Typical Auditor Questions on ISO 9001
X
XIO549
Hi Covers.
This may have been covered in other threads, but couldn't find any.
Essentially, as I am just now completing the process of rolling out the
Procedure Documents in the organisation, and doing a Gap analysis on the Quality Manual I have compiled, I'm trying to 2nd guess auditors questions by following the Standard clauses.
Do Auditors have 'pet' questions or are there typical questions that that ask?
I am at pre-registration stage yet, but want to get this wrapped up now so that I'm not constantly fixing the Manual as I proceed with the process.
I've received great help from here already and hope there are simple accurate answers to follow to this question also.
Cheers guys.
Xio
Frankly I would not be too overly concerned about this. Marc's link will help set your mind at ease but I don't think you 'll have much porblem.
Assuming you are like most of us, you are building your manual and procedures from two core items. 1) What your system requires and 2) What the ISO Standard calls for. As you go back and forth between these two, you'll hit on a good combination that satisfies both AND more importantly you'll be able to answer any question intelligently because that is how you created your documents.
Peace
James
X
XIO549
Yes James,
Marc's link is helpful and I'm doing pretty much what you've described.
So far, I feel that I could answer most questions as to how we comply and identify the procedure and record. Theres just that one awkward question that I know I'll get in an audit and wish I were prepared ; have never had an audit, so mainly this is my own paranoia. Hence the 'Standard' list of questions question.
Thanks for the link Marc. Have you any similar ones?
Xio
The best advice any of us can give you is - try to relax.
These auditors have down this road so many times and have "seen it all", or at least the lead auditor has. If you get a question that, "throws you", don't worry. Ask them for clarification, etc. If they happen to hit on something that you really hadn't thought of, just say so, and take the necessary steps to correct it.
The more relaxed, amiable and professional you are the easier the audit will be.
When I was first going through these things, I fully expected to "get nailed", and was frankly greatful for it (these were pre-cert audits. The auditor I used was frank, helpful and very easy to get along with....It also just happened to be our own Marc Smith....:notme:
Anyway - Long story short, don't expect to get everything nailed down the first time. And after you've been through it once, you'll know far better how your auditor(s) work, what they look for etc. Yes it will be stressful, but exciting too.
Peace
James
SteelMaiden
I agree the best thing is to just relax. Are you comfortable with what you are doing? If so, chances are that you will be able to explain everything to an auditor. You can pretty much tell what they are going to ask about by looking at the various sections of the standard and how they all fit into your processes. Take a deep breath, and be honest, if you find out that you need to fix something, fix it and move on. Good luck.:agree:
Marc
JRKH is right as is Steel.
If you're real freaked out get someone local to come and do a mock audit and walk-through. Back in the 1990's when I was doing implementation for a number of very large companies I would use a contract auditor to come in prior to the registrar by about a month to go through everything to make sure there was nothing I missed when doing the implementation. With my reputation at stake, with large companies I did not hesitate to bring someone in (a fresh set of eyes, so to speak) to look things over. And yes - A few times they found some things that I 'missed' (for lack of a better word). I used to do mock audits prior to the registrar coming and, for example, an auditor I contracted to check my work at one 5000 person facility found a whole department was not dating a specific form when they completed it which they should have been doing (systemic failure).
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
T Reasons to change certification body and typical costs Registrars and Notified Bodies 16
R What is the typical industry standard for documenting Usability Risk? Human Factors and Ergonomics in Engineering 16
I AS9100 5.4.1 - Typical objectives of different functions and levels AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S OHSAS 18001 Typical Input and Output Examples Occupational Health & Safety Management Standards 4
optomist1 Typical Wire Harness Testing and Validation Testing for Automotive Applications Reliability Analysis - Predictions, Testing and Standards 8
M Example of a typical First Piece Inspection Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Is there a typical personality type in Quality? Coffee Break and Water Cooler Discussions 38
S What are typical Acceptable Quality Levels (AQL) adopted in Food industry? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
P Typical Number of NCRs for a Small Manufacturing Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T How many complaints, defects and non-conformances are typical? Customer Complaints 5
W What are "typical software risks"? Is IEC/TR 80002-1 a good place to look for a list IEC 62304 - Medical Device Software Life Cycle Processes 3
A The typical organizational set-up for Housing Services - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Typical values of MTBF for Optical Avionic Networks Reliability Analysis - Predictions, Testing and Standards 1
J What are some typical Customer Service Interview Questions Career and Occupation Discussions 5
S Typical Tools for Particular Tolerances Table? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
L What typical items do auditors bring to Opening Meetings Internal Auditing 4
M What are typical Roles & Responsibilities of DHF (Design History File) Librarian? US Food and Drug Administration (FDA) 6
N What are typical Software Life Cycle Metrics Software Quality Assurance 5
M Typical requirements for Internal Audit Lead Auditors Internal Auditing 5
L Typical defect ppm level for barrel surface coating process? Supplier Quality Assurance and other Supplier Issues 1
R What is a typical ppm performance level for casting suppliers? Supplier Quality Assurance and other Supplier Issues 7
J Typical Control Chart Guidance and Hypothesis Statistical Analysis Tools, Techniques and SPC 12
R MTBF to DPPM Calculation Based on the Unit's Typical Working Hours Reliability Analysis - Predictions, Testing and Standards 9
C Calibration Standards and Typical Accuracy Requirements for Force Gauges General Measurement Device and Calibration Topics 3
T Is this typical customer service? World News 12
T EMS (ISO 14001) Audit / Interview Typical List of Questions for Review and Additions ISO 14001:2015 Specific Discussions 15
R DCX PSO book 5th Edition - Does anyone have a typical index or check list? APQP and PPAP 6
O What are typical records of different documents required by ISO9001? Records and Data - Quality, Legal and Other Evidence 2
H Exponent in Excel .xls - How can I make the result typical scientific notation? Excel .xls Spreadsheet Templates and Tools 27
P What is Milliohms Typical? Cable assemblies for vehicles Manufacturing and Related Processes 6
Govind What is your typical attendance of ASQ program meetings? ASQ - American Society for Quality 33
L Seeking example of a typical Work instruction for purchasing Document Control Systems, Procedures, Forms and Templates 3
T Standard Causes of Registration Audit Nonconformances and Typical Failure Modes IATF 16949 - Automotive Quality Systems Standard 5
D What does RTYP on a Print Stand For? Radius Typical? Misc. Quality Assurance and Business Systems Related Topics 7
Marc What are the Contents of a Typical Characteristics Matrix? FMEA and Control Plans 1
R Typical Document / Record Transaction and Archive Volumes Document Control Systems, Procedures, Forms and Templates 4
W Redacting Info Before Giving to Auditor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Quality auditor legal right to see Board meeting minutes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
V Internal Auditor Competency KPI IATF 16949 - Automotive Quality Systems Standard 14
R American Petroleum Institute - Becoming an API Auditor Professional Certifications and Degrees 2
B Lowest cost way to pass Lead Auditor exam ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Internal Auditor Competency - Product Auditors Internal Auditing 9
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
Z Auditor Findings ISO 14001:2015 vs. 45001:2015 ISO 14001:2015 Specific Discussions 6
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
A Becoming an ISO27001 3rd Party Auditor Career and Occupation Discussions 4
L ASQ's Biomedical Auditor Course Test ASQ - American Society for Quality 1
