Traceability of Standards - Where can I send my standards to be calibrated?
V
Van_H
Im beginning with the project of certifying our Q.A. Lab on 17025, but i have a doubt, if i get the acreditation, where can i send my standards to be calibrated, do they have to be calibrated with the national Standard or can i just send it to another credited lab?
Any comments are welcome.
:thanx:
SteelMaiden
Re: Traceability of standards
Where you send them is partially up to you, but they will have to be calibrated using the appropriate specifications with traceability to NIST or other applicable standard.
Hopefully, I am using the correct language....Calibration is not my primary area of expertise. Just enough knowledge to be dangerous. There are several members here who are truly experts, I'm sure they will correct any misrepresentations I have made.
Boscoeee
Are you setting up a Metrology lab or a Quality Control Lab? Specifically are you setting up to perform your own calibrations?
V
Van_H
Its a Quality lab and im setting it up to perform my own calibrations
Boscoeee
That equate to a Metrology laboratory. I will have to defer to others that more qualified regarding the Standard you referenced. However, as a minimum your master standards have to be traceable to either NIST or other Recognized sources. May I ask why you are in sourcing this activity?
D.Scott
Welcome to the Cove.
The information you have been given is very good but do you realize that you don't need lab accreditation to calibrate your own equipment? You will need to have calibrations done by qualified employees and you will need traceability to NIST or equivalent but you would not necessarily need certification.
Dave
V
Van_H
:D Yeah i realize thet, but we want the accreditation to improve our current methods, and to offer our buyers an extra security of our products and methods. BTW We are already certified under ISO 9001:2000 so we already have a lot of documentation, tracking software and master standards with traceability to nationals, so basically we're only missing the accreditation and certified technicians.
BradM
I too, am not a 17025 expert, but I will take a stab. You will need to send your standards to a competent lab for calibration. Whether you send them to a competent lab or a national standard will largely depend on the type of equipment, the availability of labs to perform that particular service, and your budget. NIST has a pretty long lead time, requiring multiple redundant standards. To answer your question, the level of scrutiny you choose in calibrating your standards will increase.
Look at it this way- it becomes a Supply Chain. You can spend all day taking care of your own shop, but if you don't exercise some level of control on the incoming raw material/product, you're spinning your wheels. Plus, if you use competent sources, they will provide uncertainty calculations that can be of assistance to you.
jfgunn
The answer to your question would depend upon the accrediting body you choose to use for your ISO 17025 accreditation. In general, you should choose an accreding body that is accepted worldwide. Based upon your profile, it would appear you are in a city in Mexico very close to the border of Texas.
Go to the following website: http://www.ilac.org/documents/mra_signatories.pdf
This lists a group of accrediting bodies that all recognize each other worldwide. There are 5 accrediting bodies in the US and 1 in Mexico on this list. First of all, you should contact several of them (if not all) to get information on obtaining accreditation and compare them before choosing one to use for accreditation.
The simple answer to your question is that you need to use a calibration laboratory that is accredited by one of the organizations on this list. Make sure that the calibration laboratory has the measurement you need on their scope of accreditation. For virtually every parameter, there are several (or many) labs that will be accredited to calibrate your standards. Each laboratory will have a different uncertainty for their calibration. You need to choose the lab whose uncertainty is sufficient for your needs.
Of course, you can also send your standards directly to the national measurement institute directly. In the US, this would be NIST. NIST has signed a mutual recognition agreement with countries around the world, so you could also send your standards directly to those national measurment institues. A list of these is at
http://www.bipm.org/en/cipm-mra/participation/signatories.html
Sending your standards directly to NIST (or similar) gets you a lower uncertainty on the calibration. Calibration by NIST is very time consuming (months) and extremely expensive. The lower uncertainty you get will be statistically insignificant for routine calibration work.
For example, if you send gage blocks to NIST, the uncertainty might be 1 microinch. If you send them to Starret, you might get 2 microinches. If you send them to any number of accredited labs, you would get between 4 and 8 microinches. When you use the gage blocks to calibrate a micrometer with 0.0001 inches, the uncertaty from that calibration is roughly 58 microinches regardless of where you sent the standard.
I hope this helps a little.
