Trial of New Medical Device
JoCam
Hi All,
During early stage development of a class I medical device, when it becomes necessary to establish whether the concept will actually be beneficial to the end user, what would a trial performed using patients be referred to as, and how should it be controlled? The device in question is a development on an existing class I device, and the changes superficial, having no affect on the safety of either the patient or health care provider.
Jo
rob73
looking for answers
What you are describing sound like a clinical investigation, from MEDDEV 2.7.2 rev 4:
Clinical investigation: systematic investigation in one or more human subjects, undertaken to assess the safety or performance of a medical device.
Clinical investigations are carried out to EN ISO 14155:2011, guidance can also be found in other MEDDEV's see http://ec.europa.eu/growth/sectors/medical-devices/guidance_en
If this device is based on an existing device then a clinical evaluation may suffice
Clinical evaluation: a methodologically sound ongoing procedure to collect, appraise and analyse clinical data pertaining to a medical device and to evaluate whether there is sufficient clinical evidence to confirm compliance with relevant essential requirements for safety and performance when using the device according to the manufacturer’s Instructions for Use.
shimonv
Hi JoCam,
You mentioned that its a class I device, meaning a low risk device.
You also mentioned that its superficial changes on top of an existing device.
It sounds like an engineering change (a revision change) that does not require investigation. I believe that a rationale explaining why no validation is required or a small usability study on simulated environment will suffice.
Shimon
dgrainger
ER 1 requires that you have looked at risk & benefit.
It sounds like your trial is a clinical investigation to demonstrate ER1.
Ronen E
Problem Solver
Moderator
In my opinion it depends on what you are going to test.
If it's the performance of the device then it falls in the domain of clinical investigation (trial) / evaluation.
If it's the way end users understand it and apply it, it's more likely to be a usability study - you could refer to either IEC 62366 of FDA guidance as applicable.
The question of whether you need a clinical investigation or just a theoretical evaluation (under the first scenario) depends on the novelty and amount of documented experience already available to you.
What do your internal QMS procedures say about existing devices modifications?
Julie O
Given that you posted in the EU sub-forum, I take it that you are asking about what is required for CE marking.
Design validation is a design control under ISO 13485. I can't help you much there, except to note that 7.3.7 of ISO 13485 (2016) refers to a need for clinical evaluation, which isn't necessarily the same thing as a clinical investigation/clinical trial.
The MDD requires a clinical evaluation, which, again, isn't necessarily the same thing as a clinical investigation/clinical trial. MEDDEV 2.7/1 Revision 4 provides detailed guidance on clinical evaluations:
Julie O
I'm also a little confused by "early stage" and "concept."
If you are talking about a clinical trial for design validation, that's the last thing you would do before transferring the design to manufacturing, which I would consider to be well past the concept stage. Unless maybe you are talking about a prototype to be used for "proof of concept."
Usually I think of the "early stage" effort to establish usefulness of the concept to users as the development of user requirements under ISO 13485 7.2.1.
JoCam
Hi JulieO,
I know what is expected to gain the CE mark, and we have started to compile the Design History File. We would like to trial the product using patients mainly to establish if the product is feasible, therefore it does fall into the feasibility study phase and the exercise could probably be termed a usability study. However, because patients are involved I want to establish whether or not we need to request a 'Notice of No Objection' from the CA before the study can commence.
I'm guessing, being as the changes are mainly superficial and that the system will still be used within its intended purpose, that I can justify not having to do this.
Jo
Julie O
Understood.
I'm afraid I can't help you with this, but I will post your question in the RAPS forum; perhaps someone there has experience with this.
