Trying to back up a dead hard drive - how to do it?
Jen Kirley
Quality and Auditing Expert
Hey all,
I am setting about making a Christmas surprise for my better half - to save the music files he's kept on a hard drive that has died, and wrap up the backup drive as a gift. Although he's very geeky, for some reason he has not tried very hard to save these files as far as I can tell.
I've been looking online and using a boot cd for Ubuntu and Xubuntu, but when the booted OS comes up I do not find the hard drive to copy onto the portable hard drive I've bought for this occasion.
Does anyone have some geeky advice for me? We have several old hard drives in a box and the same thing happens with every attempt to boot, which makes me think operator error is going on.
:cfingers:
If the hard drive has died, how can you copy anything from it? Or is that what you're asking? In general, you can't. There are reports of some success in bringing HDs back to life briefly after putting them in a freezer for a few hours. There are data recovery services that will pull an HD apart, remount the platters and attempt data recovery, but it's expensive.
Marc
Fully vaccinated are you?
Over the years I've had pretty good recovery results from drive crashes.
First off, I assume this is an internal drive in a tower PC. Is that correct?
I also assume it's a 3.5" ATA drive (or is it a SATA drive?).
No guarantee, but I've done a fair amount of data recovery over the years. I'll try to help. Just 2 weeks ago I saved 2TB of data from a crashed RAID drive set. Tell me some more details and I'll try to help.
Jen Kirley
I have three or four hard drives in a box to try, all I have to go on is what's on their labels. I have hooked each up in turn with an old tower we don't care about - it has a working CD ROM, I can't tell much else. So far, each I have hooked up and booted independently but none shows as a drive on the boot OS - this seems unlikely.
I have hooked all this up to an old Dell Dimension 4400 tower using his video, mouse and keyboard, not daring to do this evolution with his regular computer - I don't dare to be hooking up these old and drives and such with anything else but a throwaway machine. Egads, I am not very good at this but I would really like to make a nice go of it. :cfingers:
Marc
I've been looking online and using a boot cd for Ubuntu and Xubuntu <snip>
Can't help with Ubuntu and Xubuntu. What file systems do they use? NTSF?
I'm trying to think. On the Mac I have used Data Rescue to get my Mac to recognize crashed drives that would not mount. It's a recovery program so you need a drive to save to, and typically it has to be at least 1.5x larger than the drive to be recovered.
I've gone through this on Windows PCs but it's been several years. Jim is right that many times a drive cannot be recovered, but typically the electronics fail. It's rarely a platter issue.
But back to the issue, essentially you need a data recovery program which will probably involve Windows, which means there is the file system aspect.
The issues as I remember (Windows PC) had mostly to do with cable issues (sequence on the cable and the cable type its self) and the jumper position on the back (Slave vs. Master vs. 'Auto Select'). Now - This was on ATA drives. SATA drives are a different animal - There are no jumpers.
Anyway, if it's happening with several drives, it probably isn't a drive issue or it's a drive header corruption issue. Drive failure to mount is most typically a drive header corruption issue.
What size drives are these?
Jen Kirley
I have, according to the labels:
Maxtor - unknown size, with 16383 cylinders, 126 heads, 63 sectors
Western Digital, 60 GB with drive parameters LBA 117187500
Seagate Pin 1 J2TP from BUS
Very confusing - these are old drives.
Marc
Were the drives formatted NTSF?
I wish I had a lot of the info files I have on drives and settings (most of that stuff is stored in the barn these days) but the manufacturer sites should have their settings files.
This the business end of an typical ATA drive:
BTW - It's getting late here so I may be 'gone' for a while. If you want to continue on just let me know. It's a real rush when you recover data you thought was "gone forever".
Jen Kirley
Hmm, I am just hooking the drives up via a ribbon cable - the only other drive in the tower is a CDRom, from which I boot Ubuntu.
I have hooked up a jumper network cable to a laptop - I also have a USB backup hard drive, new in the box that I do not want to open up and use until I feel like I am actually able to download data.
Unlike with Xubuntu, this time with Ubuntu I can actually find one of these old drives in "places". Maybe I will go ahead and open up that backup hard drive box and give it a whirl - if I can't find a way to just transfer files to my laptop via that network cable.
In any case I feel closer now.
Jen Kirley
I've heard of that - putting them in the freezer, and I suggested that to Jeff but he seemed disinclined. But what I can't read tonight I will try the freezer with and plug them in tomorrow first thing - what can it hurt?
A young man at work encouraged me to Google the subject and try it myself, saying the methods have come a long way in the past few years. Last year I was prepared to spend a couple $hundred or so to retrieve this data, but based on this young man's encouragement I am giving it a whirl while the guys are off on their hunting trip.
howste
Thaumaturge
I think Marc has the right idea with the jumpers. Can you get into the system settings before the OS loads? If the hardware doesn't recognize the drive before you boot into the OS, then the software will never find it.
