Jim,
I think our comments may be missing each other. I am not suggesting expensive requirements. An organization does not have to use an outside lab, unless the customer specifies it, or they do not have capability. I agreed the auditor was incorrect in that view.
But, when it comes to automotive, the TS rules and requirements apply. TS requires a supplier to be certified to ISO at a minimum, AND compliant to TS. One TS requirement is to have a lab scope document detailing their lab capabilities, ...to be compliant to TS, and because PPAP will require it. It is not expensive to make a lab scope document.
Further, an ISO certified supplier to automotive is required to meet the customer's product approval process. Assuming that is AIAG PPAP, one of the required documents is the lab scope document. The auditor is correct in that part.
2.2.12 of the 4th edition PPAP manual, in part: Inspection and testing for PPAP shall be performed by a qualified laboratory as defined by customer requirements (e.g., an accredited laboratory). The qualified laboratory (internal or external to the organization) shall have a laboratory scope and documentation showing that the laboratory is qualified for the type of measurements or tests conducted.
My emphasis. There is no requirement for suppliers to be compliant with TS 16949. There is a requirement for the organization to develop suppliers with a goal of compliance, and there is considerable leeway as to how and when this takes place.
Note the bit above about "as defined by customer requirements." What if there are no customer requirements? What if the organization claims approval by merit of approved PPAP submissions? How would the organization go about "...showing that the laboratory is qualified..."? Failure to include that in PPAP submissions should also be a nonconformity, but nowhere is it defined beyond that one vague statement.
The whole set of requirements for material test reports is vague. I already mentioned the fact that the PPAP manual requires the organization to do the testing, a requirement that's never been enforced as far as I know. The fact is that in cases of metalworking--machining, stamping, etc.--test data from a mill or distributor has historically been considered acceptable, and I have never heard of an instance where an auditor asked for a scope document from a raw material supplier.
