Since this is in the TS forum, I would still qualify the need of any gages identified in the control plan to be calibrated.
What typically confuses people is what calibration actually means, and what the calibration requirements for each gage is. This confusion either has them send everything out because they do not understand it at all, save some for in house, with varying success depending on the training of the individual(s) doing the calibration, or giving up and putting "for reference only" on it. Of course, the ability to adjust a gage has nothing to do with calibration. All gages should be able to be compared to a standard. The only difference between gages that can or can not be adjusted is the reaction plan if they fail calibration.
If I was to audit, I would look at the control plan, check out the gages for the operation, review the calibration records and associated calibration procedures, look for evaluation of meeting calibration (comparison to a standard, with the identification of the standard's traceability, etc.), verification of linearity and stability, where required. I would inquire of the basis for your calibration frequency. If you can muster that information correctly, you are doing pretty darn good. If you can go the next step and have valid uncertainty data, you are way out in front of the pack. On the other hand, if the gage said 'for reference only", then I would ask to see the gage that is actually used to measure the control plan characteristic, and how the product is protected from being measured with the 'for reference only' gage.
