True Position with only 1 Datum - Referenced datum is the plane the hole is on
JasonFdz
True position with only one datum? I normaly do not have a problem with true position call outs, but this is confusing. True position on a hole and the referenced datum is the plane the hole is on. Can some one please help??
Cari Spears
True position with only one datum? ... True position on a hole and the referenced datum is the plane the hole is on.
Hi, Jason :bigwave:
So it only references one datum in the feature control frame? Are there other datums called out on the drawing? What feature(s) do your basic dimensions come off of?
JasonFdz
Hi, thanks for replying, basic dimensions are referenced but it seem i cant use them since only the one datum is specified. It seems that it would be the exact same callout twice then. please see the attached pdf file which i posted after you replied.:eek:
Cari Spears
I saw we posted simultaneously.:D
You can calculate the true position with only one datum in the feature control frame - you need the deviation from the basic dimension from that basic dimension's origin. In this case the basic dimension 30 from the center of the large (are those gear teeth?) diameter in the middle and the basic dimension 17.3 from the hole labeled "B".
Are you setting this up on a CMM - or using surface plate / height gage set-up?
JasonFdz
Im setting this up on a cmm, I'm using calypso so values are being generated, Im just not really sure what is being asked, it seems more like perpendicularity or concentricity should be used, how would you set up on a height gage?
Cari Spears
... how would you set up on a height gage?
I wouldn't - given a choice. I just wanted to make sure I didn't go into CMM set up detail if you weren't using one.
Since the feature control frame only calls out A, I would default to alphabetical order and set the part up to datums A/B/C. Then I would rotate the setup to the degrees specified and tell the program the origin of the basic dimension is "Hole XX". (I've never used Calypso.)
JasonFdz
Ok, thanks, One last question, what then would be the difference of No 130 and 131 since they would basically have the same set up and origin. (nominals)
David DeLong
The positional that I saw reflected 3 holes marked as "A" relative to datum A to become a datum B. Sounds confusing but that is what I read.
This means there is a hole to hole position of a diametrical tolerance zone of 0.1 mm beyond the MMC (maximum material condition) of the 3 holes to themselves and perpendicular to datum A. If they meet this requirement, the 3 hole pattern now becomes datum B.
To confirm the positional of the three holes, it is best to use a checking fixture since one cannot confirm all three holes at once on a CMM. If you are forced to use a CMM, most CMM Operators would create a datum on one of the holes (not quite theory) and then confirm the others to that hole.
Hope this helps.
JasonFdz
Dave,
That makes perfect sense............let me make sure i understand you correctly, create a circle using the three referenced holes (center point), create an alignment from each hole to the center of the three, and then simply ensure that the distance is within .1 of each other.
D True Position with 1 hole (Datum B) at the Radius Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
B True Position without tertiary datum? Establishing a proper rotation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
was named killer AS9100 FAIR - True Position hole out by .0011" on 50 parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B True Position Measurement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P True Position vs X and Y Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
M True Position / GD&T - I'm staring at this drawing and I'm lost Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N True Position of slot Boundary with MMC Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Measuring the True Position of a Cylinder's Pierce Point Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M True Position and MMC (Dilemma Between Engineers) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Tab to circle True Position? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S GD&T Callout for Diametrical True Position Manufacturing and Related Processes 6
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Surface Profile and True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
L GD&T Bonus Tolerance - Checking True Position of a Pierced Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Using a Pin Gage to check True Position of Inline Holes, Design, Tolerance. Etc Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Checking True Position with Pin Gage Measurement Uncertainty (MU) 3
F How could this Hole Diameter and True Position problem have been Detected & Prevented Nonconformance and Corrective Action 27
J Multiplane True Position Calculations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Y Using PC-DMIS to measure True Position of the teeth of a Spline Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L Calculation of True Position of Slots (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J How to measure the True Position on an Optical Comparator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Using True Position to Control Symmetry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K True Position Checking such as Bolt Hole Position w.r.t Center Bore on Wheels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
M GD&T - True Position Callouts for Sections of Studs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J GDT True Position Secondary Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M True Position of a Hole Capabilty - Appropriate parameters to use Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Understanding True position - Drawing Feature Control Frames - ANSI Y14.5 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
CycleMike Positional callouts on this print - GD&T true position question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
J True Position of slots that have angles as basic dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
Q GD&T True Position interpretation - True Position FCF on a B/P Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
B Calibration of Home Made Gages - Simple go/no-go gages to true position gages General Measurement Device and Calibration Topics 8
C True Position Question - What does this print callout mean? IATF 16949 - Automotive Quality Systems Standard 12
Q GD&T True Position structure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
N How to Calculate a True Position on a Square Slot - GD&T Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
H History of True position formula Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
E Capability study on true position callout. What would be the upper and lower spec? Statistical Analysis Tools, Techniques and SPC 7
A Bidirectional True Position Tolerance Call-Out for Holes for Process Capability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Ppk/Cpk for geometrical true position of hole with MMC Capability, Accuracy and Stability - Processes, Machines, etc. 17
G GD&T Help (Y14.5M-1994) - True position callout box on two dowel holes Various Other Specifications, Standards, and related Requirements 16
J GD&T - True Position - "Boundary" under the feature control frame General Measurement Device and Calibration Topics 10
D Procedure for Fixture Gages that check True Position of holes General Measurement Device and Calibration Topics 4
M How to calculate a True Position toleranced at MMC - Capability of True Position Statistical Analysis Tools, Techniques and SPC 12
D Cpk for one sided dimension - GD&T true position Capability, Accuracy and Stability - Processes, Machines, etc. 15
F Calibration certificate content - Average Value and True Value ISO 17025 related Discussions 6
A True purpose of doing EST (Electrical Safety Test) on medical device Other Medical Device Related Standards 3
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Marc The Strange & Curious Tale of the Last True Hermit Coffee Break and Water Cooler Discussions 0
