TV Mounting Question for Mechanical Engineers
tomvehoski
I'm mounting a new LCD TV on the wall and have run into some issues with the stud placement in the house. I think I have an easier solution than ripping down drywall to add braces, but for some reason am struggling with this being a good solution.
The TV is a 52" LCD that weighs 87 pounds. This is the bracket:
Full Link
My problem is that to hit two wall studs with the wall plate, I cannot center the bracket where I want the TV centered. The center arm bracket of the tv mount slides, so I could slide it to the right but that would cause the load to be unbalanced.
The horizontal TV mounting locations are 600 mm between centers. I estimate that to be where I want it, the center bracket would be 410 mm from the left bracket, 190 mm from the right. This would put 68% of the load (59 pounds) to the left of center and 32% (28 pounds) to the right (assuming the weight of the TV is equally distributed). I expect this would cause some tilt in the TV, not to mention stress on the mounting screws that secure the TV bracket to the wall bracket.
If I simply add 30 pounds of weight to the right side, will this balance it out and keep everything level? The mount is rated to 165 pounds and this would still leave me about 50 pounds under that.
Anyone see problems with this idea? If not, what is a good way to attach 30 pounds of weight to the right side of that bracket? I really don't want to tear up the wall, but I also don't want a $2400 TV crashing to the floor.
Scott Catron
True Artisan
Re: TV Question for Mechanical Engineers
The problem is you're using metric measurements for a US-built house. :D:nope::eek::rar:
But seriously - how about mounting some plywood (or something similar) to the studs and then mounting the TV wall plate to that? You could stain or paint it to match the decor.
ScottK
Not out of the crisis
I would approach it from another direction:
Mount a good piece 1x12 wood very solidly the studs at the height you want the bracket to be. Or even double it up to use longer screws.
Paint this wood to match the wall.
Then mount the bracket to this wood evenly wherever you want it.
This pushes it out into the room about .75 -1.5" extra but gives you placement flexibility without worrying about balance.
It's what I did with a swing arm all mount in my kitchen for a 12" CRT TV/DVD combo.
ScottK
Do all Scotts think alike? :D
tomvehoski
I've considered mounting 3/4 plywood across three studs, then the TV mount into it. I figured that four lag bolts into studs were more secure than two into a stud and four into plywood though. I also would like it as close to the wall as possible, but another inch would not be a big deal if necessary. I also hate painting and I'm not sure if I have any of the paint left from the living room to make it match.
reigelser
What do the angular adjustments refer to? It looks like the mount is designed to compensate for an installation that is not horizontally level. Also, I think that if the manufacturer of the mount does allow for adjustment of the 2 TV mounting rods and a horizontal angular alignment, that then the mounting bracket can handle the torque. Is there a disclosure in the manual for required mounting conditions? It would be easier to judge if I would hold the bracket in hand and see how flimsy it is.
Anyways, I seem to have the wrong job, since the only TVs I can afford are to big to hang on the wall :cool:, thus I do not have first hand experience.
Happy Holidays.
Joachim
BradM
Scotts and Brads? I was thinking the same.:lol:
Are you sure you cannot get it on studs? Most american homes are 18" or 24" on center (as long as it is not an old house). Most products are made to line up on those.
You could also run metal brackets horizontally that mount into the studs that you could mount the TV on. They could be painted to match the TV bracket. Of course, I tend to over-engineer everything I construct :tg:
K
Ken K
Personally, I wouldn't use a piece of plywood. I'd go with a 1/4" steel plate. Not only will it look better, but it will be much stronger.
Mount it with at least 4 lag bolts into two studs. For the tv bracket I would drill 4 holes from the backside of the plate. Try to center them on the plate. Counter sink the holes and tap them to hold 3/8" grade 8 bolts. Put the bracket on and put the largest washers you can find along with 4 nuts.
Although the bracket is rated for 165lbs, I don't like the look of a stamped bracket with only two pins holding a tv:mg:
Wes Bucey
Regardless of the stud spacing, I see the problem as "alignment" since the existing studs don't allow placing the TV for the most aesthetic placement on the wall without being "off" enough so that your wife will comment every time, "we should have hired somebody who knew what he was doing to put the TV where it would look best in our room."
To fit the TV where you WANT it (versus where it WILL FIT) is going to require some method of adapting the current 16-inch centers for the three verticals.
You don't say whether you have 16-inch stud centers or 24-inch, nor do you say how far off your entire ensemble will be from fitting directly to the studs to give you the placement most aesthetically pleasing to you.
Since the entire 52 inch size of the TV will hide a lot of "stuff," you should probably concentrate on the simplest adaptation that can later be removed without too much mess and effort and which does not have to be painted to match the other room decor.
