ISO 16902-1:2003 Hydraulic fluid power -- Test code for the determination of sound power levels of pumps using sound intensity techniques: Engineering method -- Part 1: Pumps
ISO/TR 16913:1999 Plastics pipes and fittings -- Definitions of types of test
ISO/PAS 16917:2002 Ships and marine technology -- Data transfer standard for maritime, intermodal transportation and security (available in English only)
ISO/TS 16922:2002 Natural gas -- Guidelines for odorizing gases
ISO 16929:2002 Plastics -- Determination of the degree of disintegration of plastic materials under defined composting conditions in a pilot-scale test
ISO 16931:2001 Animal and vegetable fats and oils -- Determination of polymerized triglycerides by high-performance size-exclusion chromatography (HPSEC)
ISO/TS 16949:2002 Quality management systems -- Particular requirements for the application of ISO 9001:2000 for automotive production and relevant service part organizations
ISO/IEC 16969:1999 Information technology -- Data interchange on 120 mm optical disk cartridges using +RW format -- Capacity: 3,0 Gbytes and 6,0 Gbytes
ISO 16978:2003 Wood-based panels -- Determination of modulus of elasticity in bending and of bending strength
ISO 16979:2003 Wood-based panels -- Determination of moisture content
ISO 16981:2003 Wood-based panels -- Determination of surface soundness
ISO/TR 16982:2002 Ergonomics of human-system interaction -- Usability methods supporting human-centred design
ISO 16983:2003 Wood-based panels -- Determination of swelling in thickness after immersion in water
ISO 16984:2003 Wood-based panels -- Determination of tensile strength perpendicular to the plane of the panel
ISO 16985:2003 Wood-based panels -- Determination of dimensional changes associated with changes in relative humidity
ISO 16998:2003 Wood-based panels -- Determination of moisture resistance -- Boil test
ISO 16999:2003 Wood-based panels -- Sampling and cutting of test pieces
