TS 16949 Clause 8.2.4.1 - Yearly Layout Inspection Requirements
Helmut Jilling
Auditor / Consultant
#11
I would like to add a question, may I? :D
What is the way to inform customer if requirements are not met in a layout inspection?
Still I have two cases that I'll explain:
1 - A layout inspection is done and some of the drawing specifications didn't match (e.g. diameter below spec.). This specifications are not critical or safety characteristics. Should I inform customer or just do an action plan without informing customer?
2 - A layout inspection is done and some of the drawing specifications didn't match (e.g. diameter below spec.). This specifications were not considered on the current PPAP which was approved by customer, even without measuring all drawing specification (e.g. just 10 of 13 specifications ballooned. Should I inform customer or just do an action plan without informing customer?
Thank you!
Ps:This is my first post
Example #1 - What you describe means you have been shipping nonconforming product, perhaps for a significant period of time. This is one of the reasons for requiring annual layouts - to see if the process ahs drifted. It also suggest you are not doing adequate internal inspection, and that may need to be reviewed.
You need to initiate an internal corrective action, and immdiately inform your customer and discuss what is the best reaction to the situation.
Example #1 - Same answer as #1 above. Further, your PPAP process is not complete and you need to do corrective action to determine why this was missed internally. The fact the customer approved the PPAP is not a guarantee they noticed or approved this gap. That is why PPAP requires a full layout in the first place - so these descrpancies can be discussed with the customer.
C.R.V.G.
Quality Engineer
#12
I see. This is a tough experience I'm passing through. I was hired two months ago and here there's a lot of PPAPs exactly as case #2. Of course I'm doing all layouts based on the whole drawing and referenced standards, but I surely know that I'll find a lot of discrepancies. I just want to know how to inform customer (if there is a procedure) because ISO/TS doesn't specify how to.
There's no problem to do an action plan, CSL or any kind of containment and corrective actions. I'm only afraid if customers block our shipments by informing them :confused:
Once again :thanx:
Helmut Jilling
#13
Once again :thanx:
Yes, this is a potentially difficult situation. But, hopefully, this is why you were hired. If companies try to hide this sort of thing, it eventually blows up into a bigger thing, and will damage the company and perhaps, even your career.
You should do some checks, and get a sense of how big this issue will be. Keep clear records.
Meet with management team, and discuss your findigns, and what TS requires (ref cl 8.3 - this is where TS specifies what actions you must take. Also, review the PPAP and APQP manuals, they address NC issue this also.
Prioritize the failures, categorize them as to whether they affect the Fit, Form and Function, and prepare to discuss the analysis results with the customer. This step should include top mgt as well. It should not be YOUR problem...YOU have to position yourself as the fixer of this company issue. Not the scapegoat.
PS: It is sometimes difficult to do the right thing, but in the long run, your integrity is not something you want to gamble with. Do the right thing, and preach that to your team and your customers.
And, if your company presses you to do the wrong things, consider whether you really want to spend the rest of your career at a company like that? This will not be the only ethical issue that arises.
And, I might add, sometimes it is helpful to use a good consultant to help you initiate this kind of correction project. that keeps you from being the only guy "causing problems" and gives a little more authoritive and experienced perspective to the management team.
Best of luck. Stay in touch and let us know how it goes. You can also private message me if you have private guidance questions.
