Transition from ISO9001 to AS9100D: O&G to Aerospace
Hello Forum,
I am currently in the process of building our ISO9001/APIQ1 QMS into an AS9100D system as well. The reasoning should be obvious with the decline in oil prices, industry instability and thirst for diversification (Oh and the CEO wants it done also). So here are a few starter questions.
1) Is the easiest route to just add to the existing QMS (QM/Procedures/Work Instructions/Forms) by adding the additional AS9100 requirements in and possibly identifying them as aerospace requirements?
2) Since we do not currently build anything for aerospace but intend to ASAP and need records for about 3 months to document manufacturing, how do I go about obtaining drawings or CAD files of an aerospace product to start working on and building records? I am looking at GrabCAD.com and seeing some promise, but obviously we will not be doing design/development to start as we are a job shop, so will making a random part be sufficient since we have no design documentation?
3) Would it be acceptable to just use the documentation and record requirements on an oil and gas part we already make and use that for audit purposes
4) I believe it is totally acceptable to separate out our quality requirements based on product type, obviously we only want to build our O&G equipment to API Q1 standards and not incorporate the extra strenuous requirements or AS9100 on a piece of oil and gas dumb iron.
Help me out here guys, what the best game plan to get this done ASAP? I have already started with the QM and also bought the AS9100 all in one document package from IHS so I Can compare verbiage, is this infeasible to think I could get certification by Q3 of 2021 if we have an accredited 9001 system?
Thanks,
Danny in Houston
Sidney Vianna
Post Responsibly
The context of work in commercial and military aerospace is very different. Just to give you a hint. Do you have any idea how to quantify and estimate the work involved with a First Article Inspection a la AS9102? Some machining work could have tolerances in a tenth of a thousand of an inch; is your production and inspection hardware capable?
I understand that the business owners might be looking for alternative markets, but the aerospace market is also depressed. I doubt an AS9100 certificate would open opportunities for a supplier with ZERO history in aerospace, when HUNDREDS of very good suppliers with DECADES of performance in the industry are also scrambling for business.
But, good luck.
Ralba
There is a bit to discuss here.
  1. Integrated QMS vs. Separate QMS is an organizational decision that very much depends on how you operate and how your QMS is set up. We are AS9100, ISO13485, and of course ISO9001. Ours are all integrated, and every Standard Operating Procedure applies to all of our certifications. I have seen others who have it broken up based on the standard. I prefer mine, but that is probably because I set it up.
  2. What requirements in the AS9100 standard are you trying to address with this change specifically?
  3. You are demonstrating your QMS, not your industry. It does not matter where your jobs come from, it matters what controls and processes you can demonstrate in the audit.
  4. While you can separate your quality requirements if you have a separated QMS based on product type, you must take extreme care in doing so. It is very hard to consistently step up quality in a controlled manner if you are not doing it constantly, and I have seen a lot of backsliding in systems that only do their higher quality sometimes. Remember that the controls given in the AS9100 system are purposeful and HELPFUL if you apply them to your business in good conscience. For example, our purchasing process only applies counterfeit protection to jobs requiring guaranteed supply chains. However, we apply our T&C's and control of external suppliers ubiquitously, regardless of the job.
I came into this industry from a different industry (plastics to electronics) and from TS16949, and implemented it here and passed our audit in 9 months. However, I have also led a TS16949 implementation and I had 100% support from the CEO. YMMV
All in all, I would say you would need to examine your company and upper management to see if they are willing to apply the change as a business system to help the company improve, or if they just want it done ASAP exclusively to gain access to jobs in industry. If it is the latter, that is a nightmare scenario and sounds very painful. It would be difficult to get that implemented in time by yourself for sure.
But, good luck.
This is a very valid point, I will have to lead business development to the professional sales guys. While the market is down for aerospace it has to come back at some point, and that is why we are choosing to pursue this now. Can you give me the 10 mile high overview of the AS9102 FAI process?
It seems I could create a duplicate QMS that includes our API Q1 and ISO 9001 system but with the supplemental requirement's of AS9100 included, than we could differentiate orders by quality plan that spell which certification requirements would be needed.
  1. What requirements in the AS9100 standard are you trying to address with this change specifically?
Since we are certified to 9001 any additional requirements spelled out in AS9100 would need to be added to our existing system.
  1. You are demonstrating your QMS, not your industry. It does not matter where your jobs come from, it matters what controls and processes you can demonstrate in the audit.
This is true and why I would like to differentiate what quality requirements are dictated per product since the majority of our products over the next year will be oil and gas related (threading, completions, drilling etc)
  1. While you can separate your quality requirements if you have a separated QMS based on product type, you must take extreme care in doing so. It is very hard to consistently step up quality in a controlled manner if you are not doing it constantly, and I have seen a lot of backsliding in systems that only do their higher quality sometimes. Remember that the controls given in the AS9100 system are purposeful and HELPFUL if you apply them to your business in good conscience. For example, our purchasing process only applies counterfeit protection to jobs requiring guaranteed supply chains. However, we apply our T&C's and control of external suppliers ubiquitously, regardless of the job.
This is a valid point and something that would require careful consideration thanks!
Fortunately my CEO is VERY involved and willing to do what it takes, unfortunately since the downturn I am the sole resident in the QA department, the QA Director : /
Thanks for the feedback!
Ralba
The upper management support makes a huge difference. For what its worth, I am also the only resident of the Quality Department, so I know what it is like.
