Trend Reporting under the EU MDR
I am drafting a trend reporting procedure and was wondering if anyone has any information on establishing trigger levels for trend reporting under Article 88 of the EU MDR? An example will be very helpful
Hi, Marcelo.
Following the question of thosan, I would like to inquire further.
Trend reporting also exists in the existing MEDDEV 2.12-1(Rev8), and I think it's next.
- A general incident that is not serious enough to meet the requirement to submit an incident report.
The company is monitoring the trend of the incident itself,
Report to the National Competent Authority, using the form in Annex 7 of MEDDEV 2.12-1 rev 8, if an increase in the frequency of the incident is
found.
In other words, I think it is not necessary to prepare a trend report submitted to the National Competent Authority if the trend of incidents that can be reported during the PMS activities is not identified.(There is no trend report, so there is no meaning of trend reporting.)
Is that what I understand?
Of course, trend analysis will have to be continued by the manufacturer. However, I do not believe that submission of such an analysis to the National Competent Authority in the name of a trend report is required by the MDR.
The MDR also requires the PSUR to include trend reporting as a result of PMS activities.
Should the manufacturer summarize in PSUR the number of trend reporting during the PMS period, the content of the report, and corrective action for the trend?
Please advise.
Marcelo
A trend report is not "prepared"it needs to be planned (for example, you need to contract something like the graphic on MEDDEV (and yes, MEDDEV 2.12-1 rev 8 did incorporate most of the text of GHTF/SG2/N36R7:2003) for each situation in which trend reporting would apply. Then you need to monitor how much of that situations is happening and, if a statically significant increase happens, you need, between other actions, to inform the regulator.
I think people had a difficult time understand this requirement and I agree that it's not the easy to understand. The way I've been trying to explain in in more light terms is something like these:
- Let's say your device is designed in such a way that some situations that might occur with it, although undesirable, are to be accepted. For example, let's say that a side effect such as going dizzy because of the use of the device is expected in 10 cases of use for each 3 months of use (please note that this is only a generic number used to show the principle). Your risk management noted the problem, and your clinical evaluation "confirmed" it, and then your benefit-risk determination accepted it.
- Then your device is cleared/approved/whatever. This means, between other things, that for the device to be considered safe and effective, the number of occurrence need to be kept under 10 cases of use for each 3 months of use
- Then, you would begin to monitor these occurrences. If, for example, in the first month of use, the device has 4 occurrences of the problem, it's automatically non-compliant, because for the 10 cases in 3 months to be right, the device would need to be under 3 cases per month.
- So, you need to investigate and do something as the manufacturer. Also. because the device is non compliant (remember, it was cleared/approved/etc. for 10 cases in 3 months, not for more than that), you also have to tell the regulator that there's a problem.
Thanks, Marcelo.
I think what I understand is right.
"The manufacturer has established the number of occurrences of an incident that can be accepted according to the benefit-risk analysis, but only if this frequency is exceeded, the manufacturer should write a trend report and submit it to he National Competent Authority." This is "Trend reporting".
In other words, it is common practice for manufacturers to monitor trends in accidents regularly, and it is a requirement of MDR to write and submit trend reports only if they exceed pre-set criteria during the monitoring process.
Hello Marcelo (and all),
Per the EU MDR (Article 88), Trend Reporting is required for "any statistically significant increase in the frequency or severity of incidents that are not serious incidents or that are expected undesirable side- effects that could have a significant impact on the benefit-risk analysis referred to in Sections 1 and 5 of Annex I and which have led or may lead to risks to the health or safety of patients, users or other persons that are unacceptable when weighed against the intended benefits."
MEDDEV 2.12-1/rev 8 required trending on a significant increase in events not normally considered incidents per 5.1.3 (e.g., expected side effects or deficiencies identified prior to use). My U.S. company has been granted a CE Mark under the MDD, but we'll have to comply with sections 83-89 of the MDR after May 26, 2020.
Will MDR section 88 on Trend Reporting supersede the MEDDEV 2.12-1 trend-reporting requirements, or will we have to do both?
This is my first time working with EU regs, so I'd really appreciate your advice!
Thank you!
rob73
looking for answers
From what i understand all MEDDEV's will become "obsolete" after MDD is withdrawn as the MEDDEV's are specifically written to help compliance with MDD not MDR. You could still use the MEDDEV's but you need to ensure that any additional requirements from the MDR are covered.
Hello, everyone.
Thanks for this topic, it helped me a lot.
I have read the GHTF/SG2/N36R7:2003 document.
Those of you who regularly prepare trend reports, please, tell me in which document of the technical product file do you record the Baseline (IB) and Threshold (IT) value against which the observed incidence is compared for establishing the trend? And also the list of such events that will be monitored.
I think that the events themselves, if they are expected side effects, are listed in the IFU. But I cannot understand where exactly I should write the threshold values for comparison, the time interval, and calculated the observed incidence expressed as a percentage.
Or can this data be written in the PSUR itself? In the same report, the analysis for the reporting period will be done, for example, for a year. And based on the analysis results, a decision is made whether the creation of Trend reporting is required.
Thank you very much for your help, I hope my question is clear.
