Training Forms - Do training forms need to be numbered?
Gman2
Involved - Posts
I am putting together some ISO-9001 overview forms (training forms).
They are very simple and straight forward with areas for Name, Machine/Area, Date, Title (ISO 9001 overview) and topic breakdows.
Then an area at the bottom for the employees and trainer to sign and date.
My question is does this need to be numbered and controled?
If so does EVERY (element/clause) training form HAVE to be?
I am thinking those do because they will be specific.
And I believe the machine training forms with listed compentencies will be numbered.
But this is just an ISO-9001 overview training form.
Just trying to get an idea on what has to be controlled and what does not.
G.
ccochran
Gman2,
Good morning. The acid test on document control is this question: are the training documents required by your management system? (Reference the 1st sentence of 4.2.3, "Documents required by the quality management system shall be controlled.") Since you've chosen to make training documents part of your system, you've already answered this question. Yes, training documents are required. Thus, they must be controlled.
How you chose to control them is largely up to you, within certain bounds. Nowhere does ISO 9001:2000 say anything about numbering of documents. You simply have to make the documents "readily identifiable." This could be accomplished through a title, as opposed to a document number.
Whenever you're not sure if something should be controlled, ask yourself if the documents in question are required by the management system. The way you answer this will tell you if control is necessary. If document control starts seeming too unwieldy, take a hard look at your document control procedure to see if it lean and streamlined enough. It's possible that your document control procedure stipulates some controls that are neither needed internally nor required by ISO 9001:2000. More thoughts here: http://www.qualitydigest.com/june02/html/doccontrol.html.
Good luck,
Craig
Craig Cochran
Center for International Standards & Quality
Georgia Institute of Technology
[email protected]
Go back to the standard: "Documents required by the quality managment system shall be controlled." Now, are these training forms required by your QMS (in other words, if you threw them out, would your QMS suffeer)? If they are required, then they must be controlled. So the next question is what type of contol? That's the a)-g) stuff. Does any of those indicate "numbering"? No, it requires them to be "readily identifiable" (e). The name, or title of the form should be good enough.
However, if your procedure says they will be numbered, then you either have to number them, or change the procedure.
We tend to make doc control much harder than it needs to be.
BadgerMan
ccochran said:
Gman2,
Good advice. I always ask myself two questions regarding the need to control "forms":
Does the system specify its use?
Does it, when completed, become the record of the activity?
In our facility, we use e-mail to communicate training activity to the Training Coordinator because she enters it into our training database which then becomes the record of the activity.
Gman2
Involved - Posts
Okay thats good but, you know the next issue that is going to come up is how do you keep track of revisions when we are not using any numbers and are only referencing the title?
What is the training for changes? How do we know we are using the current form? I think that is what they are going to ask.
G.
G.
When I mentioned numbering, I was refering to a form number, not a revision number. Two entirely different things. The Standard gives us some help here as well, however:
4.2.3 c) "to ensure that changes and the current revision status of documents are identified"
So, how do you know if it is the right form? Does it need a revision number? In some cases, perhaps. In some cases, perhaps not. Perhaps the standard can be fulfilled through training on the form. Perhaps it is from having the form in an electronic format and you fill it out, then print it (if paper copies are required). The electronic master can be controlled, and the revision would be the "date modified" on the electronic properties.
Once again, it is important for the control to be useful to you and your organization. Keep it simple, and keep it useful.
howste
Thaumaturge
ccochran said:
...The acid test on document control is this question: are the training documents required by your management system? (Reference the 1st sentence of 4.2.3, "Documents required by the quality management system shall be controlled.") Since you've chosen to make training documents part of your system, you've already answered this question. Yes, training documents are required. Thus, they must be controlled...
At the risk of sounding nit-picky, I have a different opinion on what documents are required by the quality management system. Just because you create a document does not mean your quality system requires it. I could easily create a training record on a cocktail napkin that would meet my needs. However, if the form is needed to control the content of the record, then the form requires control.
4.2.1d specifies what documents are required:
The quality management system documentation shall include
d) documents needed by the organization to ensure the effective planning, operation and control of its processes,
If the document is used to help control the process, it's required.
Marc
Gman2 said:
My question is does this need to be numbered?
None of my smaller clients have numbered their forms. In fact, all documents are identified either by the disk file name or the title of the form. No numbers, no muss, no fuss. Obviously, this is not very workable in large companies.