J Need for a cleanroom in the manufacture of a medical device for a clinical trial EU Medical Device Regulations 4
U Medical device trial budget - 2 hospitals for Class IIa medical device in Sweden Other Medical Device and Orthopedic Related Topics 2
U Do we need clinical trial data for Class IIa medical device under MDR EU Medical Device Regulations 7
T Clinical trial - Medical device product not cleared (without FDA approval) in a drug trial Other US Medical Device Regulations 9
T Medical device Clinical trial exemption list China Medical Device Regulations 2
M Does Medical Device Usability Study = Clinical Trial? Other Medical Device and Orthopedic Related Topics 26
N Medical Device PIT (Physician Initiated Trial) Study without CE Mark EU Medical Device Regulations 3
I Medical Device Clinical Trial Audit Checklist wanted ISO 13485:2016 - Medical Device Quality Management Systems 2
B IDE vs NSR for Class II medical device clincal trial? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
P Medical Device Clinical Trial Labels Other Medical Device and Orthopedic Related Topics 3
D Clinical Trial for Medical devices in Canada Canada Medical Device Regulations 2
A Singapore - Requirements for Import of Medical Devices for Clinical Trial Other Medical Device Regulations World-Wide 2
S Roadmap for Clinical Trial for Orthopaedic Medical Devices EU Medical Device Regulations 2
I Brazil clinical data/trial requirement Other Medical Device Regulations World-Wide 0
C Clinical Trial using Prototype devices (EU MDR & ISO 14155) EU Medical Device Regulations 4
shimonv Device deficiencies (~complaint) discovered during a clinical trial ISO 13485:2016 - Medical Device Quality Management Systems 3
S Clinical trial requirements for UKCA mark in UK UK Medical Device Regulations 4
B Is clinical trial necessary? EU Medical Device Regulations 3
I France clinical trial requirements EU Medical Device Regulations 1
E ISO 13485 in Clinical Trial conduct: Applicable or No ISO 13485:2016 - Medical Device Quality Management Systems 2
L Clinical Trial and Finished Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
P Clinical Trial Requirement - No equivalent devices in the market CE Marking (Conformité Européene) / CB Scheme 3
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
shimonv Minimum 60601 requirements for a clinical trial IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Ed Panek Adverse Event Clinical Trial using a 510K approved Device Other US Medical Device Regulations 6
CPhelan Using clinical trial safety data for evidence for CE marking EU Medical Device Regulations 8
F China Device Assisted Technology Clinical Trial China Medical Device Regulations 4
R Clinical Trial to sell in the EU - Necessary or Not? ISO 13485:2016 - Medical Device Quality Management Systems 5
J Biologic Injectable Device Clinical Trial Packaging/Labeling/Artwork Guidelines Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
Q EU ROHS and GUI Usability Trial Requirements EU Medical Device Regulations 10
H IVD in US Phase III Clinical Trial - Non-CE Marked and Non-FDA Approved Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
M Is a confirmation trial is obligatory in development of a product? Design and Development of Products and Processes 3
M Is a confirmation trial obligatory in development of a product? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q South Africa Clinical Trial Inspections by MCC Quality Manager and Management Related Issues 1
S Clinical Trial Informed Consent Forms ("retro-signing") US Food and Drug Administration (FDA) 2
B Health Canada Acceptance Policy of Foreign Clinical Trial Data for Devices Canada Medical Device Regulations 2
Q What documentation is required for Design Feasibility trial? ISO 13485:2016 - Medical Device Quality Management Systems 5
C Retention of Clinical Trial Data after a Clinical Trial has ended Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
N Can a Clinical Trial Lead Investigator Surgeon be a Expert Clinical Evaluator? ISO 13485:2016 - Medical Device Quality Management Systems 3
W Production Trial Run in AIAG APQP and Run at Rate (GP-9) GM 1927 APQP and PPAP 2
R CE Mark requirements on US Clinical Trial Product CE Marking (Conformité Européene) / CB Scheme 2
I IVD product for use in a Drug Clinical Trial (FDA matters) US Food and Drug Administration (FDA) 3
J Labeling Contraindication vs. Clinical Trial Exclusion Criterion Other US Medical Device Regulations 7
bio_subbu CDSCO issues Draft Guidelines for Approval of Clinical Trial & New Drugs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M Production Trial Run Checklist or PV Build Checklist wanted APQP and PPAP 3
D Subtleties of Adverse Events - How should it be captured and handled in the trial? Other US Medical Device Regulations 4
B Ford Project Trial Acronyms Customer and Company Specific Requirements 9
D EU Clinical Trial Startup vs. US IDE (Investigational Device Exemption) ISO 13485:2016 - Medical Device Quality Management Systems 1
S Clinical Trial Study Reports - SOP Other US Medical Device Regulations 3
C Manufacturing Trial Report Templates - Help wanted Document Control Systems, Procedures, Forms and Templates 8
