TS16949 - 8.2.3.1 - Processes for Key and Critical Characteristic Dimensions
stogsdill1
Hi everyone!
I've searched the related threads and still find myself a bit confused on this section. Looking at section 7.2.1.1 and 7.5.1.1, I interpret section 8.2.3.1 as pertaining to processes for key/critical dimensions. Is that correct?
Thanks for your help!
m5guy
7.2.1.1 - Do any of your customers produce a Supplier Handbook that defines what they want called out on drawings as a critical or special characteristic? For example, in the Chrysler Customer Specific Requirement for TS16949 January 2013 edition, section 4.5 lists the Shield and the Diamond symbols as identifies of Special Characteristics.
7.5.1.1 says that you Process Control Plan must "...include methods for monitoring of control exercised over special characteristics defined by both the customer and the organization." Your Control Plan should have a column where you identify specific steps by their Special Characteristics Class. What do you do when you get to this step in the control plan? Example: In final assembly, do you inspect this special characteristic feature on 100% of the parts instead of following your normal Sample Size and Frequency?
8.2.3.1 - What do you do when your production process is not capable and/or stable for producing this special characteristic feature?
Example:
Customer says they want a hole in a part marked on the drawing as a critical dimension and you need to demonstrate a process capability index on the hole diameter of 1.33. You and your customer agree that this qualifies as a Special Characteristic.
You decide to measure 100% of the parts in your PPAP run for diameter so that you can calculate your CpK. You draft this into your Prototype Control Plan.
The results of your PPAP run show that you can only hold a 1.0 CpK. You execute the Reaction Plan stated on your Prototype Control Plan which is to follow your Non-Conforming Materials Reporting Procedure, followed by an 8D.
Helmut Jilling
Auditor / Consultant
Hi everyone!
Cl 7.2.1.1, talks about using the customer's symbols.
Cl 7.3.2.3 discusses special characteristics which are designated by the "Organization" rather than the customer.
The other references you cite are not limited to "Special" Characteristics.
Clauses 7.2.1.1 and 7.5.1.1 deal with all defined characteristics, that they must be defined, held in control, and measured. If they are not capable (usually defined as CPK 1.33 in Automotive), then the defined reaction plans from the Control Plan must be applied.
W Combining documentation (elements/processes) TS16949, ISO14001 & OHSAS18001 Document Control Systems, Procedures, Forms and Templates 12
M Do I need a Procedure for Each Process? And the Interaction of Processes - TS16949 IATF 16949 - Automotive Quality Systems Standard 20
K Special Requirements for Special Processes - HT 2005 (TS16949:2002) IATF 16949 - Automotive Quality Systems Standard 1
T PPAP differences between TS16949 and VDA APQP and PPAP 1
G Is ISO/TS16949 Extension Available? IATF 16949 - Automotive Quality Systems Standard 3
B ISO/TS16949 In-House Non-Product Laboratory IATF 16949 - Automotive Quality Systems Standard 3
B TS16949 Section 8.2.2.3 Product Audit - Requirements for various Customers IATF 16949 - Automotive Quality Systems Standard 10
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
tony wardle Lean and TS16949 - Integration Lean in Manufacturing and Service Industries 4
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
B Checklist for ISO/TS16949 for review and comment IATF 16949 - Automotive Quality Systems Standard 5
T TS16949 Process Design Requirements IATF 16949 - Automotive Quality Systems Standard 2
L TS16949 Work Instruction Requirements IATF 16949 - Automotive Quality Systems Standard 7
D TS16949 Annex A versus Toyota MQC's IATF 16949 - Automotive Quality Systems Standard 14
T TS16949 Lead Auditor Training Recommendations wanted Training - Internal, External, Online and Distance Learning 5
M Increase in Major TS16949 Audit Findings IATF 16949 - Automotive Quality Systems Standard 14
D TS16949 requirements for for Directed Buy Customers IATF 16949 - Automotive Quality Systems Standard 5
G Insights into the 2016 Version of TS16949 (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 74
B ISO/TS16949 8.2.3.1 IATF 16949 - Automotive Quality Systems Standard 1
B ISO/TS16949 6.2.2.3 IATF 16949 - Automotive Quality Systems Standard 1
K TS16949 registration for Kitting and Line Sequencing Service company IATF 16949 - Automotive Quality Systems Standard 1
V Procedure to change the Company name in existing TS16949-2009 certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Calibration Certificate "As Found" condition - TS16949 Section 7.6.2 General Measurement Device and Calibration Topics 7
T Reduced Audit days when UPGRADING from AS9100 to TS16949 - Is it possible? IATF 16949 - Automotive Quality Systems Standard 2
T Is there a requirement in TS16949 that PO's show a revision level? IATF 16949 - Automotive Quality Systems Standard 3
G Service Parts Assembly Line and Scope of TS16949 Registration IATF 16949 - Automotive Quality Systems Standard 3
M Comparing the MMOG (v3 or v4) with ISO / TS16949 Customer and Company Specific Requirements 3
B ISO/TS16949 Internal Auditing - How many auditors? Internal Auditing 4
B How to maintain documentation under ISO/TS16949 Clause 4.2.3 IATF 16949 - Automotive Quality Systems Standard 8
M Is a separate ISO/TS16949 certificate required for an extension site? IATF 16949 - Automotive Quality Systems Standard 4
L Scope of TS16949 for Aftermarket Product and a Service Fill Product IATF 16949 - Automotive Quality Systems Standard 2
B Meeting the requirements of ISO/TS16949 Clause 6.2.2.3 IATF 16949 - Automotive Quality Systems Standard 4
W Does TS16949 require MSA on all measurement systems in the Control Plan? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Process Records requirements for TS16949 standard IATF 16949 - Automotive Quality Systems Standard 6
D Include non-automotive in TS16949 Registration Scope IATF 16949 - Automotive Quality Systems Standard 1
R TS16949 requirements for Motorcycle OEM Parts Suppliers (Batteries) IATF 16949 - Automotive Quality Systems Standard 1
C TS16949: Product Audit vs. "Regular Checks" Internal Auditing 1
E Gap Analysis for VDA 6.3:2010 and ISO/TS16949:2009 VDA Standards - Germany's Automotive Standards 5
U TS16949 Internal Auditor Training - Is On-line training OK? Training - Internal, External, Online and Distance Learning 1
D What is your understanding or interpretation of TS16949 7.4.1.2 IATF 16949 - Automotive Quality Systems Standard 6
M TS16949 Control regulation with business partner(Subcontractor) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M TS16949 Design Exclusion when Design is done in a different Facility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Help with TS16949 Awareness Training for Employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M TS16949 8.2.2.5 Internal Auditor Qualification IATF 16949 - Automotive Quality Systems Standard 4
N IATF Appeals on ISO/TS16949 Rules - 4th Ed. - Removal of Site Extensions IATF 16949 - Automotive Quality Systems Standard 2
M TS16949 Exclusions - Design & Development is carried out by our parent company IATF 16949 - Automotive Quality Systems Standard 14
D Risk Requirement for TS16949 Feasibility IATF 16949 - Automotive Quality Systems Standard 4
B TS16949 - 7.3 Design and Development Exclusions for a Service Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Will ISO TS16949 be impacted by ISO 9001:2015? IATF 16949 - Automotive Quality Systems Standard 3
F Gap Analysis Matrix for AS9100 Rev C to TS16949:2009 IATF 16949 - Automotive Quality Systems Standard 1
