Transitioning from ISO 9001 to ISO/TS 16949:2009
Avogel
Currently my company is ISO 9001 certified. We have a potential customer that requires us to be TS-16949 certified.
I am sure there is a thread on this discussion already; maybe someone can help me find it.
I am looking for any resource available to help with this transition.
Does anyone know of a guide or some publication to make this easy?
Thank you,
howste
Thaumaturge
Re: Iso 9001 to TS 16949-2009
Do you have a copy of the standard? It makes it pretty clear what the additional requirements are. I'd suggest that you start with a gap analysis of the differences between ISO 9001 and TS 16949, and use that to identify what work needs to be done.
jerry_Malaysia
Re: Transitioning from ISO 9001 to TS 16949: 2009
Thank you,
If you have the luxury to engage a consultant, it will make your job much easier. But make sure the consultant is a TS auditor.
I have done the transition before, yes it is quite straight forward if you do a proper GAP analysis. Basically the major GAP is the 5 core tools, and process approach audit that is emphasize a lot. Also, there are many add ons requirements.
Guess the first thing to do is to provide your potential customer a consolidated plan on working towards TS certification.
:2cents:
Why? I've done a number of TS implementations as a consultant and I wasn't a TS Auditor! Knowledge of a robust implementation process, customer specifics, automotive tools, the audit process approach are what's needed, not an auditor's qualification or how to audit the tools etc!
howste
Thaumaturge
I probably should mention, in case you aren't aware, that you can't actually get a TS 16949 certification for your system until you are making automotive product for a customer requiring TS 16949. If they require your system to be "certified" before you are making the automotive product, you can be audited and receive a "Letter of Conformance" from an approved certification body. Here are the requirements:
TS Rules 3rd Edition said:
5.14 Letter of conformance
The purpose of the letter of conformance is to confirm that processes exist which satisfy the requirements of ISO/TS 16949:2002 and these "Rules".
A client may be eligible to receive a letter of conformance in the following two situations:
1) a new site exists, or
2) an existing site that can demonstrate it is on an active bid list for a customer requiring ISO/TS 16949:2002 certification or compliance.
The certification body may issue a letter of conformance after:
a) the client is able to supply the information required for the stage 1 readiness review (see section 6.5) including internal and external performance data and one full cycle of internal audits and management review, but not twelve (12) months of internal audits and performance data,
b) the relevant site has completed an initial audit (stage 1 readiness review and stage 2) with no open nonconformity,
c) approval by veto power.
A letter of conformance issue date is the date of the positive decision and is valid for a maximum period of twelve (12) months. The IATF logo and an IATF certificate number shall not appear on the letter of conformance; therefore no record of the audit and the letter of conformance shall be entered into the IATF database.
After twelve (12) months for the new site or if the client on an active bid list receives a contract from the customer requiring ISO/TS 16949:2002 certification, the certification process shall proceed by the same certification body with an initial audit (stage 1 readiness review and stage 2), with a maximum reduction of 50% possible in audit days for the stage 2 audit.
If a contract from the customer requiring ISO/TS 16949:2002 certification has not been issued within 12 months, the client may re-apply for another letter of conformance. No stage 1 readiness review is required and a maximum reduction of 50% in the stage 2 audit days is allowable.
jerry_Malaysia
Andy,
After reading your post, I think I must apologize to all competent TS consultants who are not TS auditors. :bonk: The reason why I preferred a TS auditor to be a consultant is I had very bad experience with a consultant who is not an auditor. He has given guidance to us which was found to be incomplete. After he assessed our system and said we were ready, CB auditors actually still pointed out a lot of gaps. We ended up in a mess. :frust: Having said that, I do agree that there are many consultants who are not TS auditors, but very competent.:yes:
Andy,
No problem, Jerry! Hopefully you got things straightened out! It is so important to make selections based on the capabilities of any supplier - from raw materials to services. Its always surprised and amazed me that although a material supplier will undergo quite extensive vetting, someone like a consultant can slide in, get a lot of money, not do a very competent job and rarely get a 'reject' made against them.