G Trying to get a financially reasonable ISO Certification Body Registrars and Notified Bodies 8
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
N Student trying to apply Lean Six Sigma on a Construction project in my thesis Lean in Manufacturing and Service Industries 3
S Beginner trying to OEM a medical device - Branded Electric Acupuncture Pen EU Medical Device Regulations 3
K Trying to figure out what satisfies a few aspects of IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 2
I Trying to explain some of the Management Review Inputs (AS9100D) Management Review Meetings and related Processes 10
S Trying to understand 7.2.1(d) of ISO 13485 - Medical Device User Training ISO 13485:2016 - Medical Device Quality Management Systems 8
M Help trying to explain accuracy procedure General Measurement Device and Calibration Topics 1
A Supplier trying to avoid RMA's Supplier Quality Assurance and other Supplier Issues 11
K Auditors are trying to drive this business General Auditing Discussions 36
P Value Stream Mapping - Trying to do Value Stream Mapping of our Products Lean in Manufacturing and Service Industries 3
M Trying to take current documentation and put it into ISO forms Document Control Systems, Procedures, Forms and Templates 1
J Trying to determine whether a steel plate is bowed with a Faro Arm Calibration and Metrology Software and Hardware 8
B I'm trying to write detailed Customer Service Work Instructions Customer Complaints 10
Mikishots Trying to locate a LEGIBLE MIL-STD-105E copy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Trying to fit a GLM - Minitab 16 negative Error df Using Minitab Software 4
2 Trying to Implement a Manufacturing Engineer Concept to my Company Manufacturing and Related Processes 5
P Trying to figure Minor ? on Female Rolled Threads Various Other Specifications, Standards, and related Requirements 1
E Our Lean Initiative Manager is trying to eliminate Final Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D Medical Device Packaging - Trying to learn Technical files EU Medical Device Regulations 4
Jim Wynne The Buell Blast: Trying to Make Chicken Salad out of Chicken Poop Coffee Break and Water Cooler Discussions 1
A A Quandary - Trying to do everything on a shoestring - Out The Door Numbers Career and Occupation Discussions 11
J Measuring Technique - Trying to measure on-time delivery turnaround Quality Tools, Improvement and Analysis 13
W Controlled Documents - Trying to differentiate document control levels Document Control Systems, Procedures, Forms and Templates 5
R Trying to decipher drawing - Hole Size Manufacturing and Related Processes 12
A CFO trying to turn Quality procedure for Purchasing into a purchasing manual ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N Cost of Rejected Components - Trying to pokayoke a process Quality Tools, Improvement and Analysis 1
O ANOVA Analysis - Trying to understand MSA analysis- Please review my spreadsheet Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 22
R Trying to develop ISO 9001 training for a newly certified company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Trying to find the actual ISO 17025:2005 standard requirements ISO 17025 related Discussions 6
H What I am trying to find is someone that remembers Memphis in the nineties Coffee Break and Water Cooler Discussions 10
V Minitab Pareto - Trying to plot a relation of Count and Cycle Time Using Minitab Software 5
L Kanban cards - Trying to initiate a true Pull System - Fastener Products Lean in Manufacturing and Service Industries 3
ScottK The Berry Amendment (Imposed by 10 U.S.C. 2533a) for DoD parts - Trying to decipher Various Other Specifications, Standards, and related Requirements 7
J Food Allergen Awareness Training - Trying to implement cGMP Training - Internal, External, Online and Distance Learning 1
T Internal QMS/ISO 'Contest' - I am trying to come up with a new awareness contest ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Attribute MSA calculation - Trying to find a form or software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J Analysis of Service life, Design life and Storage - Trying to find an example report Various Other Specifications, Standards, and related Requirements 2
Marc American alligator vs. Burmese python - Python Bursts After Trying to Eat Gator Coffee Break and Water Cooler Discussions 7
P Trying to automate analyses of data from production process using Quality Analyst Quality Assurance and Compliance Software Tools and Solutions 1
C CE mark - Trying to determine if our product needs CE approval CE Marking (Conformité Européene) / CB Scheme 8
S Novice quality manager trying to get AS9100 certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 32
G Trying to find CAS numbers - The Database of chemical substance information IATF 16949 - Automotive Quality Systems Standard 3
C API Q1 Quality Manual Example - Trying to convert an existing ISO 9001 QMS Oil and Gas Industry Standards and Regulations 30
G I am Lost - Trying to implement an ISO 9001:2000 QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
M BMW and MG Rover Customer Requirements - Trying to make a matrix Customer and Company Specific Requirements 6
R Trying to find an ISO 17025 accredited testing laboratory to verify our test results ISO 17025 related Discussions 14
J Electronic Signatures - We're trying 1" x 5" Digital Sign-on Pads Like UPS's Document Control Systems, Procedures, Forms and Templates 14
Gman2 Automotive PPM Requirements - Our customer is trying to demand a 100% 0 defect rate IATF 16949 - Automotive Quality Systems Standard 3