Sam Lazzara
Here is a form that I designed in an attempt to address this requirement.
At least it is a reasoned approach that should pass the "red face test".
red face test
D Vigilance Trend reporting requirements of Meddev 2.12/ver 7 in the EU Document Control Systems, Procedures, Forms and Templates 1
K Supplier Performance - Recording Supplier Performance for long term trend reporting ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Ed Panek Requirement to track and trend positive feedback from customers ISO 13485:2016 - Medical Device Quality Management Systems 12
QMMike New Trend of not seeking Official ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
S Track Cpk trend Statistical Analysis Tools, Techniques and SPC 5
J TS 16949 - The Rules performance trend for 12 months IATF 16949 - Automotive Quality Systems Standard 7
D Best Minitab Tool to determine a Statistically Significant Trend Using Minitab Software 5
L GB15980-2003 Bioburden Count Trend on Operator Hands Other ISO and International Standards and European Regulations 1
R Out of Trend (OOT) investigation Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
A Aircraft Maintenance Quality & Safety KPIs - Industry Trend or Database EASA and JAA Aviation Standards and Requirements 3
A Aircraft Maintenance Quality & Safety KPIs - Industry Trend or Database Quality Manager and Management Related Issues 4
K Customer Satisfaction - Would you advise to investigate the trend or the incidence? Customer Complaints 9
S Trend Review and Process Improvement help needed Capability, Accuracy and Stability - Processes, Machines, etc. 6
C Trend Analysis - Evaluating Quality of Pricing - ANVOA or Std Dev? Statistical Analysis Tools, Techniques and SPC 25
Marc Definition Significant Trend Trigger Level - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
R Trend Chart Clarification - Is it necessary to include targets? Misc. Quality Assurance and Business Systems Related Topics 2
Marc Enraged Customers fuel a disturbing trend Customer and Company Specific Requirements 9
F Trend Analysis of Kanban System for our Finished Goods Statistical Analysis Tools, Techniques and SPC 6
Crusader Registrar CAR (Corrective Action Request) Trend Analysis Benchmarking 6
T Control Chart on Paper vs. Software where trend cannot be seen (Alarm only) Statistical Analysis Tools, Techniques and SPC 8
B Statistical Analysis SPC Trend explanation needed Statistical Analysis Tools, Techniques and SPC 4
P Trend analysis - Common Mistakes of Sales Process Mapping Software Quality Assurance 2
S How to Calculate Out-of-Trend Results Statistical Analysis Tools, Techniques and SPC 16
Q Root Cause Analize or Trend Project Audit Findings Problem Solving, Root Cause Fault and Failure Analysis 2
D How do we interpret the following XmR Trend Chart data? Statistical Analysis Tools, Techniques and SPC 3
D When to use an XmR Trend Chart Statistical Analysis Tools, Techniques and SPC 5
ScottK Is using a 3rd party auditor for supplier audits a big trend? Supplier Quality Assurance and other Supplier Issues 14
Crusader Customer Concerns Trend Database to Share .xls Excel file Customer Complaints 17
D Is there a process shift and/or trend in the attached control chart? Statistical Analysis Tools, Techniques and SPC 33
M Toyota Approach to Root Cause Analysis - Operator Error trend Problem Solving, Root Cause Fault and Failure Analysis 9
Marc Bye-Bye, Pension! The trend in the US to reduce middle class worker wages World News 17
G Control charts where the center line is a trend or slope? Statistical Analysis Tools, Techniques and SPC 26
C The Life Cycle of a Trend The Reading Room 3
L Effective Meetings for trend analysis - Corrective and preventive action Nonconformance and Corrective Action 8
Q Pole Data Trend Analysis Help - Monitoring the % of poles that we have to straighten Quality Tools, Improvement and Analysis 34
W TREND Identification - Good (and simple) procedure or process to identify and track Other ISO and International Standards and European Regulations 4
Steve Prevette Life Cycle of a Trend - An SPC Overview Registered Visitor Articles Archive 7
B Searching for software to track and trend customer complaints Customer Complaints 11
D Control charts to trend data for multiple dependent variables? Hotelling's T^2 stat Statistical Analysis Tools, Techniques and SPC 3
Y Control Chart Rules - Trend and Statistics Explainations Statistical Analysis Tools, Techniques and SPC 13
A Internal Audit - Negative Trend Identified - What Clause to Cite? Internal Auditing 3
A Positive Trend - Rejections and Customer Complaints - What to do? Customer Complaints 6
S Reporting REACH - Electronic components distributor REACH and RoHS Conversations 5
A OQ and reporting issues Qualification and Validation (including 21 CFR Part 11) 2
R Vigilance reporting to the country of the EU authorised representative EU Medical Device Regulations 2
M Is it Necessary to Use Health Canada Form when Reporting? Canada Medical Device Regulations 1
L Proof of Concept Studies - Do we need to comply with SAE reporting? Medical Device and FDA Regulations and Standards News 3
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 1
A Medical device Reporting : Good Faith Effort for Additional information Other US Medical Device Regulations 2
B FDA-Medical Device Reporting (MDR )procedure compliant with 21CFR section 803 US Food and Drug Administration (FDA) 0
