Two Separate Legal Entities - Manufacturer Vs. Contract Manufacturer
Ronen E
Problem Solver
Moderator
#11
If ABC, the "Specification Developer," is importing the devices from XYZ in a foreign country, does this not make ABC an initial importer?
Yes, but it's less relevant. As far as I understand, "Specification Developer" is a sub-category of "Manufacturer", whereas "Importer" / "Initial Distributor" is not. The requirements applicable to Importers are a subset of those applicable to Manufacturers (including SDs).
bikeshox
#12
If ABC is not in fact an initial importer, that might solve my problem...
When trying to re-register for 2013, I have ABC listed as a Manufacturer and Initial Importer. In 2013, I'm required to list the products I'm importing, when I attempt to list the products I'm importing from XYZ, DRLM tells me that XYZ is not a Manufacturer....
Does this mean an Initial Importer can only import from a "Manufacturer?"
MIREGMGR
#13
IIf I'm a contract manufacturer and i do not distribute the device, does that then make me a manufacturer in DRLM terms?
No. The Manufacturer (or Specification Provider) is the party that hired you to do the Contract Manufacturing and return the products to them in bulk to be distributed by them.
There is a hierarchy of applicability; every participant in the responsibility chain is accorded the highest responsibility-level that applies, even if additional lower levels of responsibility also apply. The highest level of responsibility is Manufacturer or Specification Developer, so those override Initial Importer even if the latter condition also is true.
In 2013, I'm required to list the products I'm importing, when I attempt to list the products I'm importing from XYZ, DLRM tells me that XYZ is not a Manufacturer....
Yes, it's never been legal to import devices (as opposed to components) from a non-Registered Establishment, but through 2012 FDA had no good mechanism for identifying such situations. With the 2013 rules changes, now they do have such a mechanism, i.e. you can't complete your own registration and listing process until you work with all of your suppliers to get them sorted out as well.
Or a Specification Provider, if they use a Contract Manufacturer...yes.
bikeshox
#14
Alright Lets try this...
An Initial Importer does not take responsibility for a device, the manufacturer or specification developer does.
The other thing that is throwing me off is how the DRLM defines contract manufacturer. XYZ is the contract manufacturer for ABC. The DRLM has a check box that says "Manufacture and Distribute Medical Device for Another Party (Contract Manufacturer)." However XYZ is does not distribute the device for another party (ABC). Should XYZ still select this option even though they dont distribute the product for another party?
MIREGMGR
#15
Yes, sort of. The FDA sometimes utilizes a 200% responsibility approach, i.e. both the Manufacturer and a contract sterilization provider are fully responsible for sterilization quality. The Initial Importer has some of this 200% responsibility in parallel with the outside-USA Manufacturer in regard to adverse event reporting and post market surveillance.
The wording in question is per the now-obsolete 2012 rules, under which only distributing contract manufacturers and offshore contract manufacturers had to Register. Under the 2013 rules that went into effect October 1, all contract manufacturers must Register.
bikeshox
#16
Thanks guys!
My Final Summary..as i see it....and feel free to correct any inaccuracy.
ABC and XYZ are owned by the same parent company. ABC is a Manufacturer/Specification Developer inside the US. XYZ is a Contract Manufacturer located outside the US. XYZ is the contract manufacturer because they make the devices for ABC, to ABC's specification with ABC's labeling and then send the devices to ABC.
-ABC is not an "initial importer" in this case because they are the manufacturer/specification developer taking responsibly for the Class I devices, regardless of the fact that they are importing the devices to the US.
I'm spent.
MIREGMGR
#17
FYI, as of today the terminology in the Listing module to describe the function of a Contract Manufacturer is:
Manufacture Medical Device for Another Party (Contract Manufacturer)
There is no longer any mention of distribution.
bikeshox
#19
Hi again! I'm having some more issues with this... We have a shipment stopped in customs, because our US facility is not listed as an initial importer...From the information found in this thread, I determined that our US facility is not an initial importer because we are receiving goods from our foreign facility, whom is the contract manufacturer. Does this sound correct? I'm confused again..
MIREGMGR
#20
Was the shipment stopped by FDA because they didn't like your PREDICT declaration, or by CBP because they didn't like your device-regulatory-status declaration on your Customs forms?
Historically, the Initial Importer status was created to provide a way to regulate a US distributor that buys and imports finished devices from an outside-US finished device manufacturer. A distributor normally would not have to register, but this would mean that those devices would have no responsible party within the US, within FDA native jurisdiction.
