Types of Medical Device Cytotoxicity Testing - ISO 10993-5
How many types of cytotoxicity test are available for medical device testing . ISO 10993-5:1999 - Biological evaluation of medical devices
what are the difference between Plating Efficiency/Colony forming cytotoxicity test and Cell growth Analysis via BCA Staining (L929 cells).
If a medical device comes an indirect contact with blood of patient what type of cytotoxicity testing is preferanble in oder to gain CE in Europe.
Please a quick reply would be appriciable
MIREGMGR
I suggest you call some of the more prominent medical product testing laboratories in your area, and discuss this question with them.
They are likely to have a better comparative procedural knowledge than most of us, because they work with many manufacturers to specifically address that regulatory question for a wide variety of product types and materials.
bio_subbu
There are two types of cytotoxicity testing as per the Standard ISO 10993 such as cytotoxicity test by extract method and cytotoxicity test by direct method.
1. Cytotoxicity test by extract method:
Examples of cytotoxicity test methods using extracts include:
a) Fluid Medium Tissue Culture Assay
b) Inhibition of Cell Growth Assay
c) Cloning Efficiency Assay.
Fluid Medium tissue culture Assay:
Fluid Medium Tissue Culture evaluates the cellular damage caused by the test extract on a confluent monolayer culture. The text extract is incorporated into the culture medium which is usually double strength (2×) Minimum Essential medium supplemented with serum and other essential nutrients at the maintenance level. The toxic effect on the monolayer, such as cell lysis and microscopic observation of cell morphology changes, is usually checked after 24 and 48 hours. Cell lysis can be scored by direct microscopic observation or with the use of radiolabels or tryphan blue dye uptake.
Inhibition of cell Growth Assay
The inhibition of cell growth is a more informative test requiring more time and skill. Distilled water extract is incorporated into the tissue culture medium and inoculated with the cells in the tissue culture tubes. After 72 hours, the extent of cell growth is determined by total protein assay, such as the Lowery photometric method, on the removed cells from the individual tubes.
Cloning Efficiency Assay:
The Cloning Efficiency Assay is more informative, sensitive, and quantitative and requires even more skill. The Cloning Efficiency Assay’s procedure and endpoint is similar, but is more accurate, sensitive, and direct than Cell Growth Inhibition or Fluid Medium methods. The Cloning Efficiency assay normally uses a Chinese Hamster Ovary cell line and a single-cell cloning technique to estimate the toxic insult induced in cloning efficiency. The number of cells in The initial inoculum is considerably less than those plated to get confluent cultures (approximately 1 × 105 or less cells in a 100 × 15 mm Petri dish, compared to 1 × 106 or more cells).The initial inoculam are incubated for approximately 24 hours before these growing cells are treated with the tissue culture medium containing the test extract. The cytotoxic effect of the extract is determined by measuring the ability of the treated cells to form colonies during seven subsequent days of incubation. The cloning efficiency of the treated cultures is compared to that of the control. The agar overlay method can be used to evaluate the toxicity of the extracts, but it is primarily used for the direct contact cytotoxicity tests of the solid test sample.
2. Cytotoxicity test by direct method:
Several tests are available to test cytotoxicity by direct contact please refer below ASTM standards and guidelines;
1. ASTM F813 Practice for Direct Contact Cell Culture Evaluation of Materials for Medical Devices
2. ASTM F895 Test Method for Agar Diffusion Cell Culture Screening for Cytotoxicity
3. ASTM F1027 Standard Practice for Assessment of Tissue and Cell Compatibility of Orofacial Prosthetic Materials and Devices
I don’t know exactly what type of testing required by indirect contact with blood of patient, for more details discuss with any of the biocompatibility testing centre in your country.
Thanks and Regards
S. Subramaniam
devicenewby
I'm new to this forum and new to devices. This review on cytotox testing was very helpful.
I am working with iontophoretic devices. I'm guessing I will need to use an MEM elution method for testing. How do I figure out what to elute the device with and how long should the elution be incubated with the cells, 24, 48 or 72 hrs?
Thanks!
