TS 16949 Clause 6.2.2.4 - Employee Motivation and Empowerment Procedure
#11
SteelWoman said:
We've written into our procedure the "ongoing" measure of competency, but I do think I'm going to try the grandfather (db, sorry for the use of that term again! :D) clause - see if it flies. I think it should, based on the standard.
Provided you are not trying to apply grandfathering to Employee motivation and empowerment, I would agree.
SteelWoman
#12
Nope, only to the issue of competence UP TO THIS POINT. From this point forward of course we'll continue to judge competence (though hopefully not mine, since mine is questionable at best! :D)
K
Karen R
#13
grandfathering...
We were told during training that grandfathering was OUT and we could not use that like we did with QS - that we have to 'demonstrate competence' and our registrar seemed to indicate the same thing during our last QS audit.
Of course we dont' have a better answer yet - too bad your audit isn't before mine!!
#14
It may be in the way you are trying to use it. The example I use is a welder in a fab shop. Because his/her output has been satisfactory over a number of years, I can easily say that based on past experience the welder has demonstrated competence. I do not need to perform an annual assessment for competency, because I do that with every job. Remember, as time passes, some skills will deteriorate. My eyes are not as good as they used to be and my hands are less stable. But the competency is validated in my daily welding activities.
This does not apply to all competencies, and some may need annual appraisals. But I suspect the majority do not.
SteelWoman
#15
We phrased it this way in our Training procedure:
"Similarly, employees who attained their job classifications prior to November 2003 were "grandfathered" into those classifications under TS16949 since adequate methods of judging "competence" (primarily performance evaluations) were in place prior to the implementation of TS. These employees are considered competent and qualified to perform the duties associated with their job descriptions at the time. On-going competency is routinely judged through the methods outlined in 5.2 (below)".
Randy Stewart
#16
I agree with db. My initial response to an auditor would be "You want What?" 6.2.2.4 asks for a process, well we motivate our employees by publicly flogging one a day while making the others recite our quality policy. In that way we motivate them not to screw up or off and we are promoting quality throughout the organization.
Really, if a manager or someone in authority considers them competent then the auditor can't tell you their not.
I have never run into a problem with this portion of the standard whether QS or ISO. :frust: :bonk:
#17
Ahh yes, but one of my major points is that motivation (6.2.2.4) and competence (6.2.2, 6.2.2.1, 6.2.2.2, 6.2.2.3) are two entirely different things. You can motivate incompetent workers, and you can demotivate competent ones. There may be some connection (competent workers tend to be more self-motivated?), we are mixing fruit (so let's make fruit coctail)
Randy Stewart
#18
I understand, all I'm saying is that if I decide that Joe Smuckatelli can operate the copier then who is the auditor to tell me that I'm wrong? (unless he finds a way to blow the thing up while the auditor is using it - then again how would he know that it wasn't on purpose?)
We have people that have been here for 10 - 20 years and we decided based on experience that they were competent. I shouldn't need a statement in my procedure allowing me to do that. That's all. :ca:
SteelWoman
#19
Agreed. It absolutely DEFIES LOGIC that employees who are competent one day are suddenly "suspicious" or INcompetent the day you implement TS. We entered that line in our Training procedure because it's been a successful tool in audits, to answer the auditor's question before they get the chance to ask it.
