Transitioning to AS9100 Revision C - Where to start?
PrissiDe
I have a small machine shop and am beginning my transition to Rev. C, I have taken the transitioning class but am having a tough time figuring out how to start the transition. I have my processes planned out but I am a little confused on how to make them all flow together. Do I need to put a flow chart in my quality manual? Besides the new requirements in Rev. C how will my procedures be any different then they are now? Any clarification or examples will be much appreciated.
PrissiDe
I have one more question... My basically the same as outlined in the AS9100 table of contents? Is this acceptable?
DannyK
I would suggest reading the changes document from the IAQG website and verify each clause to see if you have addressed the requirements.
The procedures should not have to be very different. Most companies add a procedure for risk management.
dsanabria
First - thanks DannyK - Good point!
Go to the IAQG website
https://www.sae.org/iaqg/organization/requirements.htm
and read the materials
then...
Do a Gap analysis
as far as your Quality manual - if you are registered to AS9100B then look at the new structure of the standard. if not... ok square 1
Let me know if you need more help or send me a PM
PrissiDe
One of the major confusions of Rev. C is how to go about showing what your processes / activities are? Where to list them? A lot of people are saying that you should use a turtle diagram in your quality manual.. I thought about using a turtle diagram in each of my process procedures to show the inputs and outputs and to show what activities fall under that process. What is your opinion on this?
Thank you for your help, once I get going I will be good to go. I know what the requirements are and what the differences are I am just having a hard time with the structure of the processes / activities.
PrissiDe
Can anyone share an example with me on how they are complling with the requirements in 4.2.2c? This is where all of my confusion is. I have read so many conflicting agruments on flow charts, turtle diagrams, etc. I am wanting to show the relationship between all of my core processes and how my sub-processes relate to each process. Any suggestions would be helpful.
Thank you in advance. :)
andygr
As mentioned first perform your gap analysis to cover the changes from B to C. Update your documents as needed to cover these.
As for process maping there are many tools that you can use. The key is to make sure that you have for each process measures of quality and timlyness as a minimum that the owner of the process would review and act on.
It is best to have the owner be involved in the creation. Keep it high level to start and add detail as you learn more.
As we are going through this creation of our overall process what we found was orphan outputs and inputs. In many cases the name had changed from one process to the next but in some cases there was an output created that no other process or requirement appeared to need or care about.
We intend to change from a straight turtle diagram and add a basic process flow chart in the center block of the turtle diagram. Will post a template once I get it sorted out
:2cents:
Boscoeee
I suspect the greater issue is AS 9101... and it's new guidelines for how you will be audited.....it will be a bit different and will take some time to put together the evidence to support the effectiveness of your processes.
I am in the same boat, no problem with updating our system, however in reading AS 9101, I can see the Auditor asking for more details with regards to effectiveness of internal processes.
If you do not have a copy, suggest you get one and review it!
PrissiDe
Thank you all so much for your input. I done a gap analysis and am in the process of making sure that we are conforming to all the new requirements. I have been studying the process approach. For some reason it has not clicked yet. I understand how all of my processes flow together, but it is like I am having a tough time distinguishing from my core processes and my sub-processes. I am also having a hard time transferring this to paper.
AndyGR- Once you get your template created that would be wonderful if you could post it here. Maybe that will help me to better understand how the process approach works. I have got to make myself understand this more because I have a feeling my next hurdle is going to be setting up a process based internal audit.
Thank you all
M Surveillance Audit - AS9100 rev B Transitioning to AS9100 rev C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
R Tips on transitioning out of testing lab Career and Occupation Discussions 0
A ISO 9001- any advise please with transitioning from a paper based system to eQMS and multi site scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Timeframe for updating QMS / transitioning from ISO 14971:2012 to ISO 14971:2019 ISO 14971 - Medical Device Risk Management 16
R Plea for advice on transitioning between Notified Bodies (label updates) Medical Device and FDA Regulations and Standards News 1
P Transitioning to the EU MDR EU Medical Device Regulations 9
S ISO 9001 Audit Observations - Transitioning my career into auditing Career and Occupation Discussions 16
R Transitioning to ISO 13485:2016 from EN ISO 13485:2012 ISO 13485:2016 - Medical Device Quality Management Systems 14
Sidney Vianna IAEG Guidance Document to assist Aerospace Organizations transitioning to 14001:2015 ISO 14001:2015 Specific Discussions 0
M IQRM Software - Transitioning from Excel based FMEA's FMEA and Control Plans 3
howste ASQ is Transitioning to Computer Based Exams ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 13
R Training to Effective Documents - Transitioning to Agile Document Control Systems, Procedures, Forms and Templates 5
O Transitioning Locations into a Multi Site ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Transitioning from ISO 9001:2008 to AS 9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
N Transitioning from ISO 9001:2008 to ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 6
V Transitioning from cGMP to ISO Systems Career and Occupation Discussions 1
A Transitioning from ISO 9001:2008 to ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 9
A Transitioning from ISO 9001 to ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 38
T Documentation Pyramid - Transitioning from one document control system to another Document Control Systems, Procedures, Forms and Templates 8
L EMC Engineer in a Test Laboratory Transitioning into Quality - Looking for Guidance Career and Occupation Discussions 4
J Transitioning from ISO 9001 to CFR - Recently transferred to a Pharma company Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 9
P ISO/TS16949 Lead Auditor requirements - Transitioning from QS9000 to ISO/TS16949 General Auditing Discussions 6
Q QS9000 Tier 2 for 12 Years - Transitioning to ISO9001 - Where do I start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
S Process Centered vs. Functional organization - Transitioning an Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
L Gap analysis within our ISO9001 system - Transitioning to TS 16949 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Transitioning from ISO 9001 to TS 16949 - Where to start and what to do? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Transitioning from QS-9000 to ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Do I need to change my SOPs? Transitioning to ISO 9001:2000 from the 1994 version ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N Quality Procedure numbering - Transitioning Document Control Systems, Procedures, Forms and Templates 6
Sidney Vianna Transitioning from ISO 14001:1996 to ISO 14001:2004 ISO 14001:2015 Specific Discussions 9
J Transitioning from ISO9001 to TS16949 IATF 16949 - Automotive Quality Systems Standard 5
D Transitioning from QS-9000 to TS 16949 - How long will it take? IATF 16949 - Automotive Quality Systems Standard 6
Claes Gefvenberg Was transitioning to ISO 9001:2000 worth it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
RoxaneB Lack of Registration Body Consistency in Transitioning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Transitioning to ISO 9000:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
Marc Transitioning to ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T What should be considered or asked to certified body auditors before selecting them for AS9100 Audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
L Counting contractors for determining AS9100 audit days AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T AS9100 Internal Audit (Quality System) Program AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T Guiding document or resource to process AS9100 audit findings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
T Clarity on requirements for indirect suppliers per AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 work for another site outside scope AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T AS9100 Process Sequence and Interaction Map Example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T Document Approver System AS9100 Doc Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Sam.F ISO9001/AS9100 Software Quality Assurance and Compliance Software Tools and Solutions 1
L Collateral Duty Inspectors - Ok for AS9100? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Production not following AS9100 std AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Process Sequence and Interaction Map AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
B AS9100 applicability to aircraft operation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S Supplier AS9100 certificate suspended - still ship goods ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