How you identify a document or form is entirely up to you.
:agree:
:agree: I like this bare bones approach that Marc takes. However, from the LARGE company approach, I have used this:
  • You have a document titled QAP 6.2.2, Competence, Awareness, and Training in your procedures manual.
  • Said document requires two forms as part of the procedure: Training Attendance Record and Employee Training Record.
  • Number them Form QAP 6.2.2-01 and Form QAP 6.2.2-02 with a rev letter or number.
  • Refer to them by # only in the procedure and put them in a collected forms in the back of your QAP Manual.
  • If they require update, simply update the form and rev letter, no need to change procedure.
  • Easy reference from the form back to the procedure that required it.
J Training SOP and Forms Training - Internal, External, Online and Distance Learning 3
E AS9102 First Article Training Material and AS9102 Forms 1, 2, and 3 Training - Internal, External, Online and Distance Learning 7
E Job training to procedures and work instructions - Do you have to train to forms? Training - Internal, External, Online and Distance Learning 7
T Training Evaluation Form - One-page feedback forms that instructors use Training - Internal, External, Online and Distance Learning 14
M Lack of Training vs. Laziness: Failure to Complete Forms and Tags AFTER Training Training - Internal, External, Online and Distance Learning 68
A Self-training or Self-studying ISO 13485:2016 - Medical Device Quality Management Systems 8
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Employees training database Document Control Systems, Procedures, Forms and Templates 4
optomist1 Rates Daily or Hourly Process Improvement Training Consultants and Consulting 2
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
S IEC60601-1 Training recommendations Training - Internal, External, Online and Distance Learning 1
P Training department ideas and development for automotive supplier Training - Internal, External, Online and Distance Learning 6
C RA (Regulatory Assurance) Training (FDA) looking for resources Training - Internal, External, Online and Distance Learning 5
was named killer Onsite Level II N.D.T. Training in Florida Training - Internal, External, Online and Distance Learning 0
T Training recommendations? Bringing our RoHS and REACH compliance efforts in-house REACH and RoHS Conversations 2
S Quality Audit Training Activities Quality Manager and Management Related Issues 2
M Audit Criteria Training Materials Internal Auditing 1
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
optomist1 Informational Training IMDS - Management of Product Chemical Regulatory Compliance RoHS, REACH, ELV, IMDS and Restricted Substances 2
Anonymous16-2 Labelling Training Training - Internal, External, Online and Distance Learning 3
J Recommendations for online ISO 19011 training? Training - Internal, External, Online and Distance Learning 8
J Looking for a training organization that can provide in house DFMEA training FMEA and Control Plans 4
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 17
JAMESH Building a "Lean" Job Shop Training Program Training - Internal, External, Online and Distance Learning 0
I Does training have to be written? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Regulations for Medical Device Kit for Training Personnel? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
S IRCA Lead Auditor training and Exam tips Training - Internal, External, Online and Distance Learning 5
N ... and some have greatness thrust upon them - Training for novice QA manager ? Training - Internal, External, Online and Distance Learning 6
C Looking for APQP Training recommendations preferably in the aerospace industry APQP and PPAP 2
B VDA 6.3 Qualification as Process Auditor training course and exam VDA Standards - Germany's Automotive Standards 0
L Hazardous Waste - Tips for creating standardized training Miscellaneous Environmental Standards and EMS Related Discussions 2
R ISO 13485 QMS Implementation Training ISO 13485:2016 - Medical Device Quality Management Systems 7
R How to keep track of employee read-only training ISO 13485:2016 - Medical Device Quality Management Systems 13
I "On the job training" as a response to how someone was trained? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 75
J Getting training either from ASQ or from SAI Global - ISO 9001 Lead Auditor training Training - Internal, External, Online and Distance Learning 1
I Date of Quality Management System - Training Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
R ISO 13485 and QMS related concepts Training - Small medical device startup company ISO 13485:2016 - Medical Device Quality Management Systems 9
R Training Matrix for Document revisions ISO 13485:2016 - Medical Device Quality Management Systems 4
I Training records and "grandfather" clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Education authority requires approval of all courses - Training services provider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S ISO 9001 Clause 8.3 - Design & Development for training course center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M ESD (Electrostatic Discharge) Training Misc. Quality Assurance and Business Systems Related Topics 2
S Is Annual QMS Training Required? ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
D ISO 9001:2015 Internal Audit Training Advice Internal Auditing 10