Likes: db
#20
Absolutely. :agree:
BTW, I would never disagree with someone with as many green dots as you have. :smokin:
D Employee Motivation and Empowerment - TS 16949 Clause 6.2.2.4 IATF 16949 - Automotive Quality Systems Standard 11
L How do you accomplish TS 16949 Clause 6.2.2.4? Employee Motivation and Awareness Training - Internal, External, Online and Distance Learning 4
R Innovation - TS 16949 requirement? Clause 6.2.2.4 Employee Motivation and Empowerment IATF 16949 - Automotive Quality Systems Standard 5
D ISO 16949 Clause 4.1.6 - Employee motivation in a low skilled workforce Preventive Action and Continuous Improvement 20
P IATF 16949 Clause 8.4.2.3 - Justification for non-certified suppliers IATF 16949 - Automotive Quality Systems Standard 14
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
R Material safety data sheet (MSDS) related clause in IATF 16949 manual IATF 16949 - Automotive Quality Systems Standard 17
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
QChas IATF 16949 Clause 8.5.1.2 - C -Standardized Work IATF 16949 - Automotive Quality Systems Standard 1
N Looking for input on the attached Process / IATF 16949 Clause Matrix IATF 16949 - Automotive Quality Systems Standard 4
R IATF 16949 Clause 6.1.2.1 - Lessons Learned and Risk Analysis IATF 16949 - Automotive Quality Systems Standard 6
L IATF 16949 Clause 9.2.2.2 Quality Management System Audit IATF 16949 - Automotive Quality Systems Standard 9
H IATF 16949 Clause 9.2.2.2 Audit System / CSR IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 clause 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
P Interesting Discussion IATF 16949:2016 Clause 9.2.2.3 and Layered Process Audits IATF 16949 - Automotive Quality Systems Standard 18
M Reference to IATF 16949 clause 8.4.3 in clause 8.3.4.4, Is it right? IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 Clause 8.3.5.2 sub-clause (l) - Process maintainability requirements IATF 16949 - Automotive Quality Systems Standard 15
J IATF 16949 Clause 9.3.2.1 - How to understand "measures" IATF 16949 - Automotive Quality Systems Standard 4
J How to address IATF 16949 clause 5.1.1.1 in my Quality Manual IATF 16949 - Automotive Quality Systems Standard 6
B IATF 16949 clause 8.3.4.3 Prototype programme IATF 16949 - Automotive Quality Systems Standard 0
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
A Escalation Process - IATF 16949 Clause 4.4.1.2 IATF 16949 - Automotive Quality Systems Standard 11
E IATF 16949 Clause of 8.4.3 - Approvals - Can you explain to me IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Clause 9.2.2.2 - Which QMS Processes are Included IATF 16949 - Automotive Quality Systems Standard 1
J What are sample documents of IATF 16949 Clause 8.6.4 a? IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Clause 8.3.3.3 - Documentation of all Special Characteristics in Drawings IATF 16949 - Automotive Quality Systems Standard 2
B IATF 16949 Section Clause 8.3.4.1 - Monitoring - Design and Development Input(s) IATF 16949 - Automotive Quality Systems Standard 3
B IATF 16949 Clause 8.6.2 - Layout Inspection and Functional Testing IATF 16949 - Automotive Quality Systems Standard 13
B IATF 16949 Clause 9.3.2.1 - Management Review Inputs IATF 16949 - Automotive Quality Systems Standard 1
T Customer Authorization for Concession - IATF 16949 Clause 8.5.1.1 IATF 16949 - Automotive Quality Systems Standard 3
W IATF 16949 Clause 8.4.2.4.1 Second Party Audits (Supplier Management) IATF 16949 - Automotive Quality Systems Standard 45
T Record Retention Requirements - IATF 16949 Clause 7.5.3.2.1 Records and Data - Quality, Legal and Other Evidence 15
B IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change) IATF 16949 - Automotive Quality Systems Standard 24
T Temporary Change of Process Controls - IATF 16949 Clause 8.5.5.1.1 IATF 16949 - Automotive Quality Systems Standard 16
B IATF 16949 Clause 8.4.1.2 - Supplier Selection Process - Service Providers IATF 16949 - Automotive Quality Systems Standard 13
J IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition - Scrap Rendered Unusable IATF 16949 - Automotive Quality Systems Standard 64
M IATF 16949 Clause 4.4.1.2 - Product Safety - Concept of the Title IATF 16949 - Automotive Quality Systems Standard 4
M IATF 16949 Clause 7.1.5.1.1 - What are "inspection equipment systems"? IATF 16949 - Automotive Quality Systems Standard 4
P Setup Verification in IATF 16949 Clause 8.5.1.3 IATF 16949 - Automotive Quality Systems Standard 6
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
J IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition Compliance IATF 16949 - Automotive Quality Systems Standard 38
M Exclusion of IATF 16949 Clause 4.4.1.2 - Product Safety IATF 16949 - Automotive Quality Systems Standard 2
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
M IATF 16949 Clause 4.4.1.2 - Product Safety IATF 16949 - Automotive Quality Systems Standard 13
M Compliance with IATF 16949 Clause 8.3.4.4 Product Approval Process IATF 16949 - Automotive Quality Systems Standard 2
dubrizo IATF 16949 Clause 8.7.1.6 - Customer Notification - Your Inputs Requested IATF 16949 - Automotive Quality Systems Standard 4
P IATF 16949 Clause 8.5.6.1.1 - Temporary Change of Process Controls IATF 16949 - Automotive Quality Systems Standard 21
M IATF 16949 Clause 8.3 - Rework Records Requirements IATF 16949 - Automotive Quality Systems Standard 1
