Type 1 Gauge (Gage) R&R Excel Template anyone?
W
wrekin
Does anyone have or know where I can get an Excel Type 1 Gauge R&R Template from?
I want to conduct a 1 x 1 x 50 study of a gauge, I'm only interested in gauge repeatability not reproducibility as in the normal 3 x 3 x 10 GRR's.
Appreciate if someone would post a file.
:D
statdoug
Re: Type 1 Gauge R&R Excel Template anyone?
Are you planning to measure 1 part 50 times? I would advise measuring several samples a few times each. A single sample measured many times, though the theoretical definition of repeatability, only represents a single point in the range of the measurements. More samples allows for an average error that represents the gage more accurately. If you do use one part measured 50 times, the calculations are pretty simple, but probably someone would have to through it together, because it is somewhat unconventional.
Coury Ferguson
Moderator here to help
:D
Have you checked the "Post Attachment List" in the upper left corner to see if there are any templates? I am sure there would be.
W
wrekin
Hi Statdoug,
Thanks for your reply.
Yes as my original post stated I wish to conduct a 1 part 50 times GRR. This is a Type 1 study, and in my opinion is a conventional study, please advise why you think this is unconventional. This type of GRR should be the first conducted prior to the most common 3 x 3 x 10.
The reason for conducting a Type 1 GRR is to initially ‘prove out’ the functionality of the gauge and a target of <10% is set. If this target is achieved then the gauge would almost certainly pass the full 3 x 3 x 10 GRR. If it fails the Type 1 then the whole gauge concept requires a rethink / redesign.
You say the calculations for a Type 1 are pretty simple, one thing that is important to my boss is the P value (Anderson-Darling Normality Test), do you have something in place in MS Excel that I can modify to suit my needs?
Your valued input would be very gratefully received.
W
wrekin
Hi Coury,
Sorry could you direct me to the "Post Attachment List" that you mention, I cannot see this link.
statdoug
You definitely want only one appraiser, but as I mentioned before, using 1 part only looks at a very narrow part of the gage. For example, lets assume as one possible scenario, that your measurement system is slightly "chunky." This is a normal condition of variable data caused by the discrete scales we impose on continuous functions (i.e., our time readings are usually in seconds, but if we want, we can measure to nanoseconds or some other fraction, but sooner or later we settle at some increment. When we measure a single part, it is going to have a true value that is probably slightly larger or smaller than our nearest increment. If it is very close to an interval, it will give us a bunch of identical readings. A little further away and we may get 2/3 of the values as one reading, and the other third as the second closest increment. This is one example, but the same kind of problem holds true with other aspects of measuring a single part.
When we look at multiple parts, still only with a single appraiser, but representing a broader pool of possible part situations, we get a type 1 gage error that is less affected by idiosyncracies of the product.
As far as a P value goes, this does not exist in isolation. If you measure 1 part 50 times, you will have within part variation. What are you going to compare this to? Any value only has meaning in its context within other numbers.
G
GeorgieP
This is for a quick check, to acknowledge the fixture is fit for purpose, as there is a time restriction prior to movement of tools. Then a proper gauge R&R can be submitted (ANNOVA Method). Is there any way to obtain this doc?
:thanx:
W
wrekin
Hi GeorgieP,
I have developed an MS Excel Workbook that has been 'calibrated' against Minitab and I'm very glad to say is absolutely spot on.
I didn't quite understand some peoples posts on my thread, as a Type 1 GRR is not anything out of the ordinary, as I believe the posts are leading people to believe!
Type 1 studies are carried out as a 'first quick look see' at the gauges functionality. Once you're satisfied that its performing how you'd like it too, then you submit a 10x3x3 MSA GRR.
Would you like a copy of my MS Excel Workbook?
Wrekin
G Gage R&R for every gauge? Or is it only every type of gauge? MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
G Type 1 Gauge R&R - Excel example wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Ford MSA - Ford TYPE 1 study on a Marposs post process gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Reading Gauge Output Into Excel .xls - Mitutoyo digital plunger type depth gauges Excel .xls Spreadsheet Templates and Tools 5
M Lever type dial gauge - Usage of a dimensional 'test indicator' for measurement General Measurement Device and Calibration Topics 10
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Separation of F-type applied part and remaining parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A AMSQQP416E Class 2 type 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Are EC type examinations still being conducted under MDR? EU Medical Device Regulations 5
S Medical watch Class II (AP Type CF) with USB connection IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
Johnnymo62 Non Aerospace topics - Anything for military trucks, trailers, Humvee type vehicles? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
N BF-type applied part MOPP vs secondary IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Marcel DS GOST-R (Type approval for Vehicles in Russia) Other ISO and International Standards and European Regulations 0
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
I Old Time Scatter diagrams for defect type and location- software Quality Tools, Improvement and Analysis 7
P Surgical masks ( type IIR) - Cleanroom Requirements EU Medical Device Regulations 3
W Insulation requirements of BF type infant skin temperature probe IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
N Infant radiant warmer - Heater Quartz Element type Other Medical Device Related Standards 0
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
K Validation of new machine (second machine of the same type) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
F Operator Manual and Type B Uncertainty Measurement Uncertainty (MU) 3
M SI #7 8.4.2.1 Type and extent of control_supplemental IATF 16949 - Automotive Quality Systems Standard 3
B F-type applied part - Separation from ALL(?) other parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
A IATF Sanctioned Interpretation No. 7 - Type and Extent of Control (supplemental) IATF 16949 - Automotive Quality Systems Standard 4
K F-TYPE APPLIED PART IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
I AS9100 8.4.2 Type and Extent of Control - External provider test reports Manufacturing and Related Processes 24
F Determining what type of scrap to include in my internal PPM calculation Quality Manager and Management Related Issues 5
R In this type of Legal Manufacturer-CMO arrangement, what happens to the DHR? ISO 13485:2016 - Medical Device Quality Management Systems 1
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
T Type BF or CF (Direct conductive contact with the heart) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P IVDD - IFU related requirements - Type of information/statement expected EU Medical Device Regulations 1
B Documented process for type and extent of control IATF 16949 - Automotive Quality Systems Standard 6
P Definition Business Type - Definition of what we do-Business Type Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
L Valid reasons to omit an "ear-tag" type label on a cable? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P 2x MOOP for type B AP - Therapeutic device - Heater/cooler with pump IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Complying with IATF 16949 Cl. 8.4.2.1 - Type and extent of control IATF 16949 - Automotive Quality Systems Standard 1
P DMF (Drug Master File) type V for Sterilization Processes for USFDA Submission Other US Medical Device Regulations 3
E IATF 16949 Cl. 8.4.2.5 - Supplier Development Type and Extent IATF 16949 - Automotive Quality Systems Standard 2
F IATF 16949 - Cl. 8.4.2.3 - Which type of suppliers could be exempt of ISO 9001 IATF 16949 - Automotive Quality Systems Standard 16
S Number of MOPP for Type BF Applied Part (Medical Device Electronics) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
