Tracing TS 16949 Requirements to AIAG Reference Manual during an Audit
Douglas E. Purdy
A question that I have been pondering for a while is how does one performing a TS Audit trace to an AIAG requirement? I recently went through a periodic audit by the registrar and a finding was documented to PPAP 3.1 as follows:
Requirement: The organization shall notify the customer of any planned changes to the design, process, or site.
Failure: The customer is not always being notified when changes to the process are made.
Now I do not have an issue with the finding, but how would I trace the finding from TS? Would it only be via the Customer Specific Requirements to get me to the PPAP reference manual? If so, then shouldn't that CSR have been stated by the auditor?
Just Wondering,
Doug
Duke Okes
Re: Tracing TS Requirements to AIAG Reference Manual during an Audit
TS 7.3.6.3 says "organization shall conform to a product and manufacturing process approval procedure recognized by the customer"
So if the customer required a PPAP, then the manual is the procedure. You could also trace it through the CSR, but it wouldn't add anything unless they used the CSR to validate that PPAP was required.
Douglas E. Purdy
I looked at 7.3.6.3, but that did not get me to the PPAP reference manual directly. Can an auditor assume the approval procedure recognized by the customer?
I guess the point that I am pondering is that in order to make a finding against an AIAG Reference Manual, an auditor would need to identify the customer requirement that leads to the AIAG Reference Manual - right? Since TS does not link itself to the reference manuals, then a TS auditor would have to link the AIAG Reference Manual requirements via the Customer Specific Requirements. Is this the proper way of identifying the nonconformance to an AIAG Reference Manual?
Still Wondering,
Doug
RickT
The auditor is not cerrect in tying the finding to the PPAP manual since it is an AIAG document and not a TS document.
The finding should have been tied to Clause 0.5 Scope,which states "This Technical Specification coupled with applicable customer specific requirements defines the fundamental quality system requirements for those subscribing to this document." That is also back-ed up clause 7.3.6.3.
I am assuming your customers are members of AIAG. hence require the use of the core tool manuals.
Each AIAG member refers in its customer specific requirements to the use of these manuals and to PPAP ion partucular.
To be correct, the suditor should have made that connection in the finding.
Douglas E. Purdy
I do not quite buy that the finding should be tied to clause 0.5 in that it is only part of the introductuction to the Technical Specification. I do think that it supports the basis that for a TS Audit to identify a requirement from a reference manual would have to be through the customer-specfic requirement.
Thanks,
Doug
I see a sort of nested finding, with the intitial reference to 7.3.6.3 as Duke suggests, and then a further reference to the CSR that establishes the specific 7.3.6.3 requirement. I don't think reference to either requirement exclusively is enough.
cheahga
Still Wondering,
Doug
Hi Doug,
I agreed with your statement on the basis "auditor can only referenced AIAG reference manual if the requirement is stated in your CSR and not other"...
If AIAG document can be used as the requirement to ISO/ TS certification, then AIAG should be the authorisation body for TS instead of IATF ...:bonk: or they are both the same....:biglaugh: That's why auditor is confusing.......:topic:
:cfingers:
RickT
Hi Doug and Cheagha,
I have no problem with your concern about tying to 0.5 except your comment that it is "only" part of the introduction. It in fact is the Goal of the TS, hence describes its intent and obective. Organizations and auditors surely should keep the 4 goals of 0.5 in mind when implementing and auditing a system that claims to meet the requirments of the Technical Specification.
(Sorry to appear on my soap-box, but i feel too many people overlook the basic premise of the TS).
IATF in the International Body that administers ISO/TS 16949 and AIAG represents the North American membership in the IATF.
Hope this helps.
RickT
antoine.dias
IMO the auditor should have mentioned 7.1.4 change control ( including both note 1 and 2.
Quote :
The organization shall have a process to control and react to changes that impact product realization. The effects of any change, including those changes caused by any supplier, shall be assessed, and verification and validation activities shall be defined, to ensure compliance with customer requirements. Changes shall be validated before implementation.
For proprietary designs, impact on form, fit and function (including performance and/or durability) shall be reviewed with the customer so that all effects can be properly evaluated.
When required by the customer, additional verification/identification requirements, such as those required for new product introduction, shall be met.
NOTE 1 Any product realization change affecting customer requirements requires notification to, and agreement from, the customer.
NOTE 2 The above requirement applies to product and manufacturing process changes.
Quote on "notes":paragraphs marked “NOTE” are for guidance in understanding or clarifying the associated requirement.Unquote
Best regards,
Antoine
Douglas E. Purdy
Hope this helps.
RickT
I do not have an issue with understanding the goal, but how can you write a nonconformance to the goal?
"This Technical Specification, coupled with applicable customer-specific requirements, defines the fundamental quality management system requirements for those subscribing to this document."?
When I stated that 0.5 is only part of the introduction I was trying to clarify that it is not a requirement. I believe the responder (don't have listing of responses below this window to reference - like usual) who identified the 0.5 clause was suggesting that the finding would be written to 0.5 along with 7.3.6.3. I simply do not agree that is the way to idenify the nonconformance to TS. I believe the goal indicates that you would have to write the nonconformance against the Customer-Specific Requirement.
Thanks,
Doug
D User Requirements Tracing - Verification and Validation Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
G Tagging and Tracing Nonconforming Products on the Production Line ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Traceability Matrix format for tracing user needs - Requirements, specifications, etc Food Safety - ISO 22000, HACCP (21 CFR 120) 11
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 0
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
H Remote product audits in Coivd-19 - IATF 16949 9.2.2.4 IATF 16949 - Automotive Quality Systems Standard 3
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Postpone IATF 16949 audit due to COVID-19 IATF 16949 - Automotive Quality Systems Standard 41
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
T Reaction Plan To Drive suppliers to IATF 16949 registration IATF 16949 - Automotive Quality Systems Standard 6
B IATF 16949 - Is a Deviation required for sample components in a prototype build? IATF 16949 - Automotive Quality Systems Standard 13
C IATF 16949 - Scope or not? IATF 16949 - Automotive Quality Systems Standard 2
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
B Go Beyond ISO 9001 WITH IATF 16949 (January 28) [Paid] Training - Internal, External, Online and Distance Learning 1
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
C Design and implementation of process audits as defined within IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
Q VDA 6.3 questions vs IATF 16949 clauses VDA Standards - Germany's Automotive Standards 0
N IATF 16949:2016 7.1.5.3.2 External Laboratory - How to approve the Testing Laboratory without accreditation scope IATF 16949 - Automotive Quality Systems Standard 2
M IATF 16949 (6.1.1 - Planning and Risk Analysis for a remote site) Process Maps, Process Mapping and Turtle Diagrams 5
D IATF 16949 FAQ 24 (8.4.2.2 Countries of Destination) - How is this actually being interpreted? IATF 16949 - Automotive Quality Systems Standard 3
