Type 1 Gage R&R or something else?
We have purchased a robotic gauging machine to test insertion and retention of cylindrical parts. There is no operator input with the exception of pushing the start button.
The robot picks up a cylinder that has tabs on one end 20200818_115526_resized.jpg
It then forces cylinder over a known gage pin and measures force required, it also at second station does the same but at this station it measures force needed to remove from gage pin. My question is how best to run a MSA. I do not have variation from different operators. I can not really run a type one gage R&R because every time the cylinder is measure and forced on a gage pin it affects the strength of the material, introduces wear and in turn the results.
Ninja
Looking for Reality
Before the GRR....
How are you reconciling the fact that your manufacturing In-Process testing changes the product?
Assuming GRR is awesome and done...how do you know the properties of what you are shipping, since they are no longer what you tested?
Before the GRR....
We understand there is a change in the product after testing one time that is very minimal, and can be quantified by retesting to see exactly what the change is. My concern with a MSA is that running the same part 50 times will be a much greater change between run 1 and 50 than say between run 1 and 2
you don't need a type 1 assessment.
you also don't need to test multiple operators.
my recommendation is to test 30 parts twice and plot it on a Youden. a Youden plot is a square 'scatter diagram' with a 45 degree 1:1 line. if there were no measurement error the two repeat measuremetns would fall on the 1:1 line. measurement error is the scatter perpendicular to the 1:1 line.
You can find the information on how to do it in the resources section. I published 2 items that will help: MSA tools will help you graph the output and MSA (not your father's gauge R&R) will describe how and why to do the analysis.
If there is slight damage that changes the part it will show up as bias to the 1:1 line. you can post your results here again for more interpretation help...
Ninja
Looking for Reality
Thanks for your answer.
My two cents...
1. Have you read @Miner 's blog on MSA? He covers MSA on destructive testing pretty well (read "awesomely").
2. You are concerned...is that concern valid by data?
Consider doing a 1x2x10 GRR (one operator, two samples, 10x each) and see if your part changes only once and plateaus or continues to change...
Added in edit: ...or what Bev said...
John Predmore
Another approach to assess gage repeatability in a process operation where one or both parts irreversibly change is to take 2 readings of every single insertion force event. The way to do that is Newton's third law, for every action there is an equal and opposite reaction. Put a force sensor on the insertion tool and a second force sensor on the fixture which holds the part. This 2-sensor method was championed by Dorian Shainin, and the paired sensor data points can be plotted on a Youden plot which @Bev D described. To reduce the risk that parallel measurement bias on both sensors in your experiment prevent you from seeing the bias, employ different technology sensors if possible - a piezoelectric load cell and a spring loaded LVDT, for example - or one sensor in compression and the other in tension.
Welshwizard
Hi Steve,
I would take at least 10 parts or more and measure each part 3 times.
Plot the data on an X Bar R Chart
Any signals on the Average Chart show that the measurement system can detect product variation
Any signals on the Range chart indicate problems with the measurement process.
Please post the data on here if possible for characterisation please see the link for more detail The Short EMP Study
Hope this helps you.
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
M For a Type 1 Gage R&R I want to use 1 unit and measure it 30 times Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P What is a Type 3 Gage Study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Type 1 GRR (Gage R&R) on a One Sided Specification Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
H Type 1 Gage Study Interpretation Question Using Minitab Software 7
S Minitab: Type 1 Gage Study vs. Gage R&R Study Using Minitab Software 5
M Type 1 Gage R&R - Analyzing Run Chart and I-mR Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Type 2 GR&R (Gage R&R): % Contribution & % Std Var Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
W Type 1 Gauge (Gage) R&R Excel Template anyone? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
A Gage Block Repair - What type of stone is acceptable for removing burrs General Measurement Device and Calibration Topics 5
M Type 1 Gage Study - What's your opinion on this gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Type 1 Gage Study Excel Template Excel .xls Spreadsheet Templates and Tools 5
G Gage R&R for every gauge? Or is it only every type of gauge? MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
Marc Errors - Uncertainty Type I, II, or Alpha, Beta vs. Gage R&R Measurement Uncertainty (MU) 1
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Separation of F-type applied part and remaining parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A AMSQQP416E Class 2 type 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Are EC type examinations still being conducted under MDR? EU Medical Device Regulations 5
S Medical watch Class II (AP Type CF) with USB connection IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
Johnnymo62 Non Aerospace topics - Anything for military trucks, trailers, Humvee type vehicles? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
N BF-type applied part MOPP vs secondary IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Marcel DS GOST-R (Type approval for Vehicles in Russia) Other ISO and International Standards and European Regulations 0
I Old Time Scatter diagrams for defect type and location- software Quality Tools, Improvement and Analysis 7
P Surgical masks ( type IIR) - Cleanroom Requirements EU Medical Device Regulations 3
W Insulation requirements of BF type infant skin temperature probe IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
N Infant radiant warmer - Heater Quartz Element type Other Medical Device Related Standards 0
K Validation of new machine (second machine of the same type) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
F Operator Manual and Type B Uncertainty Measurement Uncertainty (MU) 3
M SI #7 8.4.2.1 Type and extent of control_supplemental IATF 16949 - Automotive Quality Systems Standard 3
B F-type applied part - Separation from ALL(?) other parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
A IATF Sanctioned Interpretation No. 7 - Type and Extent of Control (supplemental) IATF 16949 - Automotive Quality Systems Standard 4
K F-TYPE APPLIED PART IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
I AS9100 8.4.2 Type and Extent of Control - External provider test reports Manufacturing and Related Processes 24
F Determining what type of scrap to include in my internal PPM calculation Quality Manager and Management Related Issues 5
R In this type of Legal Manufacturer-CMO arrangement, what happens to the DHR? ISO 13485:2016 - Medical Device Quality Management Systems 1
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
T Type BF or CF (Direct conductive contact with the heart) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P IVDD - IFU related requirements - Type of information/statement expected EU Medical Device Regulations 1
B Documented process for type and extent of control IATF 16949 - Automotive Quality Systems Standard 6
