TS 16949 - A2LA or ISO/IEC 17025 required for material testing?
QMMike
Hello Cover's :)
I'm having some of our materials tested and had this thought....
Normally I send raw materials from our suppliers to an outside lab (Smither's or ARDL - both A2LA or ISO/IEC 17025 accredited) which costs us a substantial amount of money when having all our compounds tested - I know we should look into charging this back to our supplier but bear with me........
Here is my thought -
We are a TS16949:2009 registered company and have been registered to TS almost since the standard was published. In regards to laboratories, all outside labs are required to be ISO/IEC 17025 registered or national equivalent. However, I have a temperature controller that we use internally to calibrate thermo-couples. This temperature controller I send back to the manufacturer for calibration of the unit. The manufacturer does not have a registered lab but since they are the OEM of the unit, their certifying it was enough evidence to satisfy our requirement. I think it is mainly accepted because of 7.6.3.1 of TS16949:2009 - "NOTE - Accreditation to ISO/IEC 17025 may be used to demonstrate the organization's in-house laboratory to conformity to this requirement but is not mandatory". Since they are qualifying their own equipment in their own internal lab - it's allowed.
Which made me think -
Only one of our material suppliers have an A2LA lab, theirs is a no brainer. I could call them up and have them test their own materials and supply a cert. What about our other material suppliers? Since they are the OEM of the material, as is the case with my temperature controller, would this be evidence enough?
G
George Weiss
Re: A2LA or ISO/IEC 17025 required or not in this case
There was a time, (pre-2005),when the original manufacturer was the best place to take your equipment. It was the first course suggested. Then 17025 became required in some situations. If there was no source for 17025 then the original manufacturer was accepted by A2LA for their Z540 etc. calibration. Today A2LA has pressed for any source for 17025 over the original manufacturer of equipment, if said manufacturer could not produce 17025 level calibration. This has had the effect of some late increases to 17025 by some manufacturers in some areas of scope. In short, I would ask A2LA for your specific issue, but generally you are expected to get the equipment calibrated to 17025, and that would mean not your original equipment source.
A temperature controller calibration is generally a DCmV stimulus calibration, with various calibrator manufacturer sources. Having an onsite service by a local facility would be an easy effort. A service for such an item would range from $200-$400 depending on number of channels, recording features and etc. Specifying your calibration requirements sometimes develops a more effective calibration. There is a large window of acceptable 17025 calibration specifics, subject to customer/cal-lab agreement.
Limited scope 17025 Calibrations: Are process lean/cost-effective. If you only need the temperature feature 17025 calibrated, for use in your process, then the humidity feature can be Z540 w/o data, and be acceptable.
Demonstrating conformity means having it done 17025 or doing it 17025. The manner can be add-hock, but add up to 17025.
17025 is flexable to actual needs, in this case being TS 16949.
You have options.
QMMike
Thanks for the response George. I'm good with the temperature controller, but my question concerns the testing of my raw materials to an ASTM standard (my thoughts in my head were clear - how they translated onto the post was clear.... as mud :) )....
I was thinking that since sending my temperature controller back to the OEM was acceptable - under that same principle, sending raw material back to the OEM be just as acceptable?
G
George Weiss
You are in the FDA kingdom I believe.
I offer:
I am in the same posture with either case. outside support is 17025.
I would view the following as direction also:
referenced @
http://www.askartsolutions.com/ts16949/Control-Of-MMD.html
7.6.3.2 External/commercial/independent Labs (raw material suppliers/testing labs also)
Where you use an external, commercial or independent laboratory for inspection, test or calibration services, it shall have a defined laboratory scope that includes its capability to perform the inspection, test or calibration services you require.
The costs of an FDA "FIX" are always higher than prudent process course.
bazboy
You could conduct an audit on the supplier to ensure they are complying with your agreement/contract.
howste
Thaumaturge
<snip> The manufacturer does not have a registered lab but since they are the OEM of the unit, their certifying it was enough evidence to satisfy our requirement. I think it is mainly accepted because of 7.6.3.1 of TS16949:2009 - "NOTE - Accreditation to ISO/IEC 17025 may be used to demonstrate the organization's in-house laboratory to conformity to this requirement but is not mandatory". Since they are qualifying their own equipment in their own internal lab - it's allowed.
Hi Mike. :bigwave: Sorry for the late response, but I just ran across this thread today. I have to disagree with your argument above. The relevant requirement in the standard is 7.6.3.2, not 7.6.3.1. It states:
ISO/TS 16949:2009 said:
7.6.3.2 External laboratory
External/commercial/independent laboratory facilities used for inspection, test or calibration services by the organization shall have a defined laboratory scope that includes the capability to perform the required inspection, test or calibration, and either
- there shall be evidence that the external laboratory is acceptable to the customer, or
- the laboratory shall be accredited to ISO/IEC 17025 or national equivalent.
NOTE 1 Such evidence may be demonstrated by customer assessment, for example, or by customer-approved second party assessment that the laboratory meets the intent of ISO/IEC 17025 or national equivalent.
NOTE 2 When a qualified laboratory is not available for a given piece of equipment, calibration services may be performed by the equipment manufacturer. In such cases, the organization should ensure that the requirements listed in 7.6.3.1 have been met.
Note 2 only applies to calibration, and there is no equivalent statement for material testing. Also the use of an unaccredited OEM is only allowed when an ISO 17025 accredited lab isn't available or the customer(s) approve the lab.
Ron Rompen
An interesting thread to come across, since I just completed an audit where something touching on this was the subject of an OFI.
We require our suppliers (eg steel coil) to PPAP their products to us, and then use that supplier certification in our PPAP submission to our customer. The supplier is registered to TS 16949.
Our auditor questioned whether or not we had a copy of the suppliers lab scope which included the testing performed. I had never been asked this before, but it did raise the thought within our group.
If a supplier is TS registered, AND includes the testing in their lab scope, this would qualify them under 7.6.3.1, and there would be no reason to go to an external lab at all. The TS registration document would serve as evidence that (at some point) their lab scope had been assessed (by the registrars auditors) and found to be compliant.
Anyone else have any thoughts on this?
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
T Justification of "Design Excluded" in IATF 16949 Design and Development of Products and Processes 5
Sidney Vianna Job Opening in the USA - IATF 16949 Lead Auditor Position Job Openings, Consulting and Employment Opportunities 0
Ron Rompen IATF 16949 8.5.1.4 IATF 16949 - Automotive Quality Systems Standard 7
P IATF 16949:2016 Letter of conformity IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 SI 10, External non-accredited lab IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 2
D IATF 16949 M&TE Laboratory scope IATF 16949 - Automotive Quality Systems Standard 7
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
D Bulk Materials (Greases) and IATF 16949 IATF 16949 - Automotive Quality Systems Standard 11
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 18
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 4
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 11
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 2
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
H Remote product audits in Coivd-19 - IATF 16949 9.2.2.4 IATF 16949 - Automotive Quality Systems Standard 3
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Postpone IATF 16949 audit due to COVID-19 IATF 16949 - Automotive Quality Systems Standard 41
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
T Reaction Plan To Drive suppliers to IATF 16949 registration IATF 16949 - Automotive Quality Systems Standard 6