Ironically, the ******** satirical document mocking the standard actually helped me get a grasp of the intent of the clauses, though it is for the previous revision. After I got the basic intent of the clauses, I did process mapping, and a careful reading of all of our SOPs to see what I needed to do.
I wish you luck, this board definitely helped me with my implementation, so I wouldn't hesitate to come back to Elsmar for clarification on the details of the standard.(read as "opinions"--people here do not always agree haha)
John Predmore
I wanted to mention, the AS9100 standard fully contains the clauses of ISO9001, and all added clauses appear in bold text. So for the cost of purchasing an AS9100:D standard you can quickly see what are the added requirements. There are quite a few guidance documents and recorded webinars on the industry website IAQG.org in the Supply Chain Management Handbook. Once you register, access to SCMH is free.
Awesome, I will sign up and have a look. I did notice that the AS9100 requirements were in bold which is quite helpful since the 9001 stuff is already built.
G Effect of ISO9001 2015 transition on ISO IEC 80079-34 Other ISO and International Standards and European Regulations 3
D Internal Audit During the Transition Period from ISO9001:2008 to ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
C Process Map Transition from ISO9001:2008 to ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
I Guidance for Transition from ISO9001:2008 to AS9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
G The right approach for making the transition from ISO9001 to AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Converting ISO9001:1994 to new ISO9001:2000 - Transition ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Transition from ISO9001-2000 to TS16494 - Small Business Seeking Advice and Help IATF 16949 - Automotive Quality Systems Standard 4
Raffy ISO9001:2000 Transition from QS9000 - Or Both? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J ISO9001:2000 Transition Book - Can someone recommend some good books? Book, Video, Blog and Web Site Reviews and Recommendations 1
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M MD Class I transition period MDD to MDR - changes? EU Medical Device Regulations 1
Q Transition from QC Inspector to QA Engineer Career and Occupation Discussions 4
Y MDR Transition - make "Available on the market" after CE certificate expiration EU Medical Device Regulations 3
shimonv MDR transition checklist EU Medical Device Regulations 0
T Brexit Transition Arrangements & Import into the EU EU Medical Device Regulations 3
J MDD to MDR transition - Time required for the implementation of the MDR EU Medical Device Regulations 7
S MDR consultants - in search of recommendations for a consultant for MDR transition. Paid Consulting, Training and Services 7
K Annex XVI Device Transition Timeline under the MDR EU Medical Device Regulations 2
B ISO 9001:2015 Transition: Much Easier Than You Think! Misc. Quality Assurance and Business Systems Related Topics 0
M UDI transition period and implementation EU Medical Device Regulations 6
M Informational The US FDA is Recommending Transition to Duodenoscopes with Innovative Designs to Enhance Safety: FDA Safety Communication Medical Device and FDA Regulations and Standards News 0
O New MDR 2017/745 Transition Strategy - 2019 Manufacturing and Related Processes 3
A How to manage the QMS system and SOP during the transition from MDD to MDR EU Medical Device Regulations 9
S When is the last date for transition to ISO/IEC 80079-34:2018? Other ISO and International Standards and European Regulations 0
K CE mark transition and new regulations CE Marking (Conformité Européene) / CB Scheme 0
Ronen E Informational ISO 13485:2016 Transition Period End - 1 March 2019 ISO 13485:2016 - Medical Device Quality Management Systems 0
T MDR Guidance Book - Useful for MDR transition? EU Medical Device Regulations 1
M Medical Device News EU – Transition Timelines from the Directives to the Regulations – Medical Devices and in vitro Diagnostic Medical Devices Medical Device and FDA Regulations and Standards News 13
H Transition to ISO 13485:2016 together with ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 12
Ed Panek Transition to IEC 60601 4th Edition - Risk Analysis and test submissions CE Marking (Conformité Européene) / CB Scheme 2
M Medical Device News Health Canada - Medical Device Single Audit Program (MDSAP) Transition Plan Canada Medical Device Regulations 2
M Medical Device News FDA News - 26-09-18 - FDA Reveals Vision for the Transition to ISO 13485 Other US Medical Device Regulations 1
M MDSAP Transition - Health Canada Website Notice on Apr 13 2018 Canada Medical Device Regulations 1
O IEC 60601-1-2 4th edition transition deadline Dec 31 2018 CE Marking (Conformité Européene) / CB Scheme 1
qualprod Transition and recertification at the same time? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P How To Transition From AS9100c to AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A ISO 14001:2015 transition from the 2004 standard ISO 14001:2015 Specific Discussions 8
F IATF 16949:2016 transition audit - Internal Audit Closures IATF 16949 - Automotive Quality Systems Standard 13
W AS9120A to AS9120B transition AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
L Transition date to IEC 60601-1-11:2015 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
B Going into IATF 16949 transition without Internal Audits IATF 16949 - Automotive Quality Systems Standard 4
P We have done NOTHING toward the ISO 9001 transition ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S Management representative transition checklist IEC 27001 - Information Security Management Systems (ISMS) 7
O ISO 9001:2015 Transition Internal Audit completion thread ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A ISO 14001:2015 transition audit - Major NC due to the procedure and audit plan ISO 14001:2015 Specific Discussions 10
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
R ISO 9001:2015 Transition Quality Manual Update - Redundant Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
G Upkeep of ISO 9001:2008 during Transition TO ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D AS9110 Re-Certification & Transition Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