If it were MY problem, I'd get metal plates to bolt (don't weld - if you relocate, you just have a screwed up support) across the 3 verticals (1/8-inch thick should be enough, but maybe 1/4-inch for extra insurance.) Use as many cross plates as you would have normally put lag screws in the two outside verticals. Drill holes in the cross plates for lag screws into studs - no counterbalancing required. Total extra "stick out" from the wall should be less than 1/2-inch plywood and nothing has to be painted to match the decor. Most steel distribution service centers can cut plate to size (I estimate 81 cm long X 5 cm wide should provide adequate strength with 1/8-inch plate, and only 2.5 cm wide for 1/4-inch plate.)
Added in edit:
NOTE: MAKE THE CROSS PLATE WIDE ENOUGH TO PUT TWO BOLTS INTO EACH VERTICAL TO AVOID SKEWING OF THE 90 DEGREE ANGLE BETWEEN CROSS PLATE AND VERTICAL!
Andy CDA
Although I'm not a mechanical engineer - I do have some experience with this. I wouldn't mess with adding additional weight - you're just increasing the stress on the mount. As long as you hit 2 studs (make sure you hit the center) and use 4 lags on it - you should be able to move the TV where you want it. Don't worry, it will hold. Keep it simple. Mine has been up that way for a year and it's about 100 lb tv.
J Assembly (Mounting Screws) from Backside and Frontside together in 1 Cycle Manufacturing and Related Processes 8
S 100% Inspection Control Chart By Dr. Feigenbaum - SMT (Surface Mounting Technology) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Work Instruction Question ISO 13485:2016 - Medical Device Quality Management Systems 5
M Clinical Decision Support Software Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
John C. Abnet VDA 6.3 - Question 7.3 - "blocking of parts" VDA Standards - Germany's Automotive Standards 4
D Approved supplier list - Distributors question ISO 13485:2016 - Medical Device Quality Management Systems 6
D Equipment Register and PM question ISO 13485:2016 - Medical Device Quality Management Systems 2
D Question regarding "storage and distribution" ISO 13485:2016 - Medical Device Quality Management Systems 1
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
A Quality engineering positions in US - question Job Openings, Consulting and Employment Opportunities 1
D Equipment Register related question ISO 13485:2016 - Medical Device Quality Management Systems 1
S Study sign off question / responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 3
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
M Question for Auditors - "Off the Record" Conversation? General Auditing Discussions 14
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
R Accelerated Aging - Creating test samples - Implantable medical device Question Other Medical Device Related Standards 4
A Question on Authorized Representative in Malaysia Other Medical Device Regulations World-Wide 3
D Limited Scope for second site Question? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I ISO 2233:2000 Question - Medical Device Shipping/Transportation Validation Other ISO and International Standards and European Regulations 1
Anonymous16-2 Labeling Question (Dietary Supplements/Food) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
T Question for: Cg & Cgk calculation General Measurement Device and Calibration Topics 3
N ASL Question for GitHub ISO 13485:2016 - Medical Device Quality Management Systems 6
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
A Question on ISO 14001:2015 - Are annual audits required? ISO 14001:2015 Specific Discussions 11
dinaroxentool Question about FDA Classification of a Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Another DFAR question 252.225-7009 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
F Conflict Mineral Smelter Question RoHS, REACH, ELV, IMDS and Restricted Substances 8
R NRTL - Scope Question - Off-the-Shelf Plug In IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D API 6A Certification Question Oil and Gas Industry Standards and Regulations 4
dinaroxentool Question about qualification as a medical device or accessory in Europe EU Medical Device Regulations 2
R DHR question: Traceability of components ISO 13485:2016 - Medical Device Quality Management Systems 2
C MDR - Question around software accesories EU Medical Device Regulations 2
K My question is, what/when is a nonconformity? Therefore what requires an NCR? Nonconformance and Corrective Action 9
Watchcat Authoritative References about the Research Question? Quality Tools, Improvement and Analysis 0
T Question about Quality Department employee position titles Quality Manager and Management Related Issues 10
N Question on creepage/clearance requirements for HF Active Accessories for 2nd edition 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J Question: How to create an IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
K Question on whether IEC 60601-2-62 standard is applied IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
B QMS question in regards to multiple medical devices/products and N/A activities Other Medical Device Related Standards 12
C NB approval - Basic question about Notified Bodies and their role EU Medical Device Regulations 10
G Question about Non-conformances during New Product Introduction Nonconformance and Corrective Action 14
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
O Mitutoyo Digital Caliper to PC USB question General Measurement Device and Calibration Topics 2
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
Q Supplier audit question cataloque VDA Standards - Germany's Automotive Standards 0
Ed Panek Inactive key supplier question - We are not actively buying from them ISO 13485:2016 - Medical Device Quality Management Systems 2
T Potential Off-Label Use question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R Question on determining defective units - I am not recording fixture to part rejected Statistical Analysis Tools, Techniques and SPC 5
