TS16949 Clause 7.6.3.1 - Internal laboratory - Facility shall have a defined scope
roder - 2012
Internal laboratory - facility shall have a defined scope that includes its capability to perform the required inspection, test or calibration services. This laboratory scope shall be included in the quality mgt system documentation. The laboratory shall specify and implement , as a minimum, technical rqmts for -adequacy of the laboratory procedures, -competency of the laboratory personnel, -testing of the product, capability to perform these services correctly, traceable to the relevant process stds(such as ASTM, EN, etc.), and -review of the related records.
- My question is....Does calibration of instrument based on manufacturer's manual requires compliance/traceability to process standards (standard methods)?
Assuming that there are no other relevant standards (ASTM, e.g.), the manufacturer's manual would be the "relevant process standard" in this case.
David T
So to follow that thought, is the manufacturer qualified to service and calibrate the instrument themselves. I am seeing a big circular loop between 7.6.3.2 NOTE 2 ...
calibration services may be performed by the equipment manufacturer... requirements in 7.6.3.1 have been met.
This comes back to being accredited to ISO17025 and having a complete lab scope, etc. I have manufacturers who can service my instruments but refuse to provide a lab scope because 'they are not laboratories, they are manufacturers'. In most cases, they are registered to ISO9000
V
vanputten
Hello David T:
I get the same unimformed, crap answer. Check the definiton of laboratory in TS. We all should be aware and use the definitions in ISO 9000:2005 and TS.
An OEM that provides test, calibration, or inspection service is a laboratory. I see nothing in all of 7.6.3 that is cyclical. If the OEM is providing test, inspection, or cal service, then they need to meet the requirement of 7.6.3.1.
And the OEM can provide this service if a qualified (ISO 17025 accedited) lab is not available. The OEM has to be the only available source and there are no ISO 17025 labs available to do what it is you need.
There is also the option of contacting all auto cusotmers to get a waiver.
And to add confusion, per the Foreward of TS, "Paragraphs marked Note are for guidance in understanding or clarifying the associated requirement."
So many people never read all of ISO 9000:2005, ISO 9001:2000, or TS 16949:2002.
Finally, the bigger question is what value does all of this give the auto indusry? I say just about zero.
Regards,
Dirk
David T
Thanks for your comments.
So, if I read your note correctly, we poor Tier 2/3 suppliers are stuck between a rock and a hard place.
We have a standard which requires our calibration agencies, including OEM, to either register to ISO17025 or follow the spirit enough under ISO9000 to be physically audited to a standard they don't subscribe to and pass with our permission (who are also not required to register to 17025) and/or our customer's waiver
and our OEM suppliers who are capable of making a instrument which may cost up to a $1M or more but who don't have a lab scope, and refuse to generate one.
and where I own tooling and instruments which need to be certified as as calibrated and annually checked by the manufacturer and confirmed as conform to OEM specifications
and a registrar who says all my service agencies for metrology calibrations must have a lab scope.:lmao:
Using this logic, why stop with metrology tools? All production equipment which is purchased to manufacture an automotive product and is measured to conform to OEM performance standards and customer requirements list (my requirements), must be built be an organization with a 'laboratory' and a 'laboratory scope' sufficient to pass ISO17025.
Anyone have any experience of using an OEM's process-control plan as their 'laboratory scope'?
V
vanputten
Hello Dave T:
I do not understand everything you wrote. Keep in mind that the "customer" is always the automotive customer of the organization (your orgainzation) seeking TS certification.
I am not sure what you mean by the following: "follow the spirit enough under ISO9000 to be physically audited to a standard they don't subscribe to and pass with our permission (who are also not required to register to 17025) and/or our customer's waiver"
Your customer may assess your suppliers. That is one option. See Note 1 of 7.6.3.2. Keep in mind Notes are for guidance.
Your choices:
Suppliers are ISO 17025 accredited and the service they provide is within the scope of accrediation
Have your customer assesses your suppliers ability
Ask auto customers for a waiver
If no accredited lab exists and the supplier is the OEM, then the OEM must meet the requirments of 7.6.3.1 (But only if there is no accredited lab available.)
We have an OEM supplier of machines that are millions of dollars each. Each! They will not accept the above as our requirements of them.
Not sure what you are saying here either: "and where I own tooling and instruments which need to be certified as as calibrated and annually checked by the manufacturer and confirmed as conform to OEM specifications"
I am not sure how the manufacturer or OEM applies in your statement. If you do your own cal, then you have to meet the requirements of 7.6.3.1.
Please make sure you know the definitions of "customer", "organization", and "supplier". Internal lab requirements only apply to the "organization."
All of 7.6.3 applies to test, inspection, and calibration and the providers of that service.
It is not that hard to find ISO 17025 accredited labs for what you need unless you have a very specific piece of equipment.
Lab scopes appear to be specific things. Go to the a2la.org website and do some searches. All of the accrediation certificates include a lab scope. A control plan would be something different than what I have seen as lab scopes.
