TS 16949 Section 7.2.2 - Product Releases against Purchase Orders covered by clause?
G
GoKats78
7.2.2 Review of Requirements Related to the Product
The organization shall review the requirements related to the product. This review shall be conducted prior to the organization's commitment to supply a product to the customer (e.g. submission of tenders, acceptance of contracts or order, acceptance of changes to contracts or orders) and shall ensure that;
a) product requirements are defined
b) contract or order requirements differing from those previously expressed are resolved, and
c) the organization has the ability to meet the defined requirements. Records of the results of the review and actions arising from the review shall be maintained (see 4.2.4)
OK - There is what TS says.
Our question: "Are product releases against Purchase Orders covered by this clause?"
Do we need to review and maintain records as stated above for each and every release against a Purchase Order?
Two sides:
1. This review was done during Inquiry Review and initial contract review prior to acceptance of the Purchase Order and releases are therefore covered.
2. How do we assure that nothing has changed from the initial review unless we verify the release against the contract (P.O.)
Thoughts? Ideas?
D.Scott
IMO 7.2.2 states contract review requirements prior to acceptance of a contract. If the contract is agreed and supplied under releases to the original purchase order, you should conduct normal contract review to ensure there are no changes to the original agreement. This can be as simple as reviewing whatever documents are provided with the order.
I think the 2 sides you posted are in fact two steps of normal contract review and both apply. As you say in 1, releases are therefore covered by the initial review but you point out the extension of that in 2 - ensuring there are no changes. In our business we compare all releases and POs against the original contract.
I think if you outline contract review in your procedures to include both new and releases, there would be no need for documentation past whatever you say you will do in the process. For example, if you say that all documentation supplied with release requests is reviewed against the original order prior to processing, then all orders processed are presumed to have been reviewed. There would be no need for additional documentation or records showing this was done.
I hope I understood your question.
Dave
G
GoKats78
I agree with your thoughts but I have one question.
"Records of the results of the review and actions arising from the review shall be maintained."
How do we reconcile the "requirement of records maintained" with your "no need ...or records showing this was done."
D.Scott
Again, IMO - the results of the review would either:
1) allow for release of parts without changes in which case there would be no other action to record (your processing document - work order - would serve as the records that no changes were found and the PO was processed under the agreed requirements)
2) identify a change in the original order which would prompt FULL contract review and documentation through another process (assuming you identified your action for this in the review procedure as suggested earlier).
The "records of the results and action" as required would either be the work order documenting "reviewed and no changes found" or the change form / contract review documenting "change found, reviewed and here's what happened".
When we identify a change, we put the parts/PO on hold and use the attached form to start the "change control" process.
Dave
T Seeking: Product Audit WI (section 8.2.2.3 / TS-16949) Template Document Control Systems, Procedures, Forms and Templates 3
C IATF 16949:2016 Section 8.5.1.2 item d) accessible for use at the designated work area(s) IATF 16949 - Automotive Quality Systems Standard 5
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
H Documented processes required by IATF 16949 section 4.4.1 IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Section Clause 8.3.4.1 - Monitoring - Design and Development Input(s) IATF 16949 - Automotive Quality Systems Standard 3
B IATF 16949 Section 8.5.1.5 (Total Productive Maintenance) IATF 16949 - Automotive Quality Systems Standard 19
B Calibration/Verification Records - IATF 16949 section 7.1.5.2.1 f) IATF 16949 - Automotive Quality Systems Standard 6
F ISO/TS 16949 - Definition Clause, sub clause, section, element IATF 16949 - Automotive Quality Systems Standard 8
B ISO/TS 16949 Section 7.6.3 - Use of Manufacturer to Calibrate IATF 16949 - Automotive Quality Systems Standard 21
A TS 16949 Section 7.3 - We have no design activity Design and Development of Products and Processes 4
S Designated Customer Representative - TS 16949 - Section 5.5.2.1 Design and Development of Products and Processes 3
J Definition Finishing Services - TS 16949 Section 3.1.6 references finishing services Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
L Gage Suppliers Requirements - TS 16949 Section 7.6.3.2 - Difficult to purchase gages IATF 16949 - Automotive Quality Systems Standard 16
V Auditing TS 16949, Section 6.3 for information systems General Auditing Discussions 5
D TS 16949: 2002 section 7.6.1 - MSA non conformity at registration audit IATF 16949 - Automotive Quality Systems Standard 2
T Monitoring & Measuring Software confirmation (validation) - TS 16949 Section 7.6 Statistical Analysis Tools, Techniques and SPC 1
A TS 16949 Section 8.2.4.1 - Layout inspection vs. QS-9000 Section 4.10.4.1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 0
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
H Remote product audits in Coivd-19 - IATF 16949 9.2.2.4 IATF 16949 - Automotive Quality Systems Standard 3
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
