Training department ideas and development for automotive supplier
P
Plamena
Hello all,
I have started a new career in automotive industry as training leader for people on the assembly lines - manufacturing wiring harnesses. As for me, this is very new field I need guidance about the topic.
How do you think the training department should work? We have theoretical and practical areas, but seems that they are not enough useful to prepare good operators. How can I change them, to make them work better? How to motivate the training team, as they are old crew and I'm the new one?
What do you think for you the trainers should do - main tasks, responsibilities? Should it be involved in engineering changes and discussions?
Now theory and practice are separate by days. Do you think to mix them - for instance - theory and then at the same time immediate practice about the given theory? Now all the operators learn about all process in the beginning of the theory. Do you find that useful, or they can learn just about the process they are hired for?
Do you think it will be a good idea?
I will appreciate any books and discussions on the topic?
Thank you in advance for your time.
toniriazor
Hello
good luck in your new endeavors
1 - trainer should explain to assembly operators obviously how to do something and why to do it and the best possible way to do it. (correlates with next point)
2 - trainers should also say when a job is not possible to be done according work standard and speak with engineer for improvement proposals (not many trainers will do this as they don't tend to care)
3 - trainer should pick up tricky jobs and teach operators how to perform them. What is tricky job ? tricky job is the operation where most mistakes are expected and difficult tasks to do
4 - should be involved in engineering changes and discussions because its important to know what he/she will have to teach on the line and make a plan how to do it
5 - you cannot change behavior of old employees. Mission impossible.
6 - combining theory and practice one after another looks ok - but think if you have big groups of people how you will handle them ? how many trainers you have to take this tasks ?
7 - separation of operators for the process they are hired for is ok in my opinion - but again it comes down to how many people you have to work with new hired operators
hope that helps and other people share their thoughts and experience
Mikael
The new hype is Augmented Reality(AR) & Virtual reality(VR), whether you like it or not it will be the technical part of the future of training. There is no way you can hide. If you want links let me know how much you need and what kind.
Ask the "end customers"(/operators) for feedback what have worked and not, they usualy have a lot of complains, make a gemba walk or something like that. Do the same with the trainers separately, and you might find an interesting cap.
It have become popular to talk about micro and makro learning, not my call but it can work.
What about test and observation, and you need to think about having a support system and how that should work. This include catching experience and use it, FAQ for instance.
optomist1
A Sea of Statistics
Hi Plamena, welcome...especially in the automotive industry the wiring harness, although not the most expensive assy, is in the top 1-3 assy in terms of importance. Without a reliable robust wiring harness, the vehicle operation is compromised. So to your question...visual aides are key...as are destructive and non-destructive tests to validate an operation prior to producing harness/crimped components. Sounds as though you are looking for a training program template for wiring harnesses, I will look around...the training program & were appropriate certifications must be well documented, and maintained...
toniriazor
I think one of the key aspects is to get as you mentioned feedback from operators which were previously trained.
To be honest about the part with Augmented Reality(AR) & Virtual reality(VR) it's not very clear to me how exactly would contribute to the training program or to be a better trainer. Maybe you can give us more hints.
Thank you for the ideas, I had to change my profile. For me starting with the opinion of the operators about the training would work perfectly. Mikael I would love to know how Augmented Reality(AR) & Virtual reality(VR) can be useful at work?
Thank you one more time
Mikael
Well it can be individual from case to case, but perhaps this could be a start:
How virtual reality is redefining soft skills training
Also look at www.virtualspeech.com, or for meetings where you can share and discuss 3D models look at Spatial.io . There are a lot of others, so just examples, and I don't have any economic interest with these.
Almost everyday there are news within this field and there are like more than 80 XR hardware brands, and examples and cases in most areas rise regularly.
The most common well know brands for XR (AR & VR) are:
AR - Hololens 2 (Microsoft, stand alone)
AR - Magic Leap (semi stand alone)
VR/AR (passthrough) - Varjo , high end high price. You a need a powerfull pc to run it.
AR light - Nreal (use your phone to run it)
AR light - Think reality A3
BTW AR light is popular for audit like purpose, because they are relative cheap, but still have cameras to share your view for collaboration in a production enviroment on a distance.
VR Stand alone (no wires or optional use a link cable) - Oculus Quest 2 (owned by Facebook)
VR - HP Reverb2 - Have good specs and reviews from gamers. The omni version is suited for research purpose since it have sensor that than measure a lot of things.
Traditional VR - HTC vive they are getting old specs wise, but good for business.
VR Pimax - more known for gaming with large field of view(fov) and refresh rate.
Valve index - more known for gaming, popular, high refresh rate.