A ISO 9001- any advise please with transitioning from a paper based system to eQMS and multi site scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9001 Audit Observations - Transitioning my career into auditing Career and Occupation Discussions 16
O Transitioning Locations into a Multi Site ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Transitioning from ISO 9001:2008 to AS 9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
N Transitioning from ISO 9001:2008 to ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 6
A Transitioning from ISO 9001:2008 to ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 9
J Transitioning from ISO 9001 to CFR - Recently transferred to a Pharma company Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 9
T Transitioning from ISO 9001 to TS 16949 - Where to start and what to do? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Transitioning from QS-9000 to ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Do I need to change my SOPs? Transitioning to ISO 9001:2000 from the 1994 version ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Claes Gefvenberg Was transitioning to ISO 9001:2000 worth it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
Marc Transitioning to ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Timeframe for updating QMS / transitioning from ISO 14971:2012 to ISO 14971:2019 ISO 14971 - Medical Device Risk Management 16
R Transitioning to ISO 13485:2016 from EN ISO 13485:2012 ISO 13485:2016 - Medical Device Quality Management Systems 14
V Transitioning from cGMP to ISO Systems Career and Occupation Discussions 1
P ISO/TS16949 Lead Auditor requirements - Transitioning from QS9000 to ISO/TS16949 General Auditing Discussions 6
Sidney Vianna Transitioning from ISO 14001:1996 to ISO 14001:2004 ISO 14001:2015 Specific Discussions 9
M Transitioning to ISO 9000:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
R Tips on transitioning out of testing lab Career and Occupation Discussions 0
R Plea for advice on transitioning between Notified Bodies (label updates) Medical Device and FDA Regulations and Standards News 1
P Transitioning to the EU MDR EU Medical Device Regulations 9
Sidney Vianna IAEG Guidance Document to assist Aerospace Organizations transitioning to 14001:2015 ISO 14001:2015 Specific Discussions 0
M IQRM Software - Transitioning from Excel based FMEA's FMEA and Control Plans 3
howste ASQ is Transitioning to Computer Based Exams ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 13
R Training to Effective Documents - Transitioning to Agile Document Control Systems, Procedures, Forms and Templates 5
P Transitioning to AS9100 Revision C - Where to start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Surveillance Audit - AS9100 rev B Transitioning to AS9100 rev C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
T Documentation Pyramid - Transitioning from one document control system to another Document Control Systems, Procedures, Forms and Templates 8
L EMC Engineer in a Test Laboratory Transitioning into Quality - Looking for Guidance Career and Occupation Discussions 4
Q QS9000 Tier 2 for 12 Years - Transitioning to ISO9001 - Where do I start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
S Process Centered vs. Functional organization - Transitioning an Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
L Gap analysis within our ISO9001 system - Transitioning to TS 16949 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
N Quality Procedure numbering - Transitioning Document Control Systems, Procedures, Forms and Templates 6
J Transitioning from ISO9001 to TS16949 IATF 16949 - Automotive Quality Systems Standard 5
D Transitioning from QS-9000 to TS 16949 - How long will it take? IATF 16949 - Automotive Quality Systems Standard 6
RoxaneB Lack of Registration Body Consistency in Transitioning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Is ISO 13485 certification necessary for Class I (non-sterile) medical devices? ISO 13485:2016 - Medical Device Quality Management Systems 4
A ISO:13485 Strategy for a Startup ISO 13485:2016 - Medical Device Quality Management Systems 5
G ISO 13485 and CE certification strategy ISO 13485:2016 - Medical Device Quality Management Systems 7
A Small Company Implementing ISO 13485 Timeline/Process/Steps Advice ISO 13485:2016 - Medical Device Quality Management Systems 5
Sidney Vianna Informational ISO 45002:2023 General guidelines for the implementation of ISO 45001:2018 Occupational Health & Safety Management Standards 1
K ISO 17025 Query Relating to Monitoring of Equipment ISO 17025 related Discussions 2
A ISO 27001_Audit IEC 27001 - Information Security Management Systems (ISMS) 4
R ISO 13485:2016 “Lifetime” of a product Manufacturing and Related Processes 4
A Help required in establishing Laboratory Information Management System as per ISO 17025, Cl.7.11.2 ISO 17025 related Discussions 0
R Do I need to get calibration certificate from ISO 17025 for IATF Audit IATF 16949 - Automotive Quality Systems Standard 8
kys123 Implications of failing an Anvisa Audit for ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 4
A Risk Assessment for ISO 13485:2016 section 7?? ISO 13485:2016 - Medical Device Quality Management Systems 11
L Annex of ISO 13485:2016 as harmonized standard (MDR/IVDR) ISO 13485:2016 - Medical Device Quality Management Systems 2
S Microdermabrasion device - classification according to the ISO 10993-1 Other Medical Device Related Standards 1
