of Thermoelement Batches ISO 17025 related Discussions 7
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
shimonv Design input/output traceability for mechanical parts ISO 13485:2016 - Medical Device Quality Management Systems 31
K Identification and Traceability with an ERP system - Barcode Labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
N FDA Traceability Requirements - Component lots ISO 13485:2016 - Medical Device Quality Management Systems 2
Stefan Mundt ISO 9001:2015 - 8.5.2 Identification and Traceability Manufacturing and Related Processes 14
S How to maintain a design traceability matrix ISO 13485:2016 - Medical Device Quality Management Systems 2
N Requirements for the identification and traceability of demo product for sales force US Food and Drug Administration (FDA) 1
MrTetris Traceability in Medical Sofware Development Process IEC 62304 - Medical Device Software Life Cycle Processes 3
M Medical Device Traceability ISO 13485:2016 - Medical Device Quality Management Systems 9
G Where to list chain of traceability? ISO 17025 related Discussions 6
A AS5553B Counterfeit Prevention - Traceability requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T In house Calibration? Measurement equipment traceability requirements - ISO9001 General Measurement Device and Calibration Topics 12
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Medical Device Traceability Matrix - Examples EU Medical Device Regulations 8
DeeDeeM IATF16949, clause 8.5.2.1 Identification and traceability-supplemental IATF 16949 - Automotive Quality Systems Standard 1
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
D IATF 16949 - 8.5.2.1 Traceability Plan - Does anyone have an example? IATF 16949 - Automotive Quality Systems Standard 4
A UDI - Traceability of Products Other US Medical Device Regulations 1
B AS9100 Rev D - Traceability of Consumables AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Customer Identification and Traceability in Manufacturing Plans Manufacturing and Related Processes 5
S Traceability and the initiation of GMP Activities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
N Calibration Traceability - Fluke 753 dpc with thermocouple Calibrated by Fluke ISO 17025 related Discussions 4
