Trying to understand 7.2.1(d) of ISO 13485 - Medical Device User Training
stm08007
I would really appreciate it if someone can give me some clear examples about what it means by saying organizations must determine and document whether any "user-training" is required?
Is a statement in the IFU saying something along the lines of "the healthcare provider must be trained to and understand these instructions" sufficient?
I keep getting hung up on this clause, so any input would be much appreciated!!:)
bjohnsonrli
Hi stm08007,
I would take a look at IEC 62366-1 Application of usability engineering to medical devices. Section 7 talks about training and materials for training required for the safe and effective use of a primary operation function of a device. Primary function is defined as a function that is directly related to the safety of the device or function that is frequently used. Examples they give are:
- inactivation of an alarm signal
- adjustable x-ray exposure parameters
- adjustable infusion parameters
- adjustable gas flow rates
As input into our design control, we use what we call a risk/safety questionnaire and consider questions related to intended use and reasonably foreseeable misuses. Information is then used as input into the design FMEA. If risk mitigation is to supply information for safety, its added to the IFU or labeling.
Hope this helps.
Regards,
Bryan
yodon
If you just drop the device on your customer's doorstep, can they use it? Are you introducing any new technology, new methods, new information? Will your customer base normally have the skills to use the device (e.g., if your delivering an ultrasound device, your users will typically be ultrasound operators).
I think those are the types of questions to ask to determine if there are any training requirements needed to ensure safe and effective use.
stm08007
I guess my followup question would be if you do determine there are "training requirements" needed, is it sufficient to merely document that in the IFU? We've had an auditor who had told us we can't count on a customer reading the IFU and automatically point to that whenever there's a use error identified
If there was a complaint filed where the customer was determined to have misused the product (meaning they did not follow the IFU), does this requirement mean you need to send someone to give your customer hands on training?
I think our IFU covers just about everything, however I was thinking (perhaps incorrectly) that this 7.2.1(d) might require something a bit more formal than the IFU. I wouldn't really call the IFU "training" per-say either--- just because you give someone a set of instructions doesn't mean they are "trained"
There is an IEC standard on training and training materials:
IEC TR 61258:2008
Guidelines for the development and use of medical electrical equipment educational materials
From the abstract of that:
In particular, manufacturers might find this process useful in preparing the necessary markings, accompanying documents and other educational materials which will provide necessary information to operators of the equipment and encourage them to employ safe and effective practices.
yodon
Bear in mind that 7.2.1(d) is, effectively, a design input. When you develop your product, are there requirements for training the end user. Per my previous post, if you're introducing something novel into the market, you're probably going to establish requirements for training. Those requirements would be elaborated as training materials, training courses, etc. Training is not, IMO, the role of the IFU. And the IFU is a design output.
This is exactly why the usability standard (62366) is getting more focus and the focus of several of the changes to 14971 (can't rely on labeling alone for risk reduction).
This brings the issue full circle. If you have a complaint then you need to assess it for risk, etc. If the complaint is with usability, you need to determine if the design is sufficient to ensure no hazards are realized and, if not, a design change is probably warranted. If you're following 62366, you'll have the tools in place to assess the UI and determine if this is a systemic issue or just a one-off. If systemic, you'll probably want to change the UI to reduce the likelihood of additional, similar complaints. If the UI is sound, you may then look to additional training methods.
We (in test) have a philosophy: if something can go wrong, there WILL be a user that will find it. IFUs are typically written from the 'expert' point of view, considering primarily the right way to do things. Users aren't so much the case! That's why the UI and design play such critical factors in usability and error prevention. Training is one tool in the toolbox but then you have to consider training effectiveness and training coverage (you may train one person in an office and then rely on them to train the rest of the staff... how effective can that be?).
Sorry for getting a bit off topic and babbling on about design stuff but, indeed, there's a big picture to consider when you talk about training and customer complaints.
bjohnsonrli
I'm going to assume we are talking about a prescription (Rx Only) device...
The manufacturer of a prescription device owes a duty to the physician to provide adequate information on how to properly use a device and about the risks associated. The physician owes a duty to the patient to apprise him/herself of the risk associated with a product and to exercise judgement in both the use of the device and informing the patient of the risk.
If you already haven't, take a look at GHTF/SG1/N70:2011 Label and Instructions for Use for Medical Devices. I'd post the link but I'm a few posts shy of being allowed to.
Your auditor's statement is correct. It's generally viewed as unacceptable to solely rely on the user to mitigate risk. I believe this comes from EN ISO 14971 in which the use of an information for safety (IFU, labeling, etc.) shall not atribute to any additional risk reduction.
You are probably correct in saying that your IFU covers everything and you may be overthinking things a bit.
Regards,
Bryan
Marcelo
These requirements sucks, I´ve tried several times to remove them from the drafts, but my fellow experts did not agree with me :(... My main problem with the requirements is that they are only determned at the end of design, and althought requirements related to product can be defined in any stage, it typically is defined in the beginning, so it may consuse a lot of people that do not clearly understand 7.2.1 and 7.2.2.
Anyway, the requirement is related to device design. It´s also be an output of the usability engineering of IEC 62366-1.
Training may be a requirement if the design of the device user interface identify the need for training for the safe use of the product.
So, to comply with this requirement, you would need to perform the usability process and verify (as per IEC 62366-1 requirements) if training is a requirement or not, and input this into your design process.
