TS 16949 Clause 7.6 Control of Monitoring and Measuring Devices
Rae Xu
7.6 control of monitoring and measuring devices
what is the difference between monitoring device and measuring device?If there is a device such as thermometer on the production equipment, not on the inspection instrument, what kind of device it is?
SilverHawk
Only measuring device has two factors - the reading and the user. For that rasional, only measuring device is called for GR & R.
Whereas the monitoriuing device has one factor - that's only giving the reading. So not GR & R is required... but to whether the monitoring device need calibration. look into the degree of usage..
If the "monitoring" device" has an affect on the quality of the product, it requires calibration.
SteelWoman
It depends on what the device is doing for you and what you use the results for. We have some inline/continuous monitoring devices that an operator can kind of keep an eye on to see if, for instance, the thickness of the sheet passing through is going haywire, but in the end we use standard micrometers and such to record the actual readings of the thickness that then get recorded as our final product characteristic. We R&R the micrometers, but not the isotope monitoring device.
jbGUERRA
Calibration under 7.6 Control of monitoring and measuring devices section (a)
During a supplier audit I found the supplier with gage pins that were not being sent out for calibration. The suppliers response, "we send out our gage blocks for calibration which is used to calibrate our calipers which we use the certify the gage pins." My question, is this acceptable?
jbG.
D.Scott
Welcome to the Cove.
7.6 (a) states measuring equipment shall "be calibrated or verified at specified intervals, or prior to use, against measurement standards traceable to international or national standards"
As long as the gage blocks are traceable to (example) NIST, the supplier could establish a working standard (the calipers) then verify the pins with that standard. IMHO, if the pins weren't verified before every use using the working standard, I would expect to see them listed in the calibration records showing the frequency of verification along with the other calibration records. BTW, the uncertainties for each of the gages is accumulative back to the NIST standard and should be considered when judging the effectiveness of their verification. It could be possible after stacking uncertainties that the pins become unsuitable for the measurement being done.
I would not, if the supplier's calibration method is suitable/effective and can be confirmed, expect them to send out the pins for calibration. There is no requirement to send a gage "out" although that is the readily accepted method of establishing traceability.
Dave
Dave
jbGUERRA
7.6
Based on your response the supplier would be accountable for the condition of each gage pin and its frequency of use to determine wear per their gage calibration report, correct? I would question the suppliers’ ability to certify the accuracy of the gage pins when they don't have an accredited laboratory environment that complies to IEC17025. Would I be out of line to issue them a Corrective Action based on my lack of confidence in them because they push the envelope of interpretation for this element?
It all depends on the measurements. If the pins are being used for measurements that are beyond the sensitivity of the standards used to calibrate them, then there's an obvious problem. On the other hand, in many cases the calibration process for pins involves not much more than cleaning and checking for damage that might affect measurements. In every case, before a gage is selected for use someone needs to verify that the gage is appropriately sensitive and that the standards used to calibrate it were as well.
G
gaugefixer
Are you trying to bankrupt your supplier? Sending out a gauge pin library to an ISO 17025 lab to have them calibrated would probably cost them just as much as a new set. These are gauge pins (which usually have a tolerance of .0002") that can be measured with a mic and compared to gauge blocks with a mic.
You do not nbeed to have an "accredited 17025 lab environment" to measure gauge pins and compare them to traceable calibrated gauge blocks.
If i was too have no confidence in a suppliers methods of calibrating gauge pins with .0002" tolerance; then i doubt the'yd be able to calibrate anything.
B IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change) IATF 16949 - Automotive Quality Systems Standard 24
M How to Control Nonconforming Product? TS 16949 Clause 8.3 IATF 16949 - Automotive Quality Systems Standard 2
A PFMEA and Control Plan Connections - TS 16949 Clause 7.3.3.2 FMEA and Control Plans 24
T TS 16949 Clause 7.5.1.1 - Audit Finding - Control Plan Requirements IATF 16949 - Automotive Quality Systems Standard 11
Douglas E. Purdy Control of Disposition of Records - Record Retention - TS 16949 Clause 4.2.4.1 Records and Data - Quality, Legal and Other Evidence 8
J Change Control - Product Realization example procedure - TS 16949 Clause 7.1.4 Document Control Systems, Procedures, Forms and Templates 4
D Change Control Procedure and form / template - TS 16949 Clause 7.1.4 IATF 16949 - Automotive Quality Systems Standard 1
Y TS 16949 Clause 7.3.6.2 Prototype programme and control plan IATF 16949 - Automotive Quality Systems Standard 5
R TS 16949 - Clause 4.2.3 - Identification and Control of Documents of External Origin IATF 16949 - Automotive Quality Systems Standard 15
S TS 16949 Clause 7.5.1.1 - Control Plan - Control Plans required for ALL processes? IATF 16949 - Automotive Quality Systems Standard 2
P IATF 16949 Clause 8.4.2.3 - Justification for non-certified suppliers IATF 16949 - Automotive Quality Systems Standard 14
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
R Material safety data sheet (MSDS) related clause in IATF 16949 manual IATF 16949 - Automotive Quality Systems Standard 17
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
QChas IATF 16949 Clause 8.5.1.2 - C -Standardized Work IATF 16949 - Automotive Quality Systems Standard 1
N Looking for input on the attached Process / IATF 16949 Clause Matrix IATF 16949 - Automotive Quality Systems Standard 4
R IATF 16949 Clause 6.1.2.1 - Lessons Learned and Risk Analysis IATF 16949 - Automotive Quality Systems Standard 6
L IATF 16949 Clause 9.2.2.2 Quality Management System Audit IATF 16949 - Automotive Quality Systems Standard 9
H IATF 16949 Clause 9.2.2.2 Audit System / CSR IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 clause 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
P Interesting Discussion IATF 16949:2016 Clause 9.2.2.3 and Layered Process Audits IATF 16949 - Automotive Quality Systems Standard 18
M Reference to IATF 16949 clause 8.4.3 in clause 8.3.4.4, Is it right? IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 Clause 8.3.5.2 sub-clause (l) - Process maintainability requirements IATF 16949 - Automotive Quality Systems Standard 15
J IATF 16949 Clause 9.3.2.1 - How to understand "measures" IATF 16949 - Automotive Quality Systems Standard 4
J How to address IATF 16949 clause 5.1.1.1 in my Quality Manual IATF 16949 - Automotive Quality Systems Standard 6
B IATF 16949 clause 8.3.4.3 Prototype programme IATF 16949 - Automotive Quality Systems Standard 0
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
A Escalation Process - IATF 16949 Clause 4.4.1.2 IATF 16949 - Automotive Quality Systems Standard 11
E IATF 16949 Clause of 8.4.3 - Approvals - Can you explain to me IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Clause 9.2.2.2 - Which QMS Processes are Included IATF 16949 - Automotive Quality Systems Standard 1
J What are sample documents of IATF 16949 Clause 8.6.4 a? IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Clause 8.3.3.3 - Documentation of all Special Characteristics in Drawings IATF 16949 - Automotive Quality Systems Standard 2
B IATF 16949 Section Clause 8.3.4.1 - Monitoring - Design and Development Input(s) IATF 16949 - Automotive Quality Systems Standard 3
B IATF 16949 Clause 8.6.2 - Layout Inspection and Functional Testing IATF 16949 - Automotive Quality Systems Standard 13
B IATF 16949 Clause 9.3.2.1 - Management Review Inputs IATF 16949 - Automotive Quality Systems Standard 1
T Customer Authorization for Concession - IATF 16949 Clause 8.5.1.1 IATF 16949 - Automotive Quality Systems Standard 3
W IATF 16949 Clause 8.4.2.4.1 Second Party Audits (Supplier Management) IATF 16949 - Automotive Quality Systems Standard 45
T Record Retention Requirements - IATF 16949 Clause 7.5.3.2.1 Records and Data - Quality, Legal and Other Evidence 15
T Temporary Change of Process Controls - IATF 16949 Clause 8.5.5.1.1 IATF 16949 - Automotive Quality Systems Standard 16
B IATF 16949 Clause 8.4.1.2 - Supplier Selection Process - Service Providers IATF 16949 - Automotive Quality Systems Standard 13
J IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition - Scrap Rendered Unusable IATF 16949 - Automotive Quality Systems Standard 64
M IATF 16949 Clause 4.4.1.2 - Product Safety - Concept of the Title IATF 16949 - Automotive Quality Systems Standard 4
M IATF 16949 Clause 7.1.5.1.1 - What are "inspection equipment systems"? IATF 16949 - Automotive Quality Systems Standard 4
P Setup Verification in IATF 16949 Clause 8.5.1.3 IATF 16949 - Automotive Quality Systems Standard 6
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
J IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition Compliance IATF 16949 - Automotive Quality Systems Standard 38
M Exclusion of IATF 16949 Clause 4.4.1.2 - Product Safety IATF 16949 - Automotive Quality Systems Standard 2
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
