TS 16949 - 8.5.2.4 - When are Corrective Actions required
stogsdill1
Hello all!... and thanks again for being here. We have recently moved up to a TS16949 QMS and are approaching our readiness audit. Since the TS revision to our quality manual, I have been requesting corrective action for all automotive-related RGA,s... even the one-offs. Our engineering manager has proposed that rather than issuing CA for each RGA, we pareto these one-off rejects, and issue CA when we see a trend. While, from a resource perspective, I like the idea... it doesn't seem to fit the requirement. As I read it, it is product specific and the product is what shall be issued CA.
Can I get a sanity check?
Thank you!!
CandidQuality
Re: 8.5.2.4- are corrective actions required
If you stop and create a written system of what will be evaluated, when it will be evaluated, who will be responsible for the action, what are the triggers for the action, you can do well with that system. If you leave it to chance that someone will notice a random trend, and then their opinion of what is important differs from yours, you will spiral down the wrong path. Set a system in place, do not leave it up to an individual(or their unqualified replacement). Set up a yearly review of that system to ensure that it is still meeting the current needs of the company. Not just a check box, but some type of measurable data. Did your lack of action on a single incident result in an additional 20 errors of the same type before it was taken seriously enough to be an issue? What was the potential impact to your company? There should also be exceptions with some consensus. if that single error is with a new supplier with a potential to provide future business of 30% of your net next year, you might want to coddle it and pay special attention.
Bottom line. Create a system, review it annually (once stable) and be prepared to make exceptions above and beyond when needed.
stogsdill1
Thanks Candid,
I get what you're saying about the bottom line, i.e...creating a system, reviewing in, making exceptions. However, my concern is that the spec seems to define said system as the corrective action procedure.
"The organization shall perform analysis and initiate corrective action to prevent recurrence".
A system such as a pareto, followed by CA if a trend is identified does not meet the spec as I read it.
I want to be wrong here, please convince me.:thanx:
Sidney Vianna
Post Responsibly
As I see it, 8.5.2.4 does not negate nor override 8.5.2 c) which gives the organization the latitude to determine if and when a corrective action is truly justified.
Not every nonconforming product requires a corrective action, not even a returned product from the customer. As we know, many times, at the completion of an alleged product failure analysis, the supplier can not replicate the failure. Sometimes, the problem is the customer and not the product.
Pjservan
There is wiggle room in 8.5.2.4. As long as you are able to show results of an analysis and a justification to not issue a Corrective Action you should be OK. Your process will basically determine if corrective action is needed on a case by case basis (you can define criteria around this) as well as a secondary review based on data collection over time.
O
outoftown
I would be wary of using a pareto to generate CARs. There needs to some accounting for risk or impact of the RGA item to the customer, to you and to the end consumer. Cost may also be a factor.
Best way to handle this is to separate the line accumulations (normal industry accepted fallout, e.g. porosity issues in castings), that should be addressed as returns for credit in your contract and therefore not subject to a corrective action. Other RGAs can be eliminated from CARs because it may be for a return to stock from excess inventory from the customer.
In my audit trails, I look at RGAs vs CARs occasionally for a reality check, but most CARs come from four sources; customer complaints, internal audit findings, supplier corrective actions and internal issues other than from internal audits. If you want to include RGAs, I would ask the customer requesting the RGA if they want a corrective action also. After all, why go through the entire CAR process if the customer doesn't want to see it?
Note, that you are still obligated to do failure analysis on returned product.
-outoftown, TS auditor
A Control plans - TS 16949:2002 requires corrective actions to be addressed FMEA and Control Plans 21
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
R Corrective Action for Nonconformity in ISO/TS 16949 Recertification Audit IATF 16949 - Automotive Quality Systems Standard 2
M TS 16949 clause 8.5.2 - Corrective Action - Need to some clarifications IATF 16949 - Automotive Quality Systems Standard 4
A TS 16949 Type of Corrective and Preventative Action Procedure wanted Document Control Systems, Procedures, Forms and Templates 3
C Corrective action in control plan per Annex A of ISO/ TS 16949: 2002 standard FMEA and Control Plans 4
J TS 16949 8.5.2 Corrective Action - Auditor did not like the customer related form Nonconformance and Corrective Action 13
A TS 16949 Corrective Action Impact - Difference between Preventive Action and CI? Nonconformance and Corrective Action 7
L IATF 16949 8.3 Exclusions Manufacturing and Related Processes 3
H Clause matrix for 16949 IATF 16949 - Automotive Quality Systems Standard 3
D IATF 16949 7.3.1 Awareness- Supplemental IATF 16949 - Automotive Quality Systems Standard 2
Q IATF 16949 8.4.2.4 Supplier Monitoring IATF 16949 - Automotive Quality Systems Standard 2
J Implementation, establishment and certification of IATF 16949. IATF 16949 - Automotive Quality Systems Standard 6
xfngrs 3 year audit cycle IATF 16949 IATF 16949 - Automotive Quality Systems Standard 10
D IATF 16949 Process Map IATF 16949 - Automotive Quality Systems Standard 19
Vader22 IATF 16949 extended manufacturing site help IATF 16949 - Automotive Quality Systems Standard 4
D IATF 16949 Certification and Letter of Conformance expiry (Help!!!) IATF 16949 - Automotive Quality Systems Standard 8
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
T Justification of "Design Excluded" in IATF 16949 Design and Development of Products and Processes 5
Sidney Vianna Job Opening in the USA - IATF 16949 Lead Auditor Position Job Openings, Consulting and Employment Opportunities 0
Ron Rompen IATF 16949 8.5.1.4 IATF 16949 - Automotive Quality Systems Standard 7
P IATF 16949:2016 Letter of conformity IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 SI 10, External non-accredited lab IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 M&TE Laboratory scope IATF 16949 - Automotive Quality Systems Standard 7
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
D Bulk Materials (Greases) and IATF 16949 IATF 16949 - Automotive Quality Systems Standard 11
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 18
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 4
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 11
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 2
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
