Transformers and Thermal Cutouts
dhughessr
I have a question regarding transformers with thermal cutouts and IEC 60601-1 I hope someone can answer.
I’m getting conflicting information from vendors.
One vendor says “these cutouts cannot be used to cut off the transformer power as that is not allowed in this standard and once they are provided they must go to signal an audible alarm.”
I cannot find anything resembling that statement in 60601-1 3rd. Ed.
The only thing I see is in 15.4.2.1 a) THERMAL CUT-OUTS and OVER-CURRENT RELEASES with automatic resetting shall not be used in ME EQUIPMENT if their use could result in a HAZARDOUS SITUATION by such resetting.
Are thermal cutouts allowed/required?
Do they need to have an associated audible alarm?
Stijloor
Can someone help?
Thank you very much!
Stijloor.
Peter Selvey
Thermal cut outs are common in medical devices, there is no problem to use them.
For some higher risk equipment the loss of power is a potential hazardous situation (15.4.2.1 d), for example:
- patient monitoring equipment
- equipment with mechanical constraints on the patient, where loss of power means mechanical parts cannot be moved
In these cases, there are usually other safety features, e.g. a power fail alarm; a mechanical lever which can release the patient independent of power loss.
Many parts manufacturers have a disclaimer against using their part in medical equipment. But this is normally ignored. Just use normal safety principles.
somashekar Information sharing: Week 21, 2010 (CAPACITORS, TRANSFORMERS, RELAYS) The Reading Room 2
I Lifetime Support Calculation - Thermal Operating Profile Reliability Analysis - Predictions, Testing and Standards 7
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
E Solder thermal profiles for PPAP - Automotive IATF 16949 - Automotive Quality Systems Standard 1
V Regrinding Material - Thermal properties Manufacturing and Related Processes 4
x-files [Thermal Power plant KOSTOLAC, SERBIA] Sucessfully certified to ISO 50001 Sustainability, Green Initiatives and Ecology 1
x-files [Thermal powerplant] Why "Generation of electricity" is a special process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
x-files Thermal Powerplant - 7.5.3 Identification and Traceability ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Thermal Sensitivity Testing - Heat Lamp - ILY - Increased blood circulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
x-files [Exclusions] 7.3 Design and development vs. Thermal Powerplant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
x-files Global Timeline Plan of IMS/QMS Activities for a Thermal Power Plant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc Acronym CTE - Coefficient of Thermal Expansion Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
O AECQ 200 Revision D vs. Revision C - Thermal Shock & Thermal Cycling Other ISO and International Standards and European Regulations 2
U Is there such a thing as 1-part thermal cure epoxy? Manufacturing and Related Processes 11
J IPC-A-610 E Thermal Plane Acceptance Criteria for D-Pak Component Other ISO and International Standards and European Regulations 2
M Transport Vehicle Thermal Regulation - How would you interpret this requirement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R If two thermal cutouts required for water cooling system? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
O Thermal Shock Test with conditions specified in AEC-Q200 Various Other Specifications, Standards, and related Requirements 3
M Diebond adhesive blowholes seen after thermal curing on chip to plastic bottle mount Manufacturing and Related Processes 4
somashekar The Plasma Thermal Destruction and Recovery (PTDR) Waste-to-Energy Technology Sustainability, Green Initiatives and Ecology 4
S AMS2771 - Soak Time Interpretation (Thermal Conditioning) - T6 or T61? Manufacturing and Related Processes 8
T International Reference or SOP for the Thermal Validation of Incubators, Cold Rooms General Measurement Device and Calibration Topics 2
M Thermal Mapping Concepts - Drug store with dimensions 75m x25m x13m General Measurement Device and Calibration Topics 10
somashekar Optical epoxy for LED having good thermal shock resistance. Manufacturing and Related Processes 2
C Thermal Accelerated Aging Test(s) for Epoxy Reliability Analysis - Predictions, Testing and Standards 6
S Oven Qualification - Thermal profile during the OQ of a vacuum oven General Measurement Device and Calibration Topics 6
somashekar Hazardous waste rules - India - Carbon paper and thermal transfer printer ribbons Miscellaneous Environmental Standards and EMS Related Discussions 7
T Standard for "Simulating Long Term Effects on Materials / Thermal Disinfecion" needed Other ISO and International Standards and European Regulations 3
T Detergents for Washer-Thermal Disinfector of Plastic Materials ISO 13485:2016 - Medical Device Quality Management Systems 3
E GMW3172 - Thermal Shock and PTC cycles required to validate an electronic system Reliability Analysis - Predictions, Testing and Standards 2
J Temperature cycling thermal chamber accuracy and Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M GMW3172 - Electrical/Electronic - Temperature cycling and Thermal shock Customer and Company Specific Requirements 4
D Process Qualification - Heat Treatment Process Furnace - What is Thermal Mapping? Manufacturing and Related Processes 7
