True position with bonus Excel help
poyaa521
ok ill make a few posts so i can upload my completed file. i asked a question here so ill follow thru will the results.
poyaa521
I've highjacked many files over the years from here so i'll add one today. A True position with Bonus tolerance sheet. You can use for manual layout or transfer CMM data to it. It looks good to me but its new so any problems let me know.
  • True Position with Bonus tol layout sheet.xlsx
poyaa521
Here's a rev2 of true position with bonus tolererance sheet. fixed the OK/otl colum.
  • True Position with Bonus tol layout sheet rev2.xlsx
L GD&T Bonus Tolerance - Checking True Position of a Pierced Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
R True Position and MMB Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
8 True Position (Bolt Hole Circle) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
B GD&T Question, True Position Confusion Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D True Position Formula? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
M True position, calculating theoretical distances General Measurement Device and Calibration Topics 0
was named killer AS9100 FAIR - True Position hole out by .0011" on 50 parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B True Position Measurement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
P True Position vs X and Y Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
M True Position / GD&T - I'm staring at this drawing and I'm lost Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N True Position of slot Boundary with MMC Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Measuring the True Position of a Cylinder's Pierce Point Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M True Position and MMC (Dilemma Between Engineers) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Tab to circle True Position? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S GD&T Callout for Diametrical True Position Manufacturing and Related Processes 6
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Surface Profile and True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D True Position with 1 hole (Datum B) at the Radius Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Using a Pin Gage to check True Position of Inline Holes, Design, Tolerance. Etc Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Checking True Position with Pin Gage Measurement Uncertainty (MU) 3
F How could this Hole Diameter and True Position problem have been Detected & Prevented Nonconformance and Corrective Action 27
J Multiplane True Position Calculations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Y Using PC-DMIS to measure True Position of the teeth of a Spline Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L Calculation of True Position of Slots (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J How to measure the True Position on an Optical Comparator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Using True Position to Control Symmetry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K True Position Checking such as Bolt Hole Position w.r.t Center Bore on Wheels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
M GD&T - True Position Callouts for Sections of Studs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J GDT True Position Secondary Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
J True Position with only 1 Datum - Referenced datum is the plane the hole is on Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
M True Position of a Hole Capabilty - Appropriate parameters to use Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Understanding True position - Drawing Feature Control Frames - ANSI Y14.5 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
CycleMike Positional callouts on this print - GD&T true position question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
J True Position of slots that have angles as basic dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
Q GD&T True Position interpretation - True Position FCF on a B/P Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
B Calibration of Home Made Gages - Simple go/no-go gages to true position gages General Measurement Device and Calibration Topics 8
C True Position Question - What does this print callout mean? IATF 16949 - Automotive Quality Systems Standard 12
Q GD&T True Position structure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N How to Calculate a True Position on a Square Slot - GD&T Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
H History of True position formula Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
B True Position without tertiary datum? Establishing a proper rotation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
E Capability study on true position callout. What would be the upper and lower spec? Statistical Analysis Tools, Techniques and SPC 7
A Bidirectional True Position Tolerance Call-Out for Holes for Process Capability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Ppk/Cpk for geometrical true position of hole with MMC Capability, Accuracy and Stability - Processes, Machines, etc. 17
G GD&T Help (Y14.5M-1994) - True position callout box on two dowel holes Various Other Specifications, Standards, and related Requirements 16
J GD&T - True Position - "Boundary" under the feature control frame General Measurement Device and Calibration Topics 10
D Procedure for Fixture Gages that check True Position of holes General Measurement Device and Calibration Topics 4