P IATF 16949 Clause 8.4.2.3 - Justification for non-certified suppliers IATF 16949 - Automotive Quality Systems Standard 14
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
R Material safety data sheet (MSDS) related clause in IATF 16949 manual IATF 16949 - Automotive Quality Systems Standard 17
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
QChas IATF 16949 Clause 8.5.1.2 - C -Standardized Work IATF 16949 - Automotive Quality Systems Standard 1
N Looking for input on the attached Process / IATF 16949 Clause Matrix IATF 16949 - Automotive Quality Systems Standard 4
R IATF 16949 Clause 6.1.2.1 - Lessons Learned and Risk Analysis IATF 16949 - Automotive Quality Systems Standard 6
L IATF 16949 Clause 9.2.2.2 Quality Management System Audit IATF 16949 - Automotive Quality Systems Standard 9
H IATF 16949 Clause 9.2.2.2 Audit System / CSR IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 clause 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
P Interesting Discussion IATF 16949:2016 Clause 9.2.2.3 and Layered Process Audits IATF 16949 - Automotive Quality Systems Standard 18
M Reference to IATF 16949 clause 8.4.3 in clause 8.3.4.4, Is it right? IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 Clause 8.3.5.2 sub-clause (l) - Process maintainability requirements IATF 16949 - Automotive Quality Systems Standard 15
J IATF 16949 Clause 9.3.2.1 - How to understand "measures" IATF 16949 - Automotive Quality Systems Standard 4
J How to address IATF 16949 clause 5.1.1.1 in my Quality Manual IATF 16949 - Automotive Quality Systems Standard 6
B IATF 16949 clause 8.3.4.3 Prototype programme IATF 16949 - Automotive Quality Systems Standard 0
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
A Escalation Process - IATF 16949 Clause 4.4.1.2 IATF 16949 - Automotive Quality Systems Standard 11
E IATF 16949 Clause of 8.4.3 - Approvals - Can you explain to me IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Clause 9.2.2.2 - Which QMS Processes are Included IATF 16949 - Automotive Quality Systems Standard 1
J What are sample documents of IATF 16949 Clause 8.6.4 a? IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Clause 8.3.3.3 - Documentation of all Special Characteristics in Drawings IATF 16949 - Automotive Quality Systems Standard 2
B IATF 16949 Section Clause 8.3.4.1 - Monitoring - Design and Development Input(s) IATF 16949 - Automotive Quality Systems Standard 3
B IATF 16949 Clause 8.6.2 - Layout Inspection and Functional Testing IATF 16949 - Automotive Quality Systems Standard 13
B IATF 16949 Clause 9.3.2.1 - Management Review Inputs IATF 16949 - Automotive Quality Systems Standard 1
T Customer Authorization for Concession - IATF 16949 Clause 8.5.1.1 IATF 16949 - Automotive Quality Systems Standard 3
W IATF 16949 Clause 8.4.2.4.1 Second Party Audits (Supplier Management) IATF 16949 - Automotive Quality Systems Standard 45
T Record Retention Requirements - IATF 16949 Clause 7.5.3.2.1 Records and Data - Quality, Legal and Other Evidence 15
B IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change) IATF 16949 - Automotive Quality Systems Standard 24
T Temporary Change of Process Controls - IATF 16949 Clause 8.5.5.1.1 IATF 16949 - Automotive Quality Systems Standard 16
B IATF 16949 Clause 8.4.1.2 - Supplier Selection Process - Service Providers IATF 16949 - Automotive Quality Systems Standard 13
J IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition - Scrap Rendered Unusable IATF 16949 - Automotive Quality Systems Standard 64
M IATF 16949 Clause 4.4.1.2 - Product Safety - Concept of the Title IATF 16949 - Automotive Quality Systems Standard 4
M IATF 16949 Clause 7.1.5.1.1 - What are "inspection equipment systems"? IATF 16949 - Automotive Quality Systems Standard 4
P Setup Verification in IATF 16949 Clause 8.5.1.3 IATF 16949 - Automotive Quality Systems Standard 6
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
J IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition Compliance IATF 16949 - Automotive Quality Systems Standard 38
M Exclusion of IATF 16949 Clause 4.4.1.2 - Product Safety IATF 16949 - Automotive Quality Systems Standard 2
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
M IATF 16949 Clause 4.4.1.2 - Product Safety IATF 16949 - Automotive Quality Systems Standard 13
M Compliance with IATF 16949 Clause 8.3.4.4 Product Approval Process IATF 16949 - Automotive Quality Systems Standard 2
dubrizo IATF 16949 Clause 8.7.1.6 - Customer Notification - Your Inputs Requested IATF 16949 - Automotive Quality Systems Standard 4
P IATF 16949 Clause 8.5.6.1.1 - Temporary Change of Process Controls IATF 16949 - Automotive Quality Systems Standard 21
M IATF 16949 Clause 8.3 - Rework Records Requirements IATF 16949 - Automotive Quality Systems Standard 1
J What results need to be defined in IATF 16949 Clause 8.3.4 IATF 16949 - Automotive Quality Systems Standard 3
P IATF 16949 Clause 10.2.4 - Error Proofing IATF 16949 - Automotive Quality Systems Standard 25
P IATF 16949 Clause 8.5.1.4 - Verification after Shutdown IATF 16949 - Automotive Quality Systems Standard 27
J How to understand IATF 16949 Clause 8.5.6.1.1 - Process Controls IATF 16949 - Automotive Quality Systems Standard 2
