Transformer Overload Test - Need help
EMengineer
cl. 15.5.1.3 (Overload test) says that, if first protection activates, You need to shunt it. After that you make a little smaller current, which activated protection, and then test the transformer or wait till second protection device enables. The question is: why to use smaller current? If I use smaller current than that which enabled first protection device, what is the point of smaller current? It shouldn't activate second protection device because it's value is even smaller than that current which activated first protection device.
Could someone explain this? I would appreciate for help.
P.S. First protection device is electrical protection from short circuit, second would be fuse
P.S.S. Sorry for my English (not native language), hope You'll understand :)
Peter Selvey
The second protective device is usually not relevant.
If it is, it is usually because the first protective device is current based while the second is thermal based.
For example electronic protection is set at 1.00A.
So, the test is performed at 0.99A (just below).
The transformer and switching parts slowly rise in temperature and eventually trips a thermal based device e.g. a thermistor on the heatsink for the main switching transistor, or a thermal fuse in the transformer. That would be a secondary protective device. It would stop the test.
In such a case, the secondary protective device becomes the real "protective device" and should be controlled as a safety critical part.
mehrnaz
Dear Mr. Selvey
I have a question regarding the short circuit test of transformer output winding. if there is a transformer which has 2 output voltage of 12 and 24 volts. according to clause 15.5.1.1:
Transformers of ME EQUIPMENT shall be protected against overheating in the event of short circuit or overload of any output winding.
Each winding is tested, in turn........
This means that there should be protection in the case of short circuit of the 12v winding at once and in the other test short circuit of 24v winding shall be tested?
Is this necessary to check the short circuit between 12 v and 24 v, which are beside each other in the output terminal of transformer?
Because if I short circuit 12v and 0 volt at once or 24v and 0 volt in another test the transformer passes the test, but by short circuiting 12v and 24v the protection does not react to this test and the temperature of output wires exceeds...
Thanks in advance...
Peter Selvey
In a way this is two different subjects; windings, as an energy source that supplies secondary circuits, which need to be rigorously tested for overload and short circuit by virtue of being connected to a complex circuit that no body really wants to delve into the billions of possible fault combinations that could occur in that circuit. Just add some protection and make sure it is effective no matter what, and everyone can sleep.
Separately we the possibility that the 12V circuit can short to the 12V circuit. That's a valid concern but the fault permutations are just one (1). In that case it's worth to investigate the fault directly. For example, inspecting the creepage and clearance, dielectric strength. If these don't meet the requirements for 2MOP, short away. If the short fails the temperature limits, it's a fail result.
S How to overload a linear transformer with multiple protective devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
B Transformer Requirements - IEC 60601-1 vs. IEC 61558-2-15 IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
G Where to buy Medical Grade Transformer IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
N Triple insulated wire for transformer isolation IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
E Creepage distance accross insulation of step up transformer EU Medical Device Regulations 2
A MOPs needed after Isolation Transformer IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Transformer Compliance Testing, overheat then humidity treat, then dielectric test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
alonFAI Gaps between the Bobbin and the Ferrite Core in a Transformer Manufacturing and Related Processes 1
R Question on IEC 60601 clause 15.5.1.1 (transformer overheating) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S How to implement protection for multi-winding transformer? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
P PSU Transformer Tests Approved to IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W Supply Voltage Condition for Transformer O/L and S/C (open & short circuit) testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
D Transformer Oil Analysis - Help with a a Duval's Triangle Preventive Action and Continuous Improvement 4
P Test Voltages for a Pulse Transformer used to Isolate the Patient Connection IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
L Quality Assurance Manual for Transformer Oils Service Industry Specific Topics 2
E Ethernet Isolation Transformer for Medical Grade PCB IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
R How to determine the reference voltage for three-phase transformer? IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
G 50 Turn Transformer Coil Calibration Technical question General Measurement Device and Calibration Topics 10
D UL Certified Isolation Transformer Various Other Specifications, Standards, and related Requirements 3
L looking for a forum related to motor/transformer lamination manufacturing Book, Video, Blog and Web Site Reviews and Recommendations 2
G What differentiates a "bridging transformer" from an ordinary "isolation transformer" General Measurement Device and Calibration Topics 5
F Battery overload in IEC 60601-1 vs 62133-2 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
T GD&T overload Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
N Are Overload Test Results expected to be maintained through out Life of Product? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Windings Temperature exceeds the Limit - Overload Test of Switching Power Supply IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Marc Information Overload World News 3
E EN 868-5:2018 Annex E - Peel Test Design and Development of Products and Processes 1
D Comparing inline Conductivity instrument with offline test results General Measurement Device and Calibration Topics 0
H DIN 12880:2007-05 Clause 7.2 Test Equipment Description CE Marking (Conformité Européene) / CB Scheme 0
E Usability for Near Patient Testing Test Kit Human Factors and Ergonomics in Engineering 2
B SAE J 524 Pressure Test/Possible conflicting requirements? Manufacturing and Related Processes 0
J Automated test lead switcher? Calibration and Metrology Software and Hardware 0
J Applicable Great Britain regulations for a custom-built test rig or evaluation kit used for research purposes only. Design and Development of Products and Processes 0
U Leakage test Standard for Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A MSA and Poison (Red Rabbit) Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K ISO 17025 Method Validation and Verification for Test Lab ISO 17025 related Discussions 4
J IEC60601-1: HiPot Test Method for Internally Powered Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
P Comparing Two Test Variables Using Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
M Disinfection: Test recommended ISO 13485:2016 - Medical Device Quality Management Systems 0
H Microbiology count test failure Other Medical Device Related Standards 1
S AMS 2769 - weekly frequency test AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S How to determine sample size to test when the acceptance criteria is x >= Standard value? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
Kevin Walters AS9100 and AS9120 AATT Course and Test AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
W Conducting an MSA Test on scales Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Lot Release Test and Certificate of Analysis 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
John Broomfield Construction Inspection and Test Plan Misc. Quality Assurance and Business Systems Related Topics 5
Z COVID-19 Antigen Test Kit (Self-test) Registration in Peru Other Medical Device Regulations World-Wide 0
R GearBox Test Bench Calibration General Measurement Device and Calibration Topics 2
N 60601-2-34 Electrosurgery interference Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
M Gage R&R automated test equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