Could go on but it should be enough to get started, most tech are working on either a VR, AR or hybrid.
New tech on mind control are on popping up, yes control your device handsfree with just your though, it is not science fiction, it is coming, though it is at the early stages and slow. Could be useful in production environments.
I don't know where in the world you are, but for the technical support I suggest that you contact a traditional 3D studios, often they make VR solutions.
There is the gaming approach (fun/not work) and business/serious use. For gaming/private use you might focus on specs of hardware and make a decision, though for business it is more important that you have a studio that support your field and the hardware. For instance the price for Occulus Quest 2 private and business version are very different, and there is a good reason for that.
If you need help to find studios then PM me.
Keep asking :)
A Does Training come under HR department? Training - Internal, External, Online and Distance Learning 29
Ajit Basrur Setting up a New Training Department Training - Internal, External, Online and Distance Learning 7
Q Safety Training Program Training - Internal, External, Online and Distance Learning 0
R ISO 17025 Lead Assessor Training ISO 17025 related Discussions 0
A New to QMS and regulatory... advice on training/certification? ISO 13485:2016 - Medical Device Quality Management Systems 1
T Counterfeit parts training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Anerol C FMEA workshop training South of Texas FMEA and Control Plans 0
Anerol C FMEA Training for South Texas Service Industry Specific Topics 0
N What quality training do you suggest? Manufacturing and Related Processes 14
Q Lead Auditor Training Training - Internal, External, Online and Distance Learning 31
S Training in D&D for engineers with no medical device experience Design and Development of Products and Processes 7
CPhelan Optimizing Training Review Training - Internal, External, Online and Distance Learning 4
Q Documenting Effectiveness of Training Training - Internal, External, Online and Distance Learning 14
J Old procedure review and training requirements Document Control Systems, Procedures, Forms and Templates 9
P Have you purchased training materials from the 13485store.com? Training - Internal, External, Online and Distance Learning 0
Q Training For Temps Training - Internal, External, Online and Distance Learning 1
S Training for PRRC (person responsible for regulatory compliance) EU Medical Device Regulations 3
T IAQG Approved Training Providers vs. Probitas Authentication Approved Training Providers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Training for Manufacturing Nonconformances and CAPS with focus on the wording Nonconformance and Corrective Action 4
H Product Safety & Conformity Representative (PSCR) Training Company IATF 16949 - Automotive Quality Systems Standard 0
Q ISO Training Providers to fix careless workers? Training - Internal, External, Online and Distance Learning 19
Q Training Machinists on Company Processes Training - Internal, External, Online and Distance Learning 6
R Using Scrapped NC items for training Medical Device and FDA Regulations and Standards News 15
D IATF 16949 Clause 7.2.2 - On the job training IATF 16949 - Automotive Quality Systems Standard 2
D Training for ISO 17025 ISO 17025 related Discussions 2
Q Documented Evidence of Training ISO 13485: 2016 ISO 13485:2016 - Medical Device Quality Management Systems 42
Q Training vs competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
Crusader ASQ AS9100 Lead Auditor Training Career and Occupation Discussions 27
Anerol C On line training for REACH, RoHS, Halogen RoHS, REACH, ELV, IMDS and Restricted Substances 1
M Clinical evaluation report training EU Medical Device Regulations 3
E AS9146 FOD Training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
L How to find a good 510(k) submission training? Other US Medical Device Regulations 2
L How to find a good online CFDA submission training? China Medical Device Regulations 5
Sidney Vianna IAQG News New IAQG Resources - AS9104-3 Requirements for Aerospace Auditor Competency & Training Courses AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Lean Six Sigma Online Training Six Sigma 1
M RM 13006 Training Syllabus AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Sonja D AIAG VDA PFMEA and Control Plan training FMEA and Control Plans 9
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Training on the importance of Document Control Document Control Systems, Procedures, Forms and Templates 3
M Do employee training records need to be controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
BeaBea QMS/ Training Management Software Service Industry Specific Topics 4
N ISO 22716 - GMP Training for GMP trainer Other ISO and International Standards and European Regulations 2
T Training Records - assembly line staff ISO 13485:2016 - Medical Device Quality Management Systems 20
D Do employee training records need to be centralized? IATF 16949 - Automotive Quality Systems Standard 10
C Certification vs Accreditation Training (General) Training - Internal, External, Online and Distance Learning 1
A Corrective Action Training ISO 13485:2016 - Medical Device Quality Management Systems 1
A Self-training or Self-studying ISO 13485:2016 - Medical Device Quality Management Systems 8
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Employees training database Document Control Systems, Procedures, Forms and Templates 4