E Types of nonactive Medical Device implants - What is the origin of this codification? EU Medical Device Regulations 6
Q Different Types of Audits in Medical Device industry Misc. Quality Assurance and Business Systems Related Topics 9
O Average Life Cycle Duration for a large number of medical equipment types Other Medical Device and Orthopedic Related Topics 2
J FMEA "Types" - ISO 14971 (Medical Devices - Application of Risk Management) ISO 14971 - Medical Device Risk Management 7
T Types of confidential information ISO 17025 related Discussions 8
L Allowable AC mains fuse types for latest IEC60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Torque Value for Different types of Fasteners (Socket Head, Button Head, CSK) Manufacturing and Related Processes 2
C PCBA Hardware Component different failure types - How to rate detection? FMEA and Control Plans 8
E Different types of Actions? CARs, OFIs or N/A ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S The key differences in 510k types - Traditional vs. Abbreviated vs. Special US Food and Drug Administration (FDA) 0
R ISO9001 & ISO13485 QMS for 2 types of products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Rameshwar25 Other types of Control Charts described in Chapter II of SPC Manual Statistical Analysis Tools, Techniques and SPC 6
P Any official doc/spec on different types of Yield calculation? Manufacturing and Related Processes 0
B IATF 16949 Cl. 9.2.2.1 - Internal audit program - Types of evidence Internal Auditing 1
S ITAR Document Types and Training Other ISO and International Standards and European Regulations 6
Q Where to include other types of Nonconformities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R 21 CFR Part 820.186 - Types of Quality System Records Document Control Systems, Procedures, Forms and Templates 1
C What types of Calibration Metrics are Collected General Measurement Device and Calibration Topics 2
S Double Thermocouple - Two types, same sheath (AMS2750/Nadcap) Manufacturing and Related Processes 9
S Clarification regarding types of processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Types of Controlled Documentation - Call Lists of Emergency Contacts Quality Manager and Management Related Issues 5
M Process Approach: Types & number of processes required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
G Comparison Study of CMMs and software along with Probe Types Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
V CMM plane construction method types and accuracy differences for measuring Pos Tol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Latest types of Fire Extinguishers in India Misc. Quality Assurance and Business Systems Related Topics 1
L Capability studies on machine types - Supplier has over 1000 machines Quality Manager and Management Related Issues 7
I Types of Internal Audit findings based on ISO 9001 Clause 8.2.2 Quality Manager and Management Related Issues 10
C Chrysler Quality Definitions? Chrysler has identified six types of quality Quality Manager and Management Related Issues 1
C AUDITS! Different types of audits and what they mean? General Auditing Discussions 9
U Dial Gages of all types in company flood - How to recover them General Measurement Device and Calibration Topics 6
Z KFDA (Korea) Device Change Regulations - What are 32 Types of Changes Exempted? Other Medical Device Regulations World-Wide 2
E Implementing Risk Management - Required Document Types ISO 14971 - Medical Device Risk Management 8
P NQA-1 Requirement 17 Quality Records - Facility Types and Temporary Storage Various Other Specifications, Standards, and related Requirements 5
Michael Malis FDA Guidance for Herpes Simplex Virus Types 1 and 2 Serological Assays US Food and Drug Administration (FDA) 0
B What are the Types of Quality Tools? Quality Tools, Improvement and Analysis 6
R Inspection types A, B AND C used in FMEA Preparation FMEA and Control Plans 3
M Design for Six Sigma to be applied for different types of Manufacturing Processes Six Sigma 1
R Different types of Design and Development - AS9100C Clause 7.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
E Types of Standards and Harmonized Standards Other ISO and International Standards and European Regulations 6
N Report Content of 2 types of Calibration on the same equipment - Timer and Speed Test General Measurement Device and Calibration Topics 2
N Difference between different types of Benchtop Convection Ovens General Measurement Device and Calibration Topics 5
Q How should I Keep my various types of records .. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J BS EN131-1:2007 Standards (Ladders, Specification for terms, types, functional sizes) Other ISO and International Standards and European Regulations 1
T Determination of UMDNS Code for various types of Contact Lens ISO 13485:2016 - Medical Device Quality Management Systems 4
Marc Three-Inch Device Detects 3,000 Types of Viruses and Bacteria World News 0
M Types of Yearly Quality Goals for all Manufacturing Associates Manufacturing and Related Processes 3
E Calibration of Calipers, Mics, Height gauges - Recommended Gage Block Types General Measurement Device and Calibration Topics 7
C Creating a Micro QMS - 4 geographical sites and 3 types of core activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Definition P-Diagram - Types of Noise Factors - Information System Processes Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 12
P Determining Sample Size - Filling a bag with three different types of candy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
