TS16949 Process Design Requirements
thenson
In section 7.3 of the current (2009) revision of TS16949, is it a requirement that if the organization is NOT product design responsible, does that organization still required to meet the requirements for process design?
And if yes, would you be required to show evidence of review and approvals at different phases of the project as shown in the AIAG/APQP manual?
Again, if yes, does anyone have an example of a process design and approval checklist you could share?
thanks,
thenson
Golfman25
Yes, you are still responsible for process design. Note there is no TS requirement to use the AIAG APQP process, although it may be a customer requirement and reasonably mirrors the standard. We use a checklist based on the AIAG manual. Your best bet is to work thru that and the standard to develop a checklist. Good luck.
Great Scotch
thanks,
thenson
Best is to set up an APQP for this. Or design a process map that is similar to the APQP.
M Process Records requirements for TS16949 standard IATF 16949 - Automotive Quality Systems Standard 6
J Can I skip Payment Process audit for TS16949 Internal Audit? IATF 16949 - Automotive Quality Systems Standard 4
D "Special Production Process" Validation and TS16949 Clause 7.5.2.1 IATF 16949 - Automotive Quality Systems Standard 5
B TS16949 Clause 7.1 in plastic pellet 'color mixing' and color compounding' process IATF 16949 - Automotive Quality Systems Standard 1
P Manufacturing Process Audits (TS16949) - are Turtle diagrams really helpful? IATF 16949 - Automotive Quality Systems Standard 4
D Process audit in compliance with ISO/TS16949 Process Audits and Layered Process Audits 3
R Auditing Accounting as a Key Process - TS16949 Audit Internal Auditing 6
R Quality System vs. Process vs. Product Audit - TS16949 IATF 16949 - Automotive Quality Systems Standard 49
Manix What provision is made for the Process of Implementing Project based work in TS16949? IATF 16949 - Automotive Quality Systems Standard 3
S Identifying Process Interactions Correctly - The key ones? All of them? TS16949 IATF 16949 - Automotive Quality Systems Standard 2
O Work Instructions vs. Process Control Plans - No Substitutions? TS16949 - 7.5.1.2 Document Control Systems, Procedures, Forms and Templates 10
M Do I need a Procedure for Each Process? And the Interaction of Processes - TS16949 IATF 16949 - Automotive Quality Systems Standard 20
V How to Fit a Product Audit for a Batch Process? TS16949 General Auditing Discussions 2
T Process Capability Data (TS16949 8.2.3.1) - How often should it be reviewed? Capability, Accuracy and Stability - Processes, Machines, etc. 9
C Systems Requirements vs. Process Requirements for TS16949 IATF 16949 - Automotive Quality Systems Standard 5
P TS16949 - Should specific process notes be considered a controlled document. IATF 16949 - Automotive Quality Systems Standard 4
A What is Process Performance and Product Conformity - ISO/TS16949:2002 Clause 5.6.2.c IATF 16949 - Automotive Quality Systems Standard 5
Z Looking for some examples of TS16949 process mapping Process Maps, Process Mapping and Turtle Diagrams 1
D Layered Process Audits? Are they required by TS16949? Process Audits and Layered Process Audits 13
A ISO/TS16949 Clause7.4.1 Purchasing Process IATF 16949 - Automotive Quality Systems Standard 2
D Testing process is non value added process under TS16949? IATF 16949 - Automotive Quality Systems Standard 1
Q The Checklist to ISO/TS16949 - Is it a Process Audit or Elemental? Process Audits and Layered Process Audits 8
T PPAP differences between TS16949 and VDA APQP and PPAP 1
G Is ISO/TS16949 Extension Available? IATF 16949 - Automotive Quality Systems Standard 3
B ISO/TS16949 In-House Non-Product Laboratory IATF 16949 - Automotive Quality Systems Standard 3
B TS16949 Section 8.2.2.3 Product Audit - Requirements for various Customers IATF 16949 - Automotive Quality Systems Standard 10
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
tony wardle Lean and TS16949 - Integration Lean in Manufacturing and Service Industries 4
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
B Checklist for ISO/TS16949 for review and comment IATF 16949 - Automotive Quality Systems Standard 5
L TS16949 Work Instruction Requirements IATF 16949 - Automotive Quality Systems Standard 7
D TS16949 Annex A versus Toyota MQC's IATF 16949 - Automotive Quality Systems Standard 14
T TS16949 Lead Auditor Training Recommendations wanted Training - Internal, External, Online and Distance Learning 5
M Increase in Major TS16949 Audit Findings IATF 16949 - Automotive Quality Systems Standard 14
D TS16949 requirements for for Directed Buy Customers IATF 16949 - Automotive Quality Systems Standard 5
G Insights into the 2016 Version of TS16949 (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 74
B ISO/TS16949 8.2.3.1 IATF 16949 - Automotive Quality Systems Standard 1
B ISO/TS16949 6.2.2.3 IATF 16949 - Automotive Quality Systems Standard 1
K TS16949 registration for Kitting and Line Sequencing Service company IATF 16949 - Automotive Quality Systems Standard 1
V Procedure to change the Company name in existing TS16949-2009 certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Calibration Certificate "As Found" condition - TS16949 Section 7.6.2 General Measurement Device and Calibration Topics 7
T Reduced Audit days when UPGRADING from AS9100 to TS16949 - Is it possible? IATF 16949 - Automotive Quality Systems Standard 2
T Is there a requirement in TS16949 that PO's show a revision level? IATF 16949 - Automotive Quality Systems Standard 3
G Service Parts Assembly Line and Scope of TS16949 Registration IATF 16949 - Automotive Quality Systems Standard 3
M Comparing the MMOG (v3 or v4) with ISO / TS16949 Customer and Company Specific Requirements 3
B ISO/TS16949 Internal Auditing - How many auditors? Internal Auditing 4
B How to maintain documentation under ISO/TS16949 Clause 4.2.3 IATF 16949 - Automotive Quality Systems Standard 8
M Is a separate ISO/TS16949 certificate required for an extension site? IATF 16949 - Automotive Quality Systems Standard 4
L Scope of TS16949 for Aftermarket Product and a Service Fill Product IATF 16949 - Automotive Quality Systems Standard 2
B Meeting the requirements of ISO/TS16949 Clause 6.2.2.3 IATF 16949 - Automotive Quality Systems Standard 4