Regards,
Dirk
B How to maintain documentation under ISO/TS16949 Clause 4.2.3 IATF 16949 - Automotive Quality Systems Standard 8
B Meeting the requirements of ISO/TS16949 Clause 6.2.2.3 IATF 16949 - Automotive Quality Systems Standard 4
Q Potential Field Failure as Mgmt Review Input for TS16949: How to meet the clause? IATF 16949 - Automotive Quality Systems Standard 1
Casana Supplier Waiver Request - TS16949 Clause 8.3.4 Customer Waiver IATF 16949 - Automotive Quality Systems Standard 3
Jen Kirley What's procedurally required for "cloud computing"? TS16949 Clause 4.2.4. Records and Data - Quality, Legal and Other Evidence 8
D "Special Production Process" Validation and TS16949 Clause 7.5.2.1 IATF 16949 - Automotive Quality Systems Standard 5
P Last-off-part comparison used to validate the set-up (TS16949 Clause 7.5.1.3) IATF 16949 - Automotive Quality Systems Standard 3
B TS16949 Clause 7.1 in plastic pellet 'color mixing' and color compounding' process IATF 16949 - Automotive Quality Systems Standard 1
A Requirement to control gauge and tooling drawings? TS16949 Clause 7.5.1.5 IATF 16949 - Automotive Quality Systems Standard 5
M Customer Designated Special Characteristics - TS16949 Clause 7.2.1.1 Design and Development of Products and Processes 14
K Auditor's Question Regarding TS16949 Clause 7.5.2 - How vague can an auditor be IATF 16949 - Automotive Quality Systems Standard 18
M Supplier Monitoring - Do we need to do Supplier Audits? - TS16949 Clause 7.4.3.2 IATF 16949 - Automotive Quality Systems Standard 7
S "Product Design skills" Exclusions in TS16949 Clause 6.2.2.1 Design and Development of Products and Processes 12
N Error-proofing tools/methods to suggest? TS16949 Clause 8.5.2.2 IATF 16949 - Automotive Quality Systems Standard 2
Z TS16949 Clause 7.4.1.2 - Suppliers must be 3rd party registered to ISO9001:2000? IATF 16949 - Automotive Quality Systems Standard 4
Dave.C Measurement of Employee Motivation and Awareness - TS16949 Clause 6.2.2.4 IATF 16949 - Automotive Quality Systems Standard 25
R How is effectiveness of plant layout monitored / measured - TS16949 Clause 6.3.1 IATF 16949 - Automotive Quality Systems Standard 1
A What is Process Performance and Product Conformity - ISO/TS16949:2002 Clause 5.6.2.c IATF 16949 - Automotive Quality Systems Standard 5
K How can we satisfy TS16949 Clause 8.2.2.3 Product Audit IATF 16949 - Automotive Quality Systems Standard 3
A ISO/TS16949, Clause 6.2.2.4 - Motivating employees to achieve quality objectives IATF 16949 - Automotive Quality Systems Standard 6
Q Customer's Interpretation vs. TS16949 clause 7.4.1.2 Supplier Development Requirement Supplier Quality Assurance and other Supplier Issues 70
R TS16949 clause elements compared to department ownership responsibilities matrix IATF 16949 - Automotive Quality Systems Standard 7
T PPAP differences between TS16949 and VDA APQP and PPAP 1
G Is ISO/TS16949 Extension Available? IATF 16949 - Automotive Quality Systems Standard 3
B ISO/TS16949 In-House Non-Product Laboratory IATF 16949 - Automotive Quality Systems Standard 3
B TS16949 Section 8.2.2.3 Product Audit - Requirements for various Customers IATF 16949 - Automotive Quality Systems Standard 10
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
tony wardle Lean and TS16949 - Integration Lean in Manufacturing and Service Industries 4
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
B Checklist for ISO/TS16949 for review and comment IATF 16949 - Automotive Quality Systems Standard 5
T TS16949 Process Design Requirements IATF 16949 - Automotive Quality Systems Standard 2
L TS16949 Work Instruction Requirements IATF 16949 - Automotive Quality Systems Standard 7
D TS16949 Annex A versus Toyota MQC's IATF 16949 - Automotive Quality Systems Standard 14
T TS16949 Lead Auditor Training Recommendations wanted Training - Internal, External, Online and Distance Learning 5
M Increase in Major TS16949 Audit Findings IATF 16949 - Automotive Quality Systems Standard 14
D TS16949 requirements for for Directed Buy Customers IATF 16949 - Automotive Quality Systems Standard 5
G Insights into the 2016 Version of TS16949 (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 74
B ISO/TS16949 8.2.3.1 IATF 16949 - Automotive Quality Systems Standard 1
B ISO/TS16949 6.2.2.3 IATF 16949 - Automotive Quality Systems Standard 1
K TS16949 registration for Kitting and Line Sequencing Service company IATF 16949 - Automotive Quality Systems Standard 1
V Procedure to change the Company name in existing TS16949-2009 certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Calibration Certificate "As Found" condition - TS16949 Section 7.6.2 General Measurement Device and Calibration Topics 7
T Reduced Audit days when UPGRADING from AS9100 to TS16949 - Is it possible? IATF 16949 - Automotive Quality Systems Standard 2
T Is there a requirement in TS16949 that PO's show a revision level? IATF 16949 - Automotive Quality Systems Standard 3
G Service Parts Assembly Line and Scope of TS16949 Registration IATF 16949 - Automotive Quality Systems Standard 3
M Comparing the MMOG (v3 or v4) with ISO / TS16949 Customer and Company Specific Requirements 3
B ISO/TS16949 Internal Auditing - How many auditors? Internal Auditing 4
M Is a separate ISO/TS16949 certificate required for an extension site? IATF 16949 - Automotive Quality Systems Standard 4
L Scope of TS16949 for Aftermarket Product and a Service Fill Product IATF 16949 - Automotive Quality Systems Standard 2
W Does TS16949 require MSA on all measurement systems in the Control Plan? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
