TS 16949 Continual Improvement Requirements vs. QS-9000 Requirements
tlarosa
I am confused about continual improvement in ISO/TS 16949.
In the QS-9000 days, continuous improvement meant to get better at something that you were already doing well in. For example, if you were achieving a Cpk of 1.67 in a process, then you can improve by setting a target of 2.00 and make the necessary changes to arrive at the new target.
However, in ISO/TS 16949, the meaning seems to have changed because now you can use corrective and preventive actions as inputs to continually improve.
QS-9000 made distinctions between corrective action, preventive action, and continuous improvement. TS seems to say that corrective or preventing a nonconformity can serve as a continual improvement activity.
Is anybody seeing the same thing I am?????
howste
Thaumaturge
TS 16949 makes this distinction in the very narrow view of statistically controlled manufacturing processes. You can find the carryover from QS9000 in a note under 8.5.1.2 Manufacturing process improvement:
TS 16949:2009 said:
Manufacturing process improvement shall continually focus upon control and reduction of variation in product characteristics and manufacturing process parameters.
NOTE 1 Controlled characteristics are documented in the control plan.
NOTE 2 Continual improvement is implemented once manufacturing processes are capable and stable, or product characteristics are predictable and meet customer requirements.
The current definition for continual improvement is:
recurring activity to increase the ability to fulfil requirements
I see this recurring activity as the Plan-Do-Check-Act cycle. As you noted, continual improvement of processes may be achieved with the use of both corrective actions and preventive actions. For example, an organization is tracking efficiency of a process, and has a goal of 90% efficiency. Over time, by identifying and eliminating wasted effort or other undesirable situations not related to product variation or conformity, the organization increases the efficiency and achieves 90%. This would be considered continual improvement, and doesn't violate the spirit of the note.
qusys
I am not on the same line.
Corrective actions are related to fix a problem where you are not compliant, preventive actions are action aimed at fixing a "potential issue".
I see continual improvement linked to projects to improve processes where the organization is already in line with goals and targets.
We can say that it is the "leverage" for the organization not to sleep on good results, to remain competitive and better serve Customers in terms of quality, costs and times.
However there are many current of thought in this sense and so you can find multiple interpretations. I think that it is important for an organization to give itself a method and criteria for continual improvement. For example, ISO 9004 suggests PDCA as a good methodology to aling organization in its whole to improve. As usual, top mgmt sponsorship is key
:bigwave:
ChrissieO
:bigwave:
If you put preventive action in place to prevent the possible future failure, are you not in fact improving your processes?.................and in the same vein, if you put in place corrective action in place is this not also improving your processes.
I think along with improvement projects etc CAPA is part of CI.
Chrissie
qusys
Chrissie
Yes and not , it is a question of interpretation.
As to preventive action, probably yes, because you are doing something to avoid a potential issue and to so you are change something. But howver I think we are borderline
As to corrective you shall fix the problem, so you do not improve given that you are not in compliance .
In my tought, I see Continual improvement as a sort of process that improve QMS in terms of cost, quality and methods, when the organization already achieved objectives.
To show this, organization should demonstrate a step ahead on its KPI.
This is my idea that I share. I also agree with your mind:bigwave:
howste
Thaumaturge
As to corrective you shall fix the problem, so you do not improve given that you are not in compliance.
Not always true. Look again at the definition of corrective action:
ISO 9000:2005 said:
corrective action
action to eliminate the cause of a detected nonconformity or other undesirable situation
You can meet requirements, but still have "undesirable situations" that you can take corrective action on to continually improve.
tlarosa
Very good point.
qusys
Agree with you.
I would also like to share with you that some definitions have always a sort of "escape point" as I was taught in many training I attended regarding ISO and Quality Systems.
Again , to come back to definition you mentioned, this could also open to another interpretation of " preventive actions".
I mean that action on " undesiderable situation" could also be seen as preventive action too...:bigwave:
howste
Thaumaturge
It depends on if the situation exists now, or just has the potential to exist...
ISO 9000:2005 said:
preventive action
action to eliminate the cause of a potential nonconformity or other undesirable potential situation
V Continual Improvement of the Organization - TS 16949 Clause 8.5.1.1 IATF 16949 - Automotive Quality Systems Standard 10
R Anyone have a procedure to share for TS 16949 - 8.5.1 Continual Improvement? IATF 16949 - Automotive Quality Systems Standard 3
A Continual Improvement of Production Processes - TS 16949 IATF 16949 - Automotive Quality Systems Standard 11
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 2
D IATF 16949 M&TE Laboratory scope IATF 16949 - Automotive Quality Systems Standard 4
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
D Bulk Materials (Greases) and IATF 16949 IATF 16949 - Automotive Quality Systems Standard 11
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 15
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 4
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 11
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
H Remote product audits in Coivd-19 - IATF 16949 9.2.2.4 IATF 16949 - Automotive Quality Systems Standard 3
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Postpone IATF 16949 audit due to COVID-19 IATF 16949 - Automotive Quality Systems Standard 41
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
T Reaction Plan To Drive suppliers to IATF 16949 registration IATF 16949 - Automotive Quality Systems Standard 6
B IATF 16949 - Is a Deviation required for sample components in a prototype build? IATF 16949 - Automotive Quality Systems Standard 13
C IATF 16949 - Scope or not? IATF 16949 - Automotive Quality Systems Standard 2
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
