Traceability unequal lots/batches delivery production
andrei iuganu
I have a real situation that gives me headaches (maybe I interpret things differently): from production, a batch of 1000 pieces arrives in the packaging area. All 1000 pieces are in a cardboard box. When packing, take 100 pieces and put them in plastic bags. On this bag is put the label that for the lot uses all the code of the one that came from production (A1) only the quantity differs - 100 pieces. So the lot from production a1 has 1000 pieces the one from the packaging prepared for delivery has A1 but with 100 pieces, and in total there are 10 bags. From my point of view, I consider it wrong, I can't ensure traceability. Is this way of working correct?
Ninja
Looking for Reality
What is your company's definition of "one lot"? Why?
What do you consider wrong about the current process?
Why is this in an IATF16949 forum?
I can't imagine anyone helping with the limited information you've given.
Tagin
It seems correct to me unless there is a need for traceability in the actual packaging step for some reason. E.g.,
  • Of the 10 bags, 3 are bagged & packed by one person and 7 are bagged & packed by another person, and you want traceability to the person.
  • 6 of the bags ship that week, but 4 bags don't ship for 3 months, and you need traceability to the bag level for shelf life reasons
So, can you think of a situation where traceability to the bag level would be required or helpful for your product and customers?
malasuerte
Tagin' response is spot on brilliant! There is nothing wrong unless there are additional requirements for traceability to the smaller packaging.
Maybe this helps expound upon that logic - are every single one of those pieces individually marked with some sort of id#? Probably not, because you don't need traceability to the part level.
Need more information but on initial reading, it looks acceptable. When we use the term "traceability" it refers to identifying with a control number (lot, or batch of finished product and where appropriate components) through the different stages of manufacture, assembly and distribution. In your case, if you assembled 1000 pieces, you are just dispensing the product from that assembly process in boxes of 100 quantity each. So, in essence, the 100 pieces in each of the 10 boxes belong to the same parent, the lot#.
andrei iuganu
Thanks to everyone for the answer.
I am not against this way of working, only that when theoretically I receive a complaint from the customer I cannot trace back exact route until the production phase, because the 1000 pieces given as an example are produced in three shifts, by 3 different operators.
malasuerte
What you just stated could be the reason for doing traceability at the bag level.
What is the requirement? Is sounds like you are saying that any one of those shifts/operators could cause an error (99 instead of 100, bag not sealed, etc) and you need to be able to 'trace' back such issues.
If that is the case, then yes - you should have some additional identifier. Could be as simple as Lot # - Shift #.
andrei iuganu
The client's request is to send the pieces in bags of 100 pieces each. Nobody stops me from adding on the label the shift
Ninja
Looking for Reality
That is specifically why I asked this question...
In my company (4yrs ago), we defined "a lot" as "one tank, one cast, one caster, one day"...if any of those changed it was a new lot#.
If we wanted trace to shift level or operator level we would have redefined what "one lot" was.
That gives you all the traceability you seek.
M ISO 13485:2016 Identification & Traceability ISO 13485:2016 - Medical Device Quality Management Systems 4
P AS9100 and Raw Material Traceability AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Vicki Mayer GAGEpack and Subcontracted Calibrations Traceability Using GAGEpack Software 2
Y Software to Manage IEC 62304 Traceability Requirement IEC 62304 - Medical Device Software Life Cycle Processes 3
qualprod Traceability with no rules to control labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Stock Traceability Methods, where to start? Manufacturing and Related Processes 0
B ASTM, Steel HEat traceability and mixing at distributors/reprocessors Various Other Specifications, Standards, and related Requirements 0
C IVD Metrological traceability without a reference measurement procedure General Measurement Device and Calibration Topics 11
H Traceability after changing the machine IATF 16949 - Automotive Quality Systems Standard 13
A Traceability label ISO 13485:2016 - Medical Device Quality Management Systems 7
T Design Traceability - Labelling / Instructions for Use ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
R DHR question: Traceability of components ISO 13485:2016 - Medical Device Quality Management Systems 2
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Traceability of component parts - Bolts, screws and washers ISO 13485:2016 - Medical Device Quality Management Systems 3
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Non conformance product identification and traceability 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
B Traceability of Thermoelement Batches ISO 17025 related Discussions 7
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
shimonv Design input/output traceability for mechanical parts ISO 13485:2016 - Medical Device Quality Management Systems 31
K Identification and Traceability with an ERP system - Barcode Labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
N FDA Traceability Requirements - Component lots ISO 13485:2016 - Medical Device Quality Management Systems 2
Stefan Mundt ISO 9001:2015 - 8.5.2 Identification and Traceability Manufacturing and Related Processes 14
S How to maintain a design traceability matrix ISO 13485:2016 - Medical Device Quality Management Systems 2
N Requirements for the identification and traceability of demo product for sales force US Food and Drug Administration (FDA) 1
MrTetris Traceability in Medical Sofware Development Process IEC 62304 - Medical Device Software Life Cycle Processes 3
M Medical Device Traceability ISO 13485:2016 - Medical Device Quality Management Systems 9
G Where to list chain of traceability? ISO 17025 related Discussions 6
A AS5553B Counterfeit Prevention - Traceability requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T In house Calibration? Measurement equipment traceability requirements - ISO9001 General Measurement Device and Calibration Topics 12
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Medical Device Traceability Matrix - Examples EU Medical Device Regulations 8
DeeDeeM IATF16949, clause 8.5.2.1 Identification and traceability-supplemental IATF 16949 - Automotive Quality Systems Standard 1
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
D IATF 16949 - 8.5.2.1 Traceability Plan - Does anyone have an example? IATF 16949 - Automotive Quality Systems Standard 4
A UDI - Traceability of Products Other US Medical Device Regulations 1
B AS9100 Rev D - Traceability of Consumables AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Customer Identification and Traceability in Manufacturing Plans Manufacturing and Related Processes 5
S Traceability and the initiation of GMP Activities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
N Calibration Traceability - Fluke 753 dpc with thermocouple Calibrated by Fluke ISO 17025 related Discussions 4
T Policy or Good Guidance for a Traceability Decision Tree (Serial and Batch Numbers) Misc. Quality Assurance and Business Systems Related Topics 4
J How to understand IATF 16949 Clause 8.5.2.1 - Traceability IATF 16949 - Automotive Quality Systems Standard 5
A Aluminum Die Casting Product Traceability Manufacturing and Related Processes 10
G Traceability - Checklist from NIST General Measurement Device and Calibration Topics 4
