Training Matrix Need to Be Proceduralized?
rm3chris
Is it a requlatory requirement for Training Matrices to be proceduralized? We have a company wide training procedure and each department has what we call "certifications" which are nothing more than a bunch of required sop's lumped under one umbrella. Each area has several functional certifications depending on which manufacturing line they are working on. For example, Certification A has three SOP's for sterilization. Certification B has five SOP's for boxing, etc.
All of the certifications are maintained and controlled by the Training Department. Area Leaders meet with us frequently to ensure they are updated and accurate....which docs should be added or removed or stay the same. The plant has read-only access.
Does my plant wide training procedure need to change revisions each time a document changes within a certification? And, does each certification need to be it's own procedure?
yodon
My knee-jerk reaction is that there's not even a requirement for training matrices! That's a good and common method, but the requirement is that employees are competent to perform the tasks they are assigned. How you demonstrate this is up to you.
One additional note: the updated standard places more emphasis, based on risk, on the method used to check effectiveness of actions taken (including training) to ensure competence. Make sure you factor this in when organizing your training programs.
rm3chris
Thanks so much! I was actually asking if the training matrices need to be proceduralized or not. My thoughts is if the Training team maintains them, no one has access to change it in a secure drive.
Are there any regulatory requirements for them to be proceduralized or just good practice.
yodon
Again, no requirements for specifically how you manage this as long as you can clearly demonstrate what competencies are required, personnel have the required competence, and any actions taken are assessed for effectiveness.
L
locutus
As yodon said, there is no regulatory requirement for having a "Training Matrix". If you read the standard (ISO 13485 2016 version) Section 6.2 states that organisation shall determine necessary competency for employees and then to provide training or actions to maintain this competency. No where in the standard (or ISO 9001) standard does it state a training matrix is required.
Now, one of the easier ways to show who is supposed to be trained on what, is to have a training matrix. This can be done however an organisation wants. Even myself as an auditor, I will ask to see the training matrix. But if they don't have one, then yes, as an auditor it will actually take me time to think and not use a bloody checklist to figure out how they determine competency and training thereof.
Now if your own procedure states that you create, maintain, and update a Training Matrix for personnel, then you do need to follow your procedure. How you determine competency, roles, responsibilities, authority, training requirements, training effectiveness, etc. etc. is completely up to you. So to answer your question rm3chris, no there is no regulatory requirement that requires a proceduralised training matrix unless you do this, but is it a good method? Yes. And if you do use a training matrix, then it should be a form/template in your procedure describing how it is generated and maintained. I can not speak directly to how you are doing without seeing your entire processes and interactions, but it sounds ok.
R Training Matrix for Document revisions ISO 13485:2016 - Medical Device Quality Management Systems 4
Z Training Qualification Matrix for ISO 9001:2015 Audit General Auditing Discussions 8
Q Simple and effective way to maintain Training Matrix ISO 13485:2016 - Medical Device Quality Management Systems 16
S Employee Training Matrix - Keeping track of employee training on various SOPs ISO 13485:2016 - Medical Device Quality Management Systems 4
P Work Area (Production Shop Floor) Training Matrix Requirements Training - Internal, External, Online and Distance Learning 4
S Training Matrix Dilemma Excel .xls Spreadsheet Templates and Tools 2
S Regulatory Affairs Training Matrix Training - Internal, External, Online and Distance Learning 5
D ISO 9001 Clause 6.2.2 - Training Records, a Job Skills Matrix and Job Descriptions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
1 Training Matrix for Quality Engineer and Quality Liaison personnel Training - Internal, External, Online and Distance Learning 2
J Training Matrix Requirements - ESA & Internal Frozen Process Control Various Other Specifications, Standards, and related Requirements 3
S Excel Training Matrix wanted - Moving employee training info from Access to Excel Training - Internal, External, Online and Distance Learning 11
G MS Access format Training Matrix Needed Training - Internal, External, Online and Distance Learning 12
I Skill Matrix Format as a Tool to Identify Training Needs Document Control Systems, Procedures, Forms and Templates 1
Anerol C Is a Training Matrix Enough to cover ISO requirements? Training - Internal, External, Online and Distance Learning 47
GStough Should a Training Matrix Be Approved Into the QMS? Training - Internal, External, Online and Distance Learning 9
Q Training Matrix - Job Class vs. Process Instructions - ISO 13485 Training - Internal, External, Online and Distance Learning 4
Q Training Matrix in Excel or maybe an Access database Excel .xls Spreadsheet Templates and Tools 1
B Training Record Matrix Macros in Excel .xls spreadsheet Excel .xls Spreadsheet Templates and Tools 11
F Training Matrix - Skills based matrix within an Investment Foundry Training - Internal, External, Online and Distance Learning 6
M Controlled company training matrix for ISO 9001 that identifies every position Training - Internal, External, Online and Distance Learning 12
S ISO 13485 certification training Training - Internal, External, Online and Distance Learning 1
S AS9120 - New Internal Auditor Training requirement? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M English Language training on MHLW MO169? Japan Medical Device Regulations 1
M On-demand EU MDR Compliance toolkit with online training courses, templates & document management system Training - Internal, External, Online and Distance Learning 0
Sam.F Question about training Training - Internal, External, Online and Distance Learning 17
Q Onboarding and Training Checklist Training - Internal, External, Online and Distance Learning 5
G Any training material on the 1-10-100 rule? Training - Internal, External, Online and Distance Learning 4
Sam.F Anyone knows velocity 360 training Training - Internal, External, Online and Distance Learning 11
Q Safety Training Program Training - Internal, External, Online and Distance Learning 8
R ISO 17025 Lead Assessor Training ISO 17025 related Discussions 0
A New to QMS and regulatory... advice on training/certification? ISO 13485:2016 - Medical Device Quality Management Systems 1
T Counterfeit parts training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Anerol C FMEA workshop training South of Texas FMEA and Control Plans 0
Anerol C FMEA Training for South Texas Service Industry Specific Topics 0
N What quality training do you suggest? Manufacturing and Related Processes 14
Q Lead Auditor Training Training - Internal, External, Online and Distance Learning 31
S Training in D&D for engineers with no medical device experience Design and Development of Products and Processes 8
CPhelan Optimizing Training Review Training - Internal, External, Online and Distance Learning 4
Q Documenting Effectiveness of Training Training - Internal, External, Online and Distance Learning 14
J Old procedure review and training requirements Document Control Systems, Procedures, Forms and Templates 9
P Have you purchased training materials from the 13485store.com? Training - Internal, External, Online and Distance Learning 0
Q Training For Temps Training - Internal, External, Online and Distance Learning 1
S Training for PRRC (person responsible for regulatory compliance) EU Medical Device Regulations 3
T IAQG Approved Training Providers vs. Probitas Authentication Approved Training Providers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Training for Manufacturing Nonconformances and CAPS with focus on the wording Nonconformance and Corrective Action 4
H Product Safety & Conformity Representative (PSCR) Training Company IATF 16949 - Automotive Quality Systems Standard 0
Q ISO Training Providers to fix careless workers? Training - Internal, External, Online and Distance Learning 19
Q Training Machinists on Company Processes Training - Internal, External, Online and Distance Learning 6
R Using Scrapped NC items for training Medical Device and FDA Regulations and Standards News 15
D IATF 16949 Clause 7.2.2 - On the job training IATF 16949 - Automotive Quality Systems Standard 2