Marcelo
And yes, in the end you will also need to clearly specifiy the training requirements and how you
- provide the materials necessary for training;
- ensure that the materials necessary for training are available;
- make the training available; or
- make training available to the RESPONSIBLE ORGANIZATION that enables it to train its USERS
(again, as required by IEC 62366-1)
in the user manual, but the user manual information is onlçy the result of the entire process, so not, only putting it in the user manual is not enough.
O ANOVA Analysis - Trying to understand MSA analysis- Please review my spreadsheet Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 22
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
N Student trying to apply Lean Six Sigma on a Construction project in my thesis Lean in Manufacturing and Service Industries 3
S Beginner trying to OEM a medical device - Branded Electric Acupuncture Pen EU Medical Device Regulations 3
K Trying to figure out what satisfies a few aspects of IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 2
I Trying to explain some of the Management Review Inputs (AS9100D) Management Review Meetings and related Processes 10
M Help trying to explain accuracy procedure General Measurement Device and Calibration Topics 1
A Supplier trying to avoid RMA's Supplier Quality Assurance and other Supplier Issues 11
K Auditors are trying to drive this business General Auditing Discussions 36
P Value Stream Mapping - Trying to do Value Stream Mapping of our Products Lean in Manufacturing and Service Industries 3
M Trying to take current documentation and put it into ISO forms Document Control Systems, Procedures, Forms and Templates 1
J Trying to determine whether a steel plate is bowed with a Faro Arm Calibration and Metrology Software and Hardware 8
B I'm trying to write detailed Customer Service Work Instructions Customer Complaints 10
Mikishots Trying to locate a LEGIBLE MIL-STD-105E copy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Trying to fit a GLM - Minitab 16 negative Error df Using Minitab Software 4
2 Trying to Implement a Manufacturing Engineer Concept to my Company Manufacturing and Related Processes 5
P Trying to figure Minor ? on Female Rolled Threads Various Other Specifications, Standards, and related Requirements 1
E Our Lean Initiative Manager is trying to eliminate Final Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Jen Kirley Trying to back up a dead hard drive - how to do it? Coffee Break and Water Cooler Discussions 17
D Medical Device Packaging - Trying to learn Technical files EU Medical Device Regulations 4
Jim Wynne The Buell Blast: Trying to Make Chicken Salad out of Chicken Poop Coffee Break and Water Cooler Discussions 1
A A Quandary - Trying to do everything on a shoestring - Out The Door Numbers Career and Occupation Discussions 11
J Measuring Technique - Trying to measure on-time delivery turnaround Quality Tools, Improvement and Analysis 13
W Controlled Documents - Trying to differentiate document control levels Document Control Systems, Procedures, Forms and Templates 5
R Trying to decipher drawing - Hole Size Manufacturing and Related Processes 12
A CFO trying to turn Quality procedure for Purchasing into a purchasing manual ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N Cost of Rejected Components - Trying to pokayoke a process Quality Tools, Improvement and Analysis 1
R Trying to develop ISO 9001 training for a newly certified company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Trying to find the actual ISO 17025:2005 standard requirements ISO 17025 related Discussions 6
H What I am trying to find is someone that remembers Memphis in the nineties Coffee Break and Water Cooler Discussions 10
V Minitab Pareto - Trying to plot a relation of Count and Cycle Time Using Minitab Software 5
L Kanban cards - Trying to initiate a true Pull System - Fastener Products Lean in Manufacturing and Service Industries 3
ScottK The Berry Amendment (Imposed by 10 U.S.C. 2533a) for DoD parts - Trying to decipher Various Other Specifications, Standards, and related Requirements 7
J Food Allergen Awareness Training - Trying to implement cGMP Training - Internal, External, Online and Distance Learning 1
T Internal QMS/ISO 'Contest' - I am trying to come up with a new awareness contest ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Attribute MSA calculation - Trying to find a form or software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J Analysis of Service life, Design life and Storage - Trying to find an example report Various Other Specifications, Standards, and related Requirements 2
Marc American alligator vs. Burmese python - Python Bursts After Trying to Eat Gator Coffee Break and Water Cooler Discussions 7
P Trying to automate analyses of data from production process using Quality Analyst Quality Assurance and Compliance Software Tools and Solutions 1
C CE mark - Trying to determine if our product needs CE approval CE Marking (Conformité Européene) / CB Scheme 8
S Novice quality manager trying to get AS9100 certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 32
G Trying to find CAS numbers - The Database of chemical substance information IATF 16949 - Automotive Quality Systems Standard 3
C API Q1 Quality Manual Example - Trying to convert an existing ISO 9001 QMS Oil and Gas Industry Standards and Regulations 30
G I am Lost - Trying to implement an ISO 9001:2000 QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
M BMW and MG Rover Customer Requirements - Trying to make a matrix Customer and Company Specific Requirements 6
R Trying to find an ISO 17025 accredited testing laboratory to verify our test results ISO 17025 related Discussions 14
J Electronic Signatures - We're trying 1" x 5" Digital Sign-on Pads Like UPS's Document Control Systems, Procedures, Forms and Templates 14
Gman2 Automotive PPM Requirements - Our customer is trying to demand a 100% 0 defect rate IATF 16949 - Automotive Quality Systems Standard 3
T PFMEA for Heat Treat Service Provider - Trying To Develop RPNs FMEA and Control Plans 11