Hershal
Metrologist-Auditor
Van_H, I support what jfgunn stated. If in fact you are in Mexico, then your National Measurement Institute is CENAM, and that is where your traceability should route to if possible, and ultimately back to SI Units.
If you are in a different country than Mexico, then go to
http://www.bipm.org/en/cipm-mra/signatories.html
and find the National Measurement Institute for your country.
I also generally suggest not calibrating anything inside uless you have the demonstratable technical proficiency. I recommend finding an accredited calibration provider for your calibration needs.
Hope this helps.
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
R DHR question: Traceability of components ISO 13485:2016 - Medical Device Quality Management Systems 2
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Traceability of component parts - Bolts, screws and washers ISO 13485:2016 - Medical Device Quality Management Systems 3
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Non conformance product identification and traceability 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Traceability of Thermoelement Batches ISO 17025 related Discussions 7
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
shimonv Design input/output traceability for mechanical parts ISO 13485:2016 - Medical Device Quality Management Systems 13
K Identification and Traceability with an ERP system - Barcode Labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
N FDA Traceability Requirements - Component lots ISO 13485:2016 - Medical Device Quality Management Systems 2
Stefan Mundt ISO 9001:2015 - 8.5.2 Identification and Traceability Manufacturing and Related Processes 14
S How to maintain a design traceability matrix ISO 13485:2016 - Medical Device Quality Management Systems 2
N Requirements for the identification and traceability of demo product for sales force US Food and Drug Administration (FDA) 1
MrTetris Traceability in Medical Sofware Development Process IEC 62304 - Medical Device Software Life Cycle Processes 3
M Medical Device Traceability ISO 13485:2016 - Medical Device Quality Management Systems 9
G Where to list chain of traceability? ISO 17025 related Discussions 6
A AS5553B Counterfeit Prevention - Traceability requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T In house Calibration? Measurement equipment traceability requirements - ISO9001 General Measurement Device and Calibration Topics 12
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Medical Device Traceability Matrix - Examples EU Medical Device Regulations 8
DeeDeeM IATF16949, clause 8.5.2.1 Identification and traceability-supplemental IATF 16949 - Automotive Quality Systems Standard 1
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
D IATF 16949 - 8.5.2.1 Traceability Plan - Does anyone have an example? IATF 16949 - Automotive Quality Systems Standard 4
A UDI - Traceability of Products Other US Medical Device Regulations 1
B AS9100 Rev D - Traceability of Consumables AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Customer Identification and Traceability in Manufacturing Plans Manufacturing and Related Processes 5
S Traceability and the initiation of GMP Activities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
N Calibration Traceability - Fluke 753 dpc with thermocouple Calibrated by Fluke ISO 17025 related Discussions 4
T Policy or Good Guidance for a Traceability Decision Tree (Serial and Batch Numbers) Misc. Quality Assurance and Business Systems Related Topics 4
J How to understand IATF 16949 Clause 8.5.2.1 - Traceability IATF 16949 - Automotive Quality Systems Standard 5
A Aluminum Die Casting Product Traceability Manufacturing and Related Processes 10
G Traceability - Checklist from NIST General Measurement Device and Calibration Topics 4
Raffy ISO 13485 NIST Traceability requirements for calibration of test equipment ISO 13485:2016 - Medical Device Quality Management Systems 3
G Traceability of laser based x-y measuring machine General Measurement Device and Calibration Topics 5
A Power Traceability certificate for values for voltage, current and phase General Measurement Device and Calibration Topics 1
Q Allowed no manuals, technical instructions traceability in products ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Is NIST traceability required if a Refractometer calibration is done in-house? Calibration Frequency (Interval) 6
M Component Lot Number Traceability - Class I reusable and "resposable" Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 10
B What is the FDA guidance regarding selling replacement parts and traceability? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Individual part traceability - ink/paint sprayer? IATF 16949 - Automotive Quality Systems Standard 4
A Active Implantable Medical Devices - Legal Traceability Requirements ISO 13485:2016 - Medical Device Quality Management Systems 7
M Establishing traceability from calibrated glassware to non calibrated ones General Measurement Device and Calibration Topics 5
M Traceability of Tissue Samples US Food and Drug Administration (FDA) 1