If your PREDICT and Customs forms identify you as a registered Establishment via your Specification Provider status, I would have thought that FDA and Customs would be OK.
M Can I be a legal manufacturer without being a separate legal entity? CE Marking (Conformité Européene) / CB Scheme 6
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
C Warehousing two separate components to a finished device while meeting regulations Other US Medical Device Regulations 7
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
H ISO 13485 - Separate Microbiology Audits ISO 13485:2016 - Medical Device Quality Management Systems 8
M UDI Database and EUDAMED - Will there be two separate databases? EU Medical Device Regulations 4
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
CPhelan Internal audit - Combine similar nonconformities in one or keep separate? Internal Auditing 6
S "X-MR charts do not separate piece-to-piece repeatability of the process" Statistical Analysis Tools, Techniques and SPC 2
R How far apart can you schedule separate areas or departments in your internal audit? Internal Auditing 4
S Do we need separate stand alone procedure for Suspect Unapproved Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
J Facilities - Placing our assembly group into a separate building ISO 13485:2016 - Medical Device Quality Management Systems 8
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 4
C ISO 14001 vs Existing Quality System - How to keep them separate? ISO 14001:2015 Specific Discussions 3
T Should Testing be a separate operation in the Control Plan? FMEA and Control Plans 5
P Two separate 510k submissions for one device from the same company Other US Medical Device Regulations 10
B ISO 9001:2015 8.4 External Providers - If work is transferred to a separate facility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Is a separate ISO/TS16949 certificate required for an extension site? IATF 16949 - Automotive Quality Systems Standard 4
T Two Separate Businesses - Only Part of Company Certified ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Separate Classifications for Medical Device Accessories EU Medical Device Regulations 2
R One-Time parts separate from QMS? Quality Manager and Management Related Issues 9
D Is a separate spreadsheet required for the ASL (Approved Supplier List)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
R Connection to a generic separate power supply IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Regulations for Selling Convenience Kit vs. Selling Separate Parts Other US Medical Device Regulations 2
cscalise Separate Forms or Procedure Attachments - What's more common? Document Control Systems, Procedures, Forms and Templates 2
C Do separate sites need separate documents? Document Control Systems, Procedures, Forms and Templates 7
A Newly Incorporated Business - Separate Scope and/or Separate Cert? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
L Should Internal Audit CAPAs be kept separate from "normal" CAPAs? ISO 13485:2016 - Medical Device Quality Management Systems 6
P Separate procedures? ISO 14k System combined with OHSAS 18001 Occupational Health & Safety Management Standards 3
J Device Registration and Listing - Separate for Device and corresponding Instruments? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C How to handle Outsourcing with Same Site - Separate Cert ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Separate Quality System? Product line of a parent company spins off 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
P How to separate Product Design Review, Verification, and Validation Activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
C What can you do if Quality is treated as a separate function in an organization? Quality Manager and Management Related Issues 24
C Separate Certification - Can I combine documents for ISO14001, OHSAS18001 & AS4801? Miscellaneous Environmental Standards and EMS Related Discussions 3
S IEC 62366 - Embedded Software in separate Usability Engineering File? IEC 62366 - Medical Device Usability Engineering 1
K How do ISO 9001 Requirements apply to 2 sets of specifications to 2 separate vendors? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Include as an attachment or make a separate document? Advise on Document Numbering Document Control Systems, Procedures, Forms and Templates 1
F Multiple Business Lines (Separate Corporations) in one Facility AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Separate Clinical Trials in the US and the EU - When one fails - question US Food and Drug Administration (FDA) 3
B Hospital Operating Room Regulations - Separate Entrances for Clean and Dirty Supplies Hospitals, Clinics & other Health Care Providers 4
S Separate Medical Device 12V Power Source - What inspection and testing is required? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Does ISO/IEC 17025:2005 require the Laboratory to have separate ISO 9001 Procedures ISO 17025 related Discussions 4
R HVAC Contaminant Test for Two Separate Areas Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
R CNC OTS Software Validation Separate from full IQ/OQ/PQ for 21CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
S Accessing data from separate worksheets in Minitab Using Minitab Software 3
Q Corrective Action as a Separate Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Separate Quality Manuals for Different Sites Quality Management System (QMS) Manuals 3
T 10 CFR 50 App B, NQA-1, NCA-3800 - Separate Manuals? Various Other Specifications, Standards, and related Requirements 4
