TS 16949 - AIAG's MSA Manual - Thread Inspection Gage - Attribute Gage R&R
theace
Hello all!
I´m fairly new to TS and MSA. We are trying to do MSA for thread inspection with gage (go-nogo).I downloaded Excel charts some of you have made for attribute test from this forum.
I read attribute test from MSA manual 3rd edition and it differs little from those dowloaded ones. In MSA manual they use this kappa measure and use 50 samples and 3 trials and so on. Do you have to do this test exactly according to MSA manual in order to satisfy auditors or is it enough if you do it like in these excel programs?
Regards to all
Marko
D.Scott
Welcome to the Cove Marko.
I believe the Excel programs found here would be satisfactory. The requirement is to do an MSA, but doesn't require a certain one is followed. As long as the study is statistically sound I don't think an auditor would have a problem with it. There are many commercial and privately written programs for MSA and I doubt that any are exactly alike.
Dave
howste
Thaumaturge
TS 16949 says in 7.6.1:
Statistical studies shall be conducted to analyse the variation present in the results of each type of measuring and test equipment system. This requirement shall apply to measurement systems referenced in the control plan. The analytical methods and acceptance criteria used shall conform to those in customer reference manuals on measurement systems analysis. Other analytical methods and acceptance criteria may be used if approved by the customer.
To me, that says you should follow the customer's manual unless the customer approves an alternate method. An auditor would have to be pretty thorough to notice the difference though...
Atul Khandekar
Welcome to the Cove, Marko!
Dave is right that there is no 'strict' requirement of 50 parts - more the merrier, though :). IMO, it depends on what you want to achieve from the study.
If it's a CrossTab study, where we are trying to determine the interrator agreement, you should select parts where all operators agree, and should also include parts near spec limits, ie in the zone of possible disagreement.
If you are using the Signal Detection method, where we need to identify and quantify the width of the "Gray zone" of the gage and %R&R, you need to select parts that cover the entire spectrum:
1. Unacceptable parts on both sides of the spec limits (the '-' zone on BOTH sides - rejected by all apraisers),
2. Parts from the 'Gray Zone' (near the spec limits where appraisers are likely to have some disagreement) and
3. Parts within specs (accepted by all appraisers)
IMO, You can start your study with maybe even 20 parts and go on adding parts till you get satisfactory coverage. I have seen cases where customers recommended a minimum of 20 or 30 parts - you can also ask your customer.
For Analytical method however, the MSA manual is much more prescriptive in terms of number of parts and method of parts selection.
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
V IATF Auditor Guide for TS 16949 for sale at the AIAG store IATF 16949 - Automotive Quality Systems Standard 1
M VDA, AIAG & ISO TS 16949 Standards Differences VDA Standards - Germany's Automotive Standards 1
Stijloor Auditor Guide for ISO/TS 16949 available from AIAG IATF 16949 - Automotive Quality Systems Standard 1
D TS 16949 and Control Plans - Need Tier II/III follow AIAG Annex A Format? IATF 16949 - Automotive Quality Systems Standard 27
Douglas E. Purdy Tracing TS 16949 Requirements to AIAG Reference Manual during an Audit General Auditing Discussions 10
P TS 16949 AIAG books needed for learning the requirements of the standard IATF 16949 - Automotive Quality Systems Standard 12
S AIAG's Control Plan Reference Manual - GONE from TS 16949 as a referenced document? IATF 16949 - Automotive Quality Systems Standard 9
Crusader AIAG TS 16949 Audit Checklist - Obsolete IATF 16949 - Automotive Quality Systems Standard 11
Q Release of AIAG's CQI-7: ISO/TS 16949 Implementation Guide IATF 16949 - Automotive Quality Systems Standard 21
S Where can I buy the TS 16949 standard? The AIAG is expensive! IATF 16949 - Automotive Quality Systems Standard 9
Marc Honda and ISO / TS 16949 - AIAG, ANFIA, FIEV, JAMA, SMMT and VDA VDA Standards - Germany's Automotive Standards 13
R AIAG release of TR 16949 IATF 16949 - Automotive Quality Systems Standard 12
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 0
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
H Remote product audits in Coivd-19 - IATF 16949 9.2.2.4 IATF 16949 - Automotive Quality Systems Standard 3
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Postpone IATF 16949 audit due to COVID-19 IATF 16949 - Automotive Quality Systems Standard 41
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
T Reaction Plan To Drive suppliers to IATF 16949 registration IATF 16949 - Automotive Quality Systems Standard 6
B IATF 16949 - Is a Deviation required for sample components in a prototype build? IATF 16949 - Automotive Quality Systems Standard 13
